Why not use Aspire to create the tool paths ?
Is it some kind of trial version of Aspire that can't post tool paths?
You all know I am just beginning this Craft, And NEED ALL THE HELP I CAN GET!!
I tried to Post the Tap file, NO GO, I tried also to Post the Aspire Vetric File Still NO GO. Files too Big Or Wrong Format or something wrong,
So I went back and Copied a bit of this file to post, It is actually over 17,000 lines, So Just Posting a few to show What I am Saying here,
This is the Back Machining of a Les Paul Guitar, . I took the Vectric File and Opened it in Aspire, I then proceeded to Change it to a DXF File, Then opened file in Lazycam and Selected ALL Layers. Then Created and saved G-Code, Everything Looks GREAT when running the files. EXCEPT the Z-Axis, I am used to setting up the Z-axis to cut the depth of cuts per pass. This file through the complete sequence all you ever see from the Z-axis is +1.00 Or 0.00 . I am Dumbfounded here.
Be glad to send you the complete files and let you take a look if you want, just send me an email : cubsfan1953@yahoo.com
All the way through 23 minutes of running on Simulator The Z-Axis will move from +1.00 to 0.00 and that is is.
I don't know what I am Doing wrong,
Thanks My Guru friends,
cubs
N5 (File Name = Body-Back on Saturday, March 14, 2020)N10 (Default Mill Post)
N15 G91.1
N20 G0 Z1.0000
N25 M3
N30 X3.7547 Y-4.5991
N35 Z0.1000
N40 G42
N45 G1 X3.7232 Y-4.5934 Z0.0000 F60.00
N50 X3.6917 Y-4.5874
N55 X3.6602 Y-4.5811
N60 X3.6288 Y-4.5744
N65 X3.5974 Y-4.5675
N70 X3.5660 Y-4.5602
N75 X3.5347 Y-4.5527
N80 X3.5034 Y-4.5449
N85 X3.4722 Y-4.5368
N90 X3.4411 Y-4.5285
N95 X3.4100 Y-4.5199
N100 X3.3790 Y-4.5111
N105 X3.3512 Y-4.5030
N110 X3.3236 Y-4.4947
N115 X3.2960 Y-4.4863
N120 X3.2685 Y-4.4777
N125 X3.2410 Y-4.4689
N130 X3.2136 Y-4.4600
N135 X3.1863 Y-4.4508
N140 X3.1591 Y-4.4416
N145 X3.1319 Y-4.4321
N150 X3.1048 Y-4.4225
N155 X3.0778 Y-4.4127
N160 X3.0509 Y-4.4028
N165 X3.0240 Y-4.3927
N170 X2.9972 Y-4.3824
N175 X2.9704 Y-4.3720
N180 X2.9437 Y-4.3614
N185 X2.9171 Y-4.3507
N190 X2.8906 Y-4.3398
N195 X2.8641 Y-4.3288
N200 X2.8377 Y-4.3176
N205 X2.8113 Y-4.3063
N210 X2.7851 Y-4.2948
N215 X2.7588 Y-4.2832
N220 X2.7327 Y-4.2714
N225 X2.7066 Y-4.2595
N230 X2.6806 Y-4.2475
N235 X2.6546 Y-4.2353
N240 X2.6287 Y-4.2230
N245 X2.6028 Y-4.2105
N250 X2.5771 Y-4.1979
N255 X2.5514 Y-4.1852
N260 X2.5257 Y-4.1723
N265 X2.5022 Y-4.1604
N270 X2.4788 Y-4.1484
N275 X2.4553 Y-4.1362
N280 X2.4319 Y-4.1240
N285 X2.4085 Y-4.1117
N290 X2.3851 Y-4.0993
N295 X2.3617 Y-4.0868
N300 X2.3382 Y-4.0743
N305 X2.3148 Y-4.0617
N310 X2.2914 Y-4.0491
N315 X2.2679 Y-4.0365
N320 X2.2444 Y-4.0238
N325 X2.1973 Y-3.9984
N330 X2.1738 Y-3.9857
N335 X2.1501 Y-3.9730
N340 X2.1264 Y-3.9603
N345 X2.1027 Y-3.9477
N350 X2.0789 Y-3.9351
N355 X2.0551 Y-3.9225
N360 X2.0311 Y-3.9101
N365 X2.0072 Y-3.8976
N370 X1.9831 Y-3.8853
N375 X1.9589 Y-3.8730
N380 X1.9347 Y-3.8608
N385 X1.9104 Y-3.8488
N390 X1.8860 Y-3.8368
N395 X1.8614 Y-3.8250
N400 X1.8368 Y-3.8133
N405 X1.8121 Y-3.8017
N410 X1.7872 Y-3.7903
N415 X1.7622 Y-3.7791
N420 X1.7422 Y-3.7702
N425 X1.7222 Y-3.7615
N430 X1.7021 Y-3.7529
N435 X1.6819 Y-3.7445
N440 X1.6616 Y-3.7361
