I wish to unload a work piece midway through a program and turn it over to route the other side. I need stop the vacuum and raise stops and panel lifter, then continue the program once reloaded with vac on stop and panel lifter down.
I have multiple processes processes going on both sides and by using 1 program I can ease usability and reduce human error.
If your running an old Masterwood, your best option would be to split the code with an 'IF' statement.
#100=0 (front=0, back=1)
IF #100=0
(insert front half of code)
IF #100=1
(insert back half of code)
You can switch the vacuum on/off manually, but I dont think you can engage stops or lifters while a program is running.
