1 1/2 internal npt thread
Results 1 to 5 of 5
Thread: 1 1/2 internal npt thread
    Pridefull's Avatar
    Nov 2018
    Default 1 1/2 internal npt thread
    Greetings
    Could someone please explain how to calculate values for npt thread and for preparation hole.
    I need to make 1 1/2 internal npt thread lenght of the thread would be 32 mm and i would like to start 5mm in front of the part.
    I am using a fanuc controler with 2 line g76 code
    Thanks in advance
    Registered metlshpr's Avatar
    Dec 2006
    Default Re: 1 1/2 internal npt thread
    1 1/2 internal npt thread-taper-pipe-thread-program-procedure-jpg
    WANNA GO FASTER
    Gold Member
    Feb 2006
    india
    In the second block of G76, R = L/32 where L is the total axial movement of the tool. Negative for external and positive for internal, in right-to-left machining.
    Pridefull's Avatar
    Nov 2018
    for lenghts i figured it out I'm having dificulties calculating major and minor diameter since there is so much limited information on the internet
    Dec 2006
    All info can be found in the machinist handbook for the major and minor sizes. The above attachment information was gathered from there.
    WANNA GO FASTER
