Need Help! Chamfer on a cyclinder
Results 1 to 9 of 9
Thread: Chamfer on a cyclinder
    Default Chamfer on a cyclinder
    Hi guys has anybody got a simple program to put a 2mm chamfer all around a 29 mm hole on a 75 mm diameter bar I’m struggling to do this on a doosan dam 400 fanuc machine Centre control any help would be much appreciated thanks
    Using Tapatalk
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    Default Re: Chamfer on a cyclinder
    hi pls share :
    ... your tool diameter ( oA in attached )
    ... diameter that cuts the middle of the chamfer, or the neutral fiber if you wish ( oB in attached )
    ...... if you wish, you may consider oB = oA / 2
    i need those values, because the code does not use radius comp
    pls share also desired toolpath segmentation ( suggested values : 0.075, 0.100, 0.125, 0.175, 0.250, 1 / 3 ); multiple choices available
    code requires XCZ; ( passive X + syncro CZ )
    i won't share the feed calculation, because i don't know how the controller calculates CZ simultaneous cutting / kindly
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
    Quote Originally Posted by deadlykitten View Post
    hi pls share :
    Hi it will be a 20 mm diameter 45degree tool thanks for you help
    Using Tapatalk
    Jan 2009
    Need more machine info.
    Lathe/Mill
    If lathe does it have a Y axis
    If Mill are you using a rotary
    Control model
    Could not find that model online
    Sorry yes it’s a doosan dnm400 vertical machine Centre with fanuc oi control and I need to do it in a stationary vice no 4th axis thanks
    Using Tapatalk
    Jun 2015
    Antarctica
    // now i have seen that you need the code for a mill; this code is for a lathe ... i will post soon another one, for a 3axis mill
    hi this code works for oB=10 ( half of your tool ), so it describes a o19 circle on the tool center
    o19+oB=o29 ( desired hole )
    it works on okuma controller; i can not deliver it for a doosan, but at least there are the coordinates
    i did not cut into material, i only cut air ... it should work kindly
    Code:
    OS08
        NGHOST G305
        IF [ VRSTT NE 0 ] NEND
        NOEX V1  = 2233       ( n )
        NOEX V2  = 3*0.025    ( f )
      ( CALL OCHK? LV01=LINK LV02=-50 LV03=0.5 LV04=? LV05=0.5 )
        G304
        CALL ODYNX LPOS=78 LCTR=2 LDS=0
        SB=V1 M13 M08 G00 X78 Z9.5-5 C0 M63 G95
        G00 X75
        G01     Z9.5   F+V2
        CALL OQ08B
        G01     Z9.5-5 F+V2
        G00 X78
        M12
        M0
        NEND NOEX
    RTS ( . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . )
    OQ08A ( o19 eps0.150 v1 )
        C+005.180 Z+008.876 F+002.095 * V2 M15 ( alfa = 020.880 )
        C+007.330 Z+008.207 F+001.964 * V2 M15 ( alfa = 030.240 )
        C+009.005 Z+007.470 F+001.847 * V2 M15 ( alfa = 038.160 )
        C+010.385 Z+006.675 F+001.725 * V2 M15 ( alfa = 045.360 )
        C+011.490 Z+005.870 F+001.601 * V2 M15 ( alfa = 051.840 )
        C+012.642 Z+004.784 F+001.463 * V2 M15 ( alfa = 059.760 )
        C+013.624 Z+003.497 F+001.303 * V2 M15 ( alfa = 068.400 )
