PartKam gcode won't run on grbl Candle
Results 1 to 2 of 2
Thread: PartKam gcode won't run on grbl Candle
    Member dlatch's Avatar
    Apr 2019
    Default PartKam gcode won't run on grbl Candle
    I used MakerCam to create gcode from an svg line drawing. The gcode displays and runs on the Candle simulator but, it gives errors at most of the G2/G3 instructions.
    It starts to run, goes to work origin and then to the staring point, the z goes down to a test height but then, it heads for machine home and hits the stops.
    Any suggestions as to why? The gcode has a comment line "created by PartKam"
    Its a small engraver using Woodpecker 3.2 and Candle .9
    Member machinehop5's Avatar
    Aug 2009
    Default Re: PartKam gcode won't run on grbl Candle
    G2 G3 Arc Centers.....incremental or absolute maybe set wrong
