G76 Thread help
Results 1 to 8 of 8
Thread: G76 Thread help
    Member osubucksfan09's Avatar
    Dec 2019
    Default G76 Thread help
    Attempting to turn 5/16-18 Threads on 4140 Material. L20 Citizen Mitsubishi Controls
    Turn down .312(.030 chamfer 45 degree), and Grooving clearance (Groove to .242) past the threads. I am using an Iscar 16ER18 turning insert, with a right hand holder that is at a 10 degree
    Using the code below, I consistently get threads that fit in the go gage for pitch, not in the no go for pitch, but the back side appears to have what looks like nicks, and the first thread appears damaged.
    Unsure how to control retract as wondering if machine is not retracting far enough to clear the part.
    G96S700
    G0X.355 Z-.225
    G76 P020030 Q0005 R0005
    G76 X.2405 Z.16 P0350 Q0010 R0 F.055
    Any advice would be greatly appreciated.
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    Default Re: G76 Thread help
    hy osub i have worked with citizen cincom l12 with mithusbishi cnc, mass-production, setups > 2 months
    i like to program the depth of each pass, like this :
    Code:
    T0505 G99
    M3 S1=3000
    G0  X13                    Z-1
    G92 X5-0.28                Z3.5 F0.5
        X5-0.28-0.24
        X5-0.28-0.24-0.16
        X5-0.28-0.24-0.16-0.08
    G0  X13
    T00
    M5
    last 2 passes are spring passes, thus they don't cut material, but only make the thread look better
    in previous code, retraction occurs at X13
    also, is good to be able to detect the retracting diameter, without looking inside the code
    please take a look over attached image : i have never used that code, by i only shared it, so to show you that i could find informations pretty fast, like in 60 seconds
    if you wish for cnc manuals, please share an e-mail in private message; archive is about 32mb
    this is a classical problem thus you have ok from the go&no-go calibers, but the thread does not look ok
    there are methods to improve the aspect, for frontal chamfer, back chamfer, and in-between
    [ frontal-chamfer, back-chamfer ] : after the threading operation, re-cut only the chamfer, by going down, towards X-; if you wish to improve the aestetich even more, try using a double chamfer, like merging a 45degrees with a 30degrees
    [in-between] : also the entire thread aspect can be improved, and the method involves spring-passes, and sometimes also re-cutting the od; what do to depends, if there is used a full-profile-insert, or a partial-type
    also, if needed, i program custom infeed patterns
    i hope you find this useful / kindly
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
    Dec 2019
    I appreciate the info, but I'm still trying to figure out why my G76 isn't working. It should work in theory. By cosmetic, I mean that it appears I am not retracting enough, as a section of the beginning thread is missing, and the back side on everycthread is gouged (not at same position but multiple positions), making me believe the tool is dragging into it during the retract pass.
    Quote Originally Posted by deadlykitten View Post
    Code:
    T0505 G99
    M3 S1=3000
    G0  X13                    Z-1
        X5-0.28-0.24
        X5-0.28-0.24-0.16
    G0  X13
    T00
    M5
    Jun 2015
    Antarctica
    hy, when i started to write programs for the citizen, i was not used with the g76-syntax, thus i was only somehow aware that fanuc has a threading syntax that requires 2 lines of code
    i was used with using a single line syntax, or with controlling the depth of each cut
    now, back to you :
    ... replace "G0X.355 Z-.225" with a bigger X value, thus increase radial clearance
    ... test lower rpms, because at high rpms, the cnc motion is not as stable as when using low rpms, especially when threading
    ... run 1 pass, stop and inspect, run 2nd pass, stop and inspect, and so on; it may be possible to observe that the tool is dragging after 3rd pass
    i have tested many threads, especially when threading with very low clearances, like between shoulders(?!), or inside tight holes
    sometimes, i reduce the rapid speed, so to avoid the dragging effect
    i hope this helps / kindly
    Member machinehop5's Avatar
    Aug 2009
    ...would G08 or G09 ramping mode affect threading?