        C+014.557 Z+001.191 F+001.109 * V2 M15 ( alfa = 082.800 )
        C+013.883 Z-003.049 F+001.019 * V2 M16 ( alfa = 108.720 )
        C+012.826 Z-004.577 F+001.263 * V2 M16 ( alfa = 118.800 )
        C+011.827 Z-005.584 F+001.428 * V2 M16 ( alfa = 126.000 )
        C+010.642 Z-006.503 F+001.567 * V2 M16 ( alfa = 133.200 )
        C+009.293 Z-007.320 F+001.699 * V2 M16 ( alfa = 140.400 )
        C+007.646 Z-008.084 F+001.825 * V2 M16 ( alfa = 148.320 )
        C+005.858 Z-008.695 F+001.937 * V2 M16 ( alfa = 156.240 )
        C+002.721 Z-009.332 F+002.048 * V2 M16 ( alfa = 169.200 )
        C-004.316 Z-009.071 F+002.119 * V2 M16 ( alfa = 197.280 )
        C-006.686 Z-008.437 F+002.000 * V2 M16 ( alfa = 207.360 )
        C-008.414 Z-007.755 F+001.889 * V2 M16 ( alfa = 215.280 )
        C-009.987 Z-006.925 F+001.767 * V2 M16 ( alfa = 223.200 )
        C-011.137 Z-006.147 F+001.641 * V2 M16 ( alfa = 229.680 )
        C-012.250 Z-005.191 F+001.512 * V2 M16 ( alfa = 236.880 )
        C-013.330 Z-003.937 F+001.358 * V2 M16 ( alfa = 245.520 )
        C-014.250 Z-002.247 F+001.181 * V2 M16 ( alfa = 256.320 )
        C-014.156 Z+002.478 F+001.000 * V2 M15 ( alfa = 285.120 )
        C-013.170 Z+004.153 F+001.205 * V2 M15 ( alfa = 295.920 )
        C-012.147 Z+005.290 F+001.379 * V2 M15 ( alfa = 303.840 )
        C-011.016 Z+006.238 F+001.526 * V2 M15 ( alfa = 311.040 )
        C-009.714 Z+007.086 F+001.661 * V2 M15 ( alfa = 318.240 )
        C-008.262 Z+007.824 F+001.785 * V2 M15 ( alfa = 325.440 )
        C-006.522 Z+008.491 F+001.899 * V2 M15 ( alfa = 333.360 )
        C-003.965 Z+009.139 F+002.012 * V2 M15 ( alfa = 344.160 )
        C+003.257 Z+009.258 F+002.122 * V2 M15 ( alfa = 012.960 )
    OQ08B ( o19 eps0.075 v1 )
        C+003.789 Z+009.171 F+002.108 * V2 M15 ( alfa = 015.120 )
        C+005.180 Z+008.876 F+002.042 * V2 M15 ( alfa = 020.880 )
        C+006.358 Z+008.544 F+001.989 * V2 M15 ( alfa = 025.920 )
        C+007.330 Z+008.207 F+001.933 * V2 M15 ( alfa = 030.240 )
        C+008.110 Z+007.891 F+001.879 * V2 M15 ( alfa = 033.840 )
        C+009.005 Z+007.470 F+001.819 * V2 M15 ( alfa = 038.160 )
        C+009.714 Z+007.086 F+001.755 * V2 M15 ( alfa = 041.760 )
        C+010.385 Z+006.675 F+001.693 * V2 M15 ( alfa = 045.360 )
        C+010.893 Z+006.327 F+001.635 * V2 M15 ( alfa = 048.240 )
        C+011.490 Z+005.870 F+001.574 * V2 M15 ( alfa = 051.840 )
        C+012.042 Z+005.389 F+001.505 * V2 M15 ( alfa = 055.440 )
        C+012.642 Z+004.784 F+001.428 * V2 M15 ( alfa = 059.760 )
        C+013.170 Z+004.153 F+001.344 * V2 M15 ( alfa = 064.080 )
        C+013.624 Z+003.497 F+001.263 * V2 M15 ( alfa = 068.400 )
        C+014.106 Z+002.593 F+001.175 * V2 M15 ( alfa = 074.160 )
        C+014.557 Z+001.191 F+001.072 * V2 M15 ( alfa = 082.800 )
        C+014.334 Z-002.014 F+001.004 * V2 M16 ( alfa = 102.240 )
        C+013.883 Z-003.049 F+001.124 * V2 M16 ( alfa = 108.720 )
        C+013.330 Z-003.937 F+001.224 * V2 M16 ( alfa = 114.480 )
        C+012.826 Z-004.577 F+001.317 * V2 M16 ( alfa = 118.800 )
