What control are you using?
Hello!
I want to know if my G-code will work if instead of this:
G90;
G1 F9000 X220 Y215;
G1 F1000 X232;
G4 P700;
G1 F9000 X220
I write it like this:
G90; G1 F9000 X220 Y215; G1 F1000 X232; G4 P700; G1 F9000 X220;
The reason is because I want to use Cura plug-in to search and replace. So I will replace tons of lines for this single line, so I'll not be able to separate them.
Much appreciated!
UPDATED: Yes, it does work, I made a quick test. It also works if, after all the line of code, there's a lost number there, like:
G90; G1 F9000 X220 Y215; G1 F1000 X232; G4 P700; G1 F9000 X220;2
This is helpful since I can replace ";LAYER:" without referencing a single layer specifically.
UCCNC 2017 Screenset
I'm not sure how to answer, I'm using Cura software and using the Post-Processing plug-in to edit the G-code, where I'll use the "Search and Replace" tool and replace all ";LAYER:" by this line of code I just posted.
