Need Help! G Code CNC to Wood Router G Code
Results 1 to 6 of 6
Thread: G Code CNC to Wood Router G Code
    Mar 2018
    Exclamation G Code CNC to Wood Router G Code
    Help Please! I am very new into this world of CNC/G Code. We currently operate a flash cut table, that has a wood router attachment. I don't know enough about taking a G Code from our program, which we use for the plasma machine. When I try to copy the G-code, into the software for the wood router, I don't have the ability to set the depth or spindle speed etc. If anyone has any suggestions, or has used the Flash Cut software, I would greatly appreciate the help!
    Member routalot's Avatar
    Dec 2003
    Default Re: G Code CNC to Wood Router G Code
    Don't even think about firing up the machine until you know a bit more about the process-it could get expensive!
    Mar 2018
    I Understand G Code, its more the software itself I require assistance with. The files are DXF however when importing it into FlashCut Software for Routering, I am lost.
    Member he1957's Avatar
    Jun 2018
    Tasmania
    Tried calling the Flashcut Support folks?
    Dec 2003
    I don't know Flashcut.I do know a few other pieces of software and one of the obvious differences between plasma and router use is that you will need to define the tool and it's feed and speed parameters.Another is that you may need to specify cutting depth as the spindle may not have the power to cut all the way through the workpiece in one pass.Do you perhaps have a software module missing?
    Member awerby's Avatar
    Apr 2004
    A G-code program written for plasma-cutting is not going to work for routing. As you've noticed, the plasma G-code doesn't need to set spindle speed, and won't send the tool to the correct depths. You should get a CAM program and run the DXF through it to generate a G-code file that will do what you want - it should be able to cut out a part leaving the outside dimensions intact, instead of taking the radius of the tool out of the piece, as a program that just sent the tool down a linear path would, Make sure you choose a CAM program that has a Flashcut post-processor you can use to customize the output for your machine.