        C+012.351 Z-005.090 F+001.393 * V2 M16 ( alfa = 122.400 )
        C+011.827 Z-005.584 F+001.463 * V2 M16 ( alfa = 126.000 )
        C+011.256 Z-006.056 F+001.533 * V2 M16 ( alfa = 129.600 )
        C+010.642 Z-006.503 F+001.601 * V2 M16 ( alfa = 133.200 )
        C+009.987 Z-006.925 F+001.667 * V2 M16 ( alfa = 136.800 )
        C+009.293 Z-007.320 F+001.731 * V2 M16 ( alfa = 140.400 )
        C+008.564 Z-007.686 F+001.791 * V2 M16 ( alfa = 144.000 )
        C+007.646 Z-008.084 F+001.853 * V2 M16 ( alfa = 148.320 )
        C+006.849 Z-008.382 F+001.909 * V2 M16 ( alfa = 151.920 )
        C+005.858 Z-008.695 F+001.960 * V2 M16 ( alfa = 156.240 )
        C+004.490 Z-009.035 F+002.015 * V2 M16 ( alfa = 162.000 )
        C+002.721 Z-009.332 F+002.071 * V2 M16 ( alfa = 169.200 )
        C-002.361 Z-009.374 F+002.122 * V2 M16 ( alfa = 189.360 )
        C-004.316 Z-009.071 F+002.078 * V2 M16 ( alfa = 197.280 )
        C-005.690 Z-008.742 F+002.022 * V2 M16 ( alfa = 203.040 )
        C-006.686 Z-008.437 F+001.968 * V2 M16 ( alfa = 207.360 )
        C-007.646 Z-008.084 F+001.914 * V2 M16 ( alfa = 211.680 )
        C-008.414 Z-007.755 F+001.858 * V2 M16 ( alfa = 215.280 )
        C-009.293 Z-007.320 F+001.797 * V2 M16 ( alfa = 219.600 )
        C-009.987 Z-006.925 F+001.731 * V2 M16 ( alfa = 223.200 )
        C-010.514 Z-006.590 F+001.674 * V2 M16 ( alfa = 226.080 )
        C-011.137 Z-006.147 F+001.615 * V2 M16 ( alfa = 229.680 )
        C-011.716 Z-005.680 F+001.547 * V2 M16 ( alfa = 233.280 )
        C-012.250 Z-005.191 F+001.477 * V2 M16 ( alfa = 236.880 )
        C-012.826 Z-004.577 F+001.400 * V2 M16 ( alfa = 241.200 )
        C-013.330 Z-003.937 F+001.317 * V2 M16 ( alfa = 245.520 )
        C-013.821 Z-003.162 F+001.231 * V2 M16 ( alfa = 250.560 )
        C-014.250 Z-002.247 F+001.141 * V2 M16 ( alfa = 256.320 )
        C-014.632 Z+000.716 F+001.012 * V2 M16 ( alfa = 274.320 )
        C-014.156 Z+002.478 F+001.052 * V2 M15 ( alfa = 285.120 )
        C-013.692 Z+003.386 F+001.163 * V2 M15 ( alfa = 290.880 )
        C-013.170 Z+004.153 F+001.257 * V2 M15 ( alfa = 295.920 )
        C-012.642 Z+004.784 F+001.344 * V2 M15 ( alfa = 300.240 )
        C-012.147 Z+005.290 F+001.421 * V2 M15 ( alfa = 303.840 )
        C-011.604 Z+005.775 F+001.491 * V2 M15 ( alfa = 307.440 )
        C-011.016 Z+006.238 F+001.560 * V2 M15 ( alfa = 311.040 )
        C-010.385 Z+006.675 F+001.628 * V2 M15 ( alfa = 314.640 )
        C-009.714 Z+007.086 F+001.693 * V2 M15 ( alfa = 318.240 )
        C-009.005 Z+007.470 F+001.755 * V2 M15 ( alfa = 321.840 )
        C-008.262 Z+007.824 F+001.814 * V2 M15 ( alfa = 325.440 )
        C-007.330 Z+008.207 F+001.874 * V2 M15 ( alfa = 329.760 )
        C-006.522 Z+008.491 F+001.928 * V2 M15 ( alfa = 333.360 )
        C-005.351 Z+008.833 F+001.981 * V2 M15 ( alfa = 338.400 )
        C-003.965 Z+009.139 F+002.036 * V2 M15 ( alfa = 344.160 )
        C-001.638 Z+009.439 F+002.091 * V2 M15 ( alfa = 353.520 )
        C+003.257 Z+009.258 F+002.119 * V2 M15 ( alfa = 012.960 )
  7. #7
    Jan 2009
    is the control in metric?
