The machine reads the G41 line, makes a linear move to that point then stops.
However, if I set the tool diameter for D3 in the register to 0, then it will execute the entire program.
Is there anything wrong with this code?
After this, I will need to figure out how to interpolate in the G19 plane with cutter comp. I'm just starting with something simple just to understand all the basics.
Any help will be much appreciated! We are looking at buying a right angle head for the fadal in order to do some horizontal thread milling on 24 inch long plates.
your nc example is missing the remaining lines.
... normally.. most nc controls look ahead when using cutter comp, so to calculate the continuing adjusted path.
try posting the full nc code up to the G40. so we can give a better diagnosis.
What is the center coordinate when the tool stops?
Does it alarm out also?
What is tool radius?
Does it work with G42?
Replace G0 x0 y0 Z0 by G00 X1 Y-1 Z0. Does it work ?
