Milling AR15 Bolt Carrier Need Some advice
Results 1 to 2 of 2
Thread: Milling AR15 Bolt Carrier Need Some advice
    Aug 2016
    Default Milling AR15 Bolt Carrier Need Some advice
    I am trying to lighten my AR15 bolt. This is just a cheap one so thought I would give it a whirl. I have a Harbor Freight X2 Mill and kinda a novice at this. I bought a carbide endmill and this past weekend tried to cut it...
    That was a joke! The mill touched that Bolt Carrier and acted like it was made of un-cuttable material. The endmill heated up and never got anything cut.
    So here's my questions...
    Yes I have the X2 i wanna be a mill machine but it should be able to cut it yes?
    Is this steel so hard that no use in trying or what is the secret? Type of endmill etc?
    I guess I can use a grinder to get the most material gone then clean up with an endmill but how should I do this?
    Member Mecanix's Avatar
    Aug 2019
    Default Re: Milling AR15 Bolt Carrier Need Some advice
    AR15? as in assault weapon engineered with a sole purpose to end life???
    you oki my friend?