    Part aligned with x?
    position X or Y of hole?
  8. #8
    Jan 2009
    This is for part aligned in X, Hole at X0, Z0 at top of part, Metric
    N1T1M06
    G90G54G00X0Y0S6000M03
    G43Z2.H01M08
    G01Z-5.0F?(input feed)
    G03X11.5Y0I5.75J0F?(input feed)
    G01X11.484Y0.602Z-5.01
    X11.437Y1.202Z-5.04
    X11.358Y1.799Z-5.089
    X11.249Y2.391Z-5.157
    X11.108Y2.976Z-5.244
    X10.937Y3.554Z-5.348
    X10.736Y4.121Z-5.469
    X10.506Y4.677Z-5.605
    X10.247Y5.221Z-5.756
    X9.959Y5.75Z-5.919
    X9.645Y6.263Z-6.093
    X9.304Y6.76Z-6.276
    X8.937Y7.237Z-6.466
    X8.546Y7.695Z-6.662
    X8.132Y8.132Z-6.861
    X7.695Y8.546Z-7.061
    X7.237Y8.937Z-7.26
    X6.76Y9.304Z-7.456
    X6.263Y9.645Z-7.647
    X5.75Y9.959Z-7.829
    X5.221Y10.247Z-8.002
    X4.677Y10.506Z-8.163
    X4.121Y10.736Z-8.31
    X3.554Y10.937Z-8.441
    X2.976Y11.108Z-8.555
    X2.391Y11.249Z-8.651
    X1.799Y11.358Z-8.726
    X1.202Y11.437Z-8.781
    X0.602Y11.484Z-8.814
    X0Y11.5Z-8.825
    X-0.602Y11.484Z-8.814
    X-1.202Y11.437Z-8.781
    X-1.799Y11.358Z-8.726
    X-2.391Y11.249Z-8.651
    X-2.976Y11.108Z-8.555
    X-3.554Y10.937Z-8.441
    X-4.121Y10.736Z-8.31
    X-4.677Y10.506Z-8.163
    X-5.221Y10.247Z-8.002
    X-5.75Y9.959Z-7.829
    X-6.263Y9.645Z-7.647
    X-6.76Y9.304Z-7.456
    X-7.237Y8.937Z-7.26
    X-7.695Y8.546Z-7.061
    X-8.132Y8.132Z-6.861
    X-8.546Y7.695Z-6.662
    X-8.937Y7.237Z-6.466
    X-9.304Y6.76Z-6.276
    X-9.645Y6.263Z-6.093
    X-9.959Y5.75Z-5.919
    X-10.247Y5.221Z-5.756
    X-10.506Y4.677Z-5.605
    X-10.736Y4.121Z-5.469
    X-10.937Y3.554Z-5.348
    X-11.108Y2.976Z-5.244
    X-11.249Y2.391Z-5.157
    X-11.358Y1.799Z-5.089
    X-11.437Y1.202Z-5.04
    X-11.484Y0.602Z-5.01
    X-11.5Y0Z-5.0
    X-11.484Y-0.602Z-5.01
    X-11.437Y-1.202Z-5.04
    X-11.358Y-1.799Z-5.089
    X-11.249Y-2.391Z-5.157
    X-11.108Y-2.976Z-5.244
    X-10.937Y-3.554Z-5.348
    X-10.736Y-4.121Z-5.469
    X-10.506Y-4.677Z-5.605
    X-10.247Y-5.221Z-5.756
    X-9.959Y-5.75Z-5.919
    X-9.645Y-6.263Z-6.093
    X-9.304Y-6.76Z-6.276
    X-8.937Y-7.237Z-6.466
    X-8.546Y-7.695Z-6.662
    X-8.132Y-8.132Z-6.861
    X-7.695Y-8.546Z-7.061
    X-7.237Y-8.937Z-7.26
    X-6.76Y-9.304Z-7.456
    X-6.263Y-9.645Z-7.647
    X-5.75Y-9.959Z-7.829
    X-5.221Y-10.247Z-8.002
    X-4.677Y-10.506Z-8.163
    X-4.121Y-10.736Z-8.31
    X-3.554Y-10.937Z-8.441
    X-2.976Y-11.108Z-8.555
    X-2.391Y-11.249Z-8.651
    X-1.799Y-11.358Z-8.726
    X-1.202Y-11.437Z-8.781
    X-0.602Y-11.484Z-8.814
    X0Y-11.5Z-8.825
    X0.602Y-11.484Z-8.814
    X1.202Y-11.437Z-8.781
    X1.799Y-11.358Z-8.726
    X2.391Y-11.249Z-8.651
    X2.976Y-11.108Z-8.555
    X3.554Y-10.937Z-8.441
    X4.121Y-10.736Z-8.31
    X4.677Y-10.506Z-8.163
    X5.221Y-10.247Z-8.002
    X5.75Y-9.959Z-7.829
