Need Help!- peck tapping on Robodrill --- Fanuc
Hello all,
I can't seem to figure out how to peck tapping on the robodrill Fanuc a-D21L iA5 control.
my other Fanuc does pecking tapping with G94 M29, with PITCH X RPM = FEED...
but on this machine I wanted to just use the pitch...
example below
(M7x1 XXXX TAPRH)
M29 S300
G98 G84 Z-10. R10. Q3. F1.
I find it way simpler because 90% of the jobs are in mellimeters.
Anyone please tell me what would be the proper way of doing this pecking tapping cycle?
thanks Similar Threads:
Re: peck tapping on Robodrill --- Fanuc
Add G95 before the M29 S300 command.
(M7x1 XXXX TAPRH)
G95
M29 S300
G80
G94
M30
Regards,
Heavy_Metal
Thanks Heavy_Metal
What I don't like about the G95 on this machine is, the single block works a little weird, it stops in every single cycle. It stops at every peck.
It got to be a parameter to change this...
Thanks and cheers to you!
Check your Parameter-Manual for Rigid Tapping.
For the 0i-D series par. 5200 and more.
Par. 5200 #6 (FHD)
FHD Feed hold and single block in rigid tapping:
0: Invalidated
1: Validated
Regards,
Heavy_Metal.
Forum Rules
