Code issue with cutter going off
Results 1 to 7 of 7
Thread: Code issue with cutter going off
    Apr 2007
    Default Code issue with cutter going off
    Code issue with cutter going off-code-jpg
    Hello, Nube question here. Iam running UCCNC using a C76 - UC300ETH Multifunction Board and getting my GCode out of Fusion 360 using the Mach3 Postprocessor.
    Iam having an issue with the Cutter going to the machines Zero,cutting into the bed, at the beginning of the routine.
    Is there a setting in UCCNC or Fusion at makes it so the cutter stays at the part and doesnt go off to the machines Zero.
    Thanks,
    Dave
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Code issue with cutter going off
    Delete line # N25G28G91Z0
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by sierradays View Post
    Thanks,
    Dave
    Can you show post more of the program, do you home the machine and where have you set your Tool Zero point, you most likely have a combination of cad and machine setup problems
    Mactec54
    Jan 2005
    Quote Originally Posted by machinehop5 View Post
    He needs to fix the whole problem, to delete what you suggest would not fix the whole problem N25G28G91Z0 this should move his Z axes to Home which should be above the part
    Mactec54
    Aug 2009
    G54 Active also....what is store in there. Readout shows +164. mm...maybe forgot to use a (-) sign in Offset
    Apr 2007
    Here is the code.
    Let me know if this is enough.
    I have not homed the machine.
    I set the Zero paint at the top Left corner of the part.Code issue with cutter going off-spot2-jpg
    (1001)
    (T1 D=3 CR=1.5 TAPER=3deg - ZMIN=-15.2 - tapered mill)
    (T3 D=6.35 CR=0 - ZMIN=-5.691 - flat end mill)
    N10 G90 G94
    N15 G17
    N20 G21
    N25 G28 G91 Z0
    N30 G90
    (Adaptive2)
    N35 M9
    N40 T3 M6
    N45 T1
    N50 S15000 M3
    N55 G54
    N60 G0 X27.56 Y-42.195
    N65 G43 Z17.4 H3
    N70 Z7.4
    N75 Z2.6
    N80 G3 X33.412 Y-44.339 Z2.258 I2.926 J-1.072 F333.3
    N85 X27.56 Y-42.195 Z1.916 I-2.926 J1.072
    N90 X33.412 Y-44.339 Z1.574 I2.926 J-1.072
    N95 X27.56 Y-42.195 Z1.232 I-2.926 J1.072
    N100 X33.412 Y-44.339 Z0.89 I2.926 J-1.072
    N105 X27.56 Y-42.195 Z0.549 I-2.926 J1.072
    N110 X33.412 Y-44.339 Z0.207 I2.926 J-1.072
    N115 X27.56 Y-42.195 Z-0.135 I-2.926 J1.072
    N120 X33.412 Y-44.339 Z-0.477 I2.926 J-1.072
    N125 X27.56 Y-42.195 Z-0.819 I-2.926 J1.072
    N130 X33.412 Y-44.339 Z-1.161 I2.926 J-1.072
    N135 X33.603 Y-43.267 Z-1.199 I-2.926 J1.072
    N140 X27.37 I-3.116
    N145 X33.603 I3.116
    N150 G1 X33.647 Y-42.041 F1000
    N155 X33.729 Y-41.639
    N160 X33.758 Y-41.492
    N165 X33.773 Y-41.343
    N170 X33.775 Y-41.193
    N175 X33.764 Y-41.043
    N180 X33.743 Y-40.895
    N185 X33.711 Y-40.748
    N190 X33.67 Y-40.604
    N195 X33.62 Y-40.463
    N200 X33.561 Y-40.324
    N205 X33.495 Y-40.19
  7. #7
    Jan 2005
    Here is the code.
    (1001)
    N10 G90 G94
    N15 G17
    N20 G21
    N25 G28 G91 Z0
    N30 G90
    (Adaptive2)
    N35 M9
    N40 T3 M6
    N45 T1 This could be a problem you can only have ( 1 ) tool call you need to remove this
    N50 S15000 M3
    N55 G54
    N65 G43 Z17.4 H3
    N70 Z7.4
    N75 Z2.6
    N140 X27.37 I-3.116
    N145 X33.603 I3.116
    The first place it is going to move is this line here, it is going to rapid move there, this is not your work X0 Y0 point and look in G54 offset to see if there is any numbers set in there these will be X Y and Z you can leave at zero
    If you have homing set up you need to use it, once you home the machine you then set up you work X 0 Y0 this will be in the G54 work offset page in the control you then set you Z axes Cuter to the top of your part this will be in offsets G43
    Mactec54
