hi / there is a yellow button on some okuma panels, that allows to perform a specific code when the slide-hold is pressed ( for example right in the middle of a G01 you may send one axis at the +limit and stop after that ); real application example : on request interruption durring hobbing ( sincro SM )
making this action auto-occure, like when a "tool broked" or when the "emergency button is pressed" requires only a mere mortal with 2-3 extra skills and a golden egg
perhaps haidenhain has something similar ?
sometimes i use the " / block skip " to move the tool at a safe position : so i can not trigger this behaviour right in the middle of a cutting movement, but only before or after it occured ( is ok when machining common parts )
common behaviour to interrupt a feed movement is by using the "slide hold " button : but it is triggered by an operator, and once pressed, it simply freezes the cnc ( at least the linear axis ), but i guess you know that / kindly
