I do not think so.
G90 and G91 belong to the same G-code group, and only one code from a group remains active at any time.
You may, however, experiment and let us know the result: G90 G00 X_ Z_ G91 A_
I am cutting a constant pitch screw with varying root diameter with constant pitch on my mill using the 4th axis .
The screw has a major root diameter (.325") for 6 turns and then transitions to a minor diameter (.265 ") for 8 turns.
From there the screw is cut an additional 6 turn at the minor diameter.
Right now I am cutting in one direction from left to right .
After completing the pass I am raising the spindle up to a clearance height and then moving X and A back to there initial
starting position to the left..
A lot of time is wasted returning A axis back to 0,0 to start the next pass.
Right now every line is written in absolute mode.
Can I combine G90 and G91 on the same command line such that X and Z moves would be in absolute and
A moves would be in incremental ?
I do not think so.
hy johnd
is the rapid of the 4th axis really-really slow ? what is it's rapid speed ?A lot of time is wasted returning A axis back to 0,0 to start the next pass
repositioning movement is done in feed or in rapid ?
during threading, is the 4th axis used in positioning mode ( degrees / minute ), or like a spindle ( rpms / minute ) ?
if your code works in positioning mode ( degrees / minute ), then have you tried to "start" and "end" at same spindle phase ? so to eliminate the need to reposition the 4th axis between passes ?
it is possible to achive this somehow ( by using a soubroutine, etc ), but i don't believe that you really need this trickCan I combine G90 and G91 on the same command line such that X and Z moves would be in absolute and A moves would be in incremental ?
i hope that all those questions listed above will light a spark / kindly
we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
Hello sinha and mactec54,Originally Posted by mactec54
In the way you can combine Absolute and Incremental with a lathe control, (G00 X100.0 W-30.0) so are you able to do the same with a mill control using G90 and G91 in the same Command Block. The following example is quite legal and results in a combined Absolute move to X100.0 and an Incremental move of Y-10.0.
G00 G90 X100.0 G91 Y-10.0
One caution that should be observed is that on completion of the above example Block, the control will be in G91 (Incremental) Mode.
Regards,
Bill
hello angel
same (iso) code may perform differently, depending on control brandG00 G90 X100 G91 Y-10
each code line ( block , etc ) has different words inside it, and some controls may be sensitive to words order; in such a case, that code will work
a conflict may appear on controls that are not sensitive to words order, because there are at least 2 words that belong to the same family
such a code may be executed identicaly on both types of controlers, because G90 is "modal", while W is "one shot"G00 X100 W-30
kindly
I see you're still demonstrating your lack of knowledge.
G90/G91 are from the same G Code Group
Yet they can be combined in the same Block. The above are extracts from a Fanuc Manual, but Haas, Mazak, Yasnac and many other controls are the same. It is, however, not allowed to program G90/G91 in the same Block with an Okuma control.
because the controller is sensitive to words orderYet they can be combined in the same Block. Haas, Mazak, Yasnac and most controls are the same
because the controller is not sensitive to words order, at least for g-codesIt is, however, not allowed to program G90/G91 in the same Block with an Okuma control
please, will you share the full list of those G groups ? kindly
