How to export a 3d path as GCode - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 28 of 28
Thread: How to export a 3d path as GCode
  1. #25
    Gold Member Jim Dawson's Avatar
    Dec 2013
    Default Re: How to export a 3d path as GCode
    Quote Originally Posted by ZeroBacklash View Post
    That sounds interesting probably I can test it out today.
    That would need a G code library wouldn't it?
    No, the motion controller has no idea what to do with G code. The G code needs to be translated into a command string that the motion controller can understand. This is normally done in the CNC program. In the case of Mach3, it is a motion controller, but it still has to convert the G code into step & direction commands to drive the axis motors. Motion controllers understand pulses (for positioning), pulses/second (for speed), and pulses/second^2 (for acceleration).
    So a G1 X1.00 Y1.00 F10 would be translated to what the motion controller can read, maybe something like LI100,100<1000>1000 So rather than make the translation, just output the native machine code directly.
    Jim Dawson
    Sandy, Oregon, USA
  2. #26
    Mar 2012
    UK
    Quote Originally Posted by Jim Dawson View Post
    What you are trying to suggest is output the step / dir pulses directly from software instead of first converting it to g code right? That's an amazing idea. The issue I face here is how best to co-ordinate all the axis together, will a simple state machine do the job here.
    GRBL and other such controller's do a good job of getting co-ordinated motion from multiple axis, but I like what you say and it seems doable.
    Will a plugin for Mach3 do the job here I mean insead of feeding Mach3 gcode we can directly tell it to output the desired step/dir pulses.
    Are there any existing libraries out there that do this kind of thing that is bypass intepreting G code and output step/dir signals on parallel port or in theses days on the USB port?
  3. #27
    Dec 2013
    If you want to use Mach3 or similar, then you will probably have to create G code that your chosen CNC software and/or plug-in will understand. I don't know enough about Mach3 and other similar platforms to know what is possible with them and how you can manipulate them. I normally work with more industrial motion systems, but I'm pretty sure that Arduino or something similar could be programed to do what you want. What I am suggesting is really much like CAD/CAM/CNC all wrapped up in one package.
    As an example, winding an electrical coil on a form is much easier to describe textually than trying to draw it in CAD and then going through the process of trying to generate a ''toolpath'' from that. An electrical coil is easy to describe by number of turns, width, wire size, ect. Winding carbon fiber on a tube is similar and can be described with a few more parameters. The textual description can be easily converted to motion commands that the motion controller can understand.
    Jim Dawson
    Sandy, Oregon, USA
  4. #28
    May 2006
    Your task is not impossible
    Generating the path is no problem converting is.
    Check out Tow Placement or Automated fiber placement.
    I had a Phd in math and computer science do the postprocessor from C/L x,y,z,i,j,k,f data to 7axis motion 0, 90, +45, -45 with cuts and adds
    Just like rolling paint.....................
    Attached Thumbnails Attached Thumbnails How to export a 3d path as GCode-s-running-robot-c-jpg
    Been doing this too long
