Help With Simple Code,
Results 1 to 5 of 5
Thread: Help With Simple Code,
    Jan 2017
    Question Help With Simple Code,
    Is anyone here familiar with Intuwiz G-Code Generator?
    I bought this software and can NOT Get it to work properly on a simple 2 inch Circle by .500 deep.
    Trying to set it up with a .25 tool, cutting .025 per pass on Aluminum.
    Will try to post picture of this interface,
    Thank You for looking,
    cubs
    Attached Thumbnails Attached Thumbnails Help With Simple Code,-dscn1119-jpg
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Help With Simple Code,
    ...looking at your dialog for first thing I see is missing decimal points possible. did you try 1.0000 instead of just 1 ?
    Jan 2017
    No I did not use decimal points,, Of Course this was just a copy of program I am trying to use,
    cubs
    May 2005
    canada
    Quote Originally Posted by cubby View Post
    cubs
    A screen shot with your actual inputs would have been more helpful. Also a bit of the g-code produced.
    fwiw the online version of Intuwhiz circles seems to work.
    Anyone who says "It only goes together one way" has no imagination.
    Jan 2017
    Quote Originally Posted by cyclestart View Post
    Thanks I will do that now,
    cubs