    Feb 2011
    G96S700
    G0X.355 Z-.225
    first thing i would do is remove the g96 s700 as this is csfm and will cause the machine to ramp up and down as it is machining causing different starts as it picks up the point on the spindle to start
    is this machine a sub micron machine or non sub micro machine ?
    if it is a sub micron machine you would need an extra 0 either before or after the number IE 00050 would equal .0005 on a sub micron
    the mitsubishi control i work on you can use the decimal point for the Q,R,P values
    and last thing is if it still isn't working try doing P020060 some times the 60 degrees works good and F.0556
  7. #7
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    I agree... G97 instead of G96
    M3/M4 missing
    Z-.225 going to Z.16 ( so starting in groove cutting away from chuck.... not allowing any chance to get to correct feed before actually cutting ... P & Q addresses cant have decimal point
    Pxxyyzz
    xx= number of finish passes
    yy= thread ending 00=instant retract
    zz= infeed angle (varies between manufaturers, usually only fixed #s can be used.... I use 29 on 60° vee, so tip flank cleans up a little on each instep, zero is a straight infeed pattern) (60 may not work, so check manual)
    Q0005 is amount to leave for finishing passes
    R0005 is clearance (G76Xvalue plus 2 depths plus this value)... check this out.)
    G76Q0010 is depth of 1st pass.... can be larger
  8. #8
    Jun 2015
    Antarctica
    hy guys you are right, g96 should not be there
    i did not looked carefull over the code, i suposed that code syntax is correct, and even if the code is simple, i did not exactly remembered if 96 is ccs also on citizen; there are a few differences between g-codes, at least when compared to okuma ( for example 94 95 vs 98 99 )
    but the control itself should have generated an alarm, because 96 and 76 should not be compatible
    please, what do you mean by those ? i did not find them inside the citizen manuals / kindly
  9. #9
    Member hanermo's Avatar
    Aug 2004
    barcelona
    #5 and #6 are great ideas.
    Yet, it seems You are tearing threads on 1 side, only.
    Ramp mode per #5 might affect this, depending on your control.
    The clearance value might affect this.
    R parameter I think.
    Try R at 30x higher.
    Also, run a cycle at S1, aka spindle 1 rpm.
    See what happens.
    Put sharpie on a blank, and see where the error actually occurs after just 1 pass.
    Also, call your local mtb / reseller.
    They are usually extremely good at these types of things, and will tell you exactly what to do, why, and how, free.
    This is what I / we did when I was the commercial manager at Haas Spain.
    (long post deleted)
  10. #10
    Jun 2015
    Antarctica
    is possible that the cnc won't be able to handle s1; there may be a minimal rpm required, otherwise the cnc will stop, because it won't receive the confirmation signal
    ... on okuma lathes, the minimum accepted rpm is arround 20
    ... on citizen equiped with bar feeders, there is a parametet for this value, so to keep the spindle turning, when bar feeding occurs, in order to avoid scratching the guide bushing; if this parameter is lowered, then the machine will stop
    * i like to refer to this minimal rpm as dead-slow
    to speed up in machine checks, i use to open the door during cutting, stop the cutting fluid, and run in single block
    single block may be tricky if a 2nd spindle is used, so i use a custom test programs, that executes only the faulty operation / kindly
  11. #11
    Dec 2019
    Quote Originally Posted by Superman View Post
    M3/M4 missing
    Pxxyyzz
    Z 0 is faced off, so by starting at -.225 I am starting in space, then feeding stock into the cut for .160 distance.
    Confused when you say not having chance to correct feed, when should be making at least four complete thread revs before reaching part
  12. #12
    Jun 2015
    Antarctica
    hy osub, i believe that superman was reffering to the fact that your clearance may be too low ?!
    0.225inch = 5.715mm
    0.055inch = 1.397mm
    5.715/1.397=4.09 theoretical revs before reaching the part
    well, math is math, but this does not mean that you reach the required feed before begining to cut
    those 4.09 are theoretical revs, and you should take into consideration the distance required for the linear axis to get up to speed
    it is possible to have a thread that is ok at the go & no-go gauges, even if the machine reached the desired feed after z0
    inside okuma manuals are shared examples how to calculate the distance required to accelerate an axis
    in most cases this does not matter, unless you are threading with high specs, and low clearances / kindly
  13. #13
    Dec 2008
    Antarctica
    Bugger off kitty.... that is not what I meant
    .. I pictured part in spindle on left with origin at R/H face
    moving tool further left is Z- dir
    I have always followed the rule that you program the tool to move..... even if it is the part that does the actual movement.
G76 Thread help
G76 Thread help