N445 X1.6412 Y-3.7279
N450 X1.6208 Y-3.7199
N455 X1.6003 Y-3.7120
N460 X1.5797 Y-3.7043
N465 X1.5590 Y-3.6967
N470 X1.5383 Y-3.6893
N475 X1.5175 Y-3.6820
N480 X1.4966 Y-3.6749
N485 X1.4756 Y-3.6681
N490 X1.4546 Y-3.6614
N495 X1.4334 Y-3.6549
N500 X1.4122 Y-3.6486
N505 X1.3909 Y-3.6425
N510 X1.3696 Y-3.6366
N515 X1.3482 Y-3.6310
N520 X1.3266 Y-3.6256
N525 X1.3051 Y-3.6204
N530 X1.2834 Y-3.6155
N535 X1.2617 Y-3.6108
N540 X1.2399 Y-3.6063
N545 X1.2180 Y-3.6021
N550 X1.1960 Y-3.5982
N555 X1.1740 Y-3.5946
N560 X1.1519 Y-3.5912
N565 X1.1298 Y-3.5881
N570 X1.1075 Y-3.5853
N575 X1.0852 Y-3.5828
N580 X1.0596 Y-3.5803
N585 X1.0339 Y-3.5782
N590 X1.0082 Y-3.5765
N595 X0.9825 Y-3.5752
N600 X0.9567 Y-3.5743
N605 X0.9309 Y-3.5738
N610 X0.9051 Y-3.5737
N615 X0.8792 Y-3.5739
N620 X0.8534 Y-3.5746
N625 X0.8276 Y-3.5756
N630 X0.8018 Y-3.5771
N635 X0.7760 Y-3.5789
N640 X0.7502 Y-3.5811
N645 X0.7245 Y-3.5837
N650 X0.6988 Y-3.5866
N655 X0.6732 Y-3.5900
N660 X0.6476 Y-3.5937
N665 X0.6221 Y-3.5978
N670 X0.5967 Y-3.6023
N675 X0.5713 Y-3.6072
N680 X0.5460 Y-3.6125
N685 X0.5208 Y-3.6181
N690 X0.4958 Y-3.6241
N695 X0.4708 Y-3.6304
N700 X0.4459 Y-3.6372
N705 X0.4212 Y-3.6443
N710 X0.3966 Y-3.6518
N715 X0.3721 Y-3.6597
N720 X0.3478 Y-3.6679
N725 X0.3236 Y-3.6765
N730 X0.2996 Y-3.6855
N735 X0.2756 Y-3.6949
N740 X0.2450 Y-3.7075
N745 X0.2145 Y-3.7208
N750 X0.1844 Y-3.7346
N755 X0.1547 Y-3.7490
N760 X0.1252 Y-3.7639
N765 X0.0961 Y-3.7793
N770 X0.0673 Y-3.7952
N775 X0.0387 Y-3.8116
N780 X0.0105 Y-3.8283
N785 X-0.0175 Y-3.8455
N790 X-0.0452 Y-3.8631
N795 X-0.0726 Y-3.8811
N800 X-0.0998 Y-3.8994
N805 X-0.1268 Y-3.9181
N810 X-0.1535 Y-3.9371
N815 X-0.1799 Y-3.9564
N820 X-0.2062 Y-3.9760
N825 X-0.2322 Y-3.9958
N830 X-0.2580 Y-4.0159
N835 X-0.2837 Y-4.0362
N840 X-0.3091 Y-4.0567
N845 X-0.3344 Y-4.0775
Anyone who says "It only goes together one way" has no imagination.
It is hard to understand your process but from what I understand an import/export of a dxf file is involved.
Dxf format may be reduced to 2D during importing or exporting, losing the Z axis data.
From 2D geometry back to Gcode you will then have a reset of the Z axis coordinates, from what I see a Z1.000 for rapid move to a Z0.100 for approach and finally Z0.000 in feed.
Thank You Lucas,
I finally Got the Back Procedure Figured out, And Ran The Code in Simulation, And everything looked good,
Except the setup of material is set Long Side in X-Axis, My X-Axis is Short, So I need to figure out how to Change to Y-Axis for the Long Side,
But I'm NOT giving up, The New CNC Build I'm Doing is a Much larger working area, But I'm Still Several months from having it completed, LOL
cubs
If the whole file have the same structure as the sample you posted, you can do that with a "regular expression" search and replace in text editor (with notepad++ for example)
search for : (X)([0-9+-. ]+)(Y)([0-9+-. ]+)
replace with : X\4Y\2
It will swap X and Y coordinates in the whole file (with mirroring the geometry)
It looks like you may have the G42 cutter compensation set up incorrectly. It's usually supposed to be on the same line as a motion command. See: LEARNING CNC STRATERGIES AND TIPS: G40 G41 and G42 Cuttercompensation