    X6.263Y-9.645Z-7.647
    X6.76Y-9.304Z-7.456
    X7.237Y-8.937Z-7.26
    X7.695Y-8.546Z-7.061
    X8.132Y-8.132Z-6.861
    X8.546Y-7.695Z-6.662
    X8.937Y-7.237Z-6.466
    X9.304Y-6.76Z-6.276
    X9.645Y-6.263Z-6.093
    X9.959Y-5.75Z-5.919
    X10.247Y-5.221Z-5.756
    X10.506Y-4.677Z-5.605
    X10.736Y-4.121Z-5.469
    X10.937Y-3.554Z-5.348
    X11.108Y-2.976Z-5.244
    X11.249Y-2.391Z-5.157
    X11.358Y-1.799Z-5.089
    X11.437Y-1.202Z-5.04
    X11.484Y-0.602Z-5.01
    X11.5Y0Z-5.0
    G03X0Y0I-5.75J0
    G0Z2.0
    G91G28Z0M19
    M01
    M30
  9. #9
    That makes more sense how did you do that I will try this ????
    Using Tapatalk
  10. #10
    Is that without cutter comp?
    Using Tapatalk
  11. #11
    Jan 2009
    no cutter comp
  12. #12
    Jun 2015
    Antarctica
    hi there are 2 codes in this post
    1st code cuts the o29 chamfer with the tool at o10, thus it describes a "circle" with dia = 19
    it contains 2 soubroutines, from which you may get the coordinates: the 2nd one has a higher resolution and a better discretization algorithm, but also 1st one should deliver
    it had been tested on an Y lathe ( i only cut air ); for the mill, just replace " X with Z " and viceversa
    program origin is at the intersection of the "cilinder axis" and the " bore axis "
    there is the V3 parameter, which acts like a scale factor : this allows to obtain some kind of a comp behaviour; for example, the code is created to cut at o10=o20/2=tool_dia/2; if you wish to cut at tool_dia=o12, you should input V3 = 12 / 10
    pls be carefull, because using V3 will output a proportional ( scaled ) toolpath only among xy ( if you wish to scale also z, just put V3 also there ); in reality, if a huge compensation is required, than real result may not be ok, because required shape is not proportional; so V3 should work just fine for something like 5 - 10 - 30% compensation, but deviations will increase if higher values are used
    2nd code has a parametric structure which allows to obtain the "comp behaviour" and also to change the resolution of the toolpath; as a benefit, trials time is signifiantly reduced, because code iterations can be created fast, only by editing the program ( more free time, life is short, etc )
    ... if you transit it to the doosan, it will be a pretty versatile tool kindly
    Code:
    OS09
        NGHOST G305
        NOEX V3  = 1          ( scale factor )
        G304
        SB=V1 M13 M08 G00 X78 Z[9.5-5]*V3 C0 M63 F+V2 G95
        G00 X75 M147
        NOEX V4 = VDIN [ 1000 ]
        G01     Z9.5    *V3
        G138
        CALL OQ09B
        G136
        G01     Z[9.5-5]*V3
        G00 X78
        NOEX V4 = VDIN [ 1000 ] - V4
        M12 M146
        M0
        NEND NOEX
    OQ09A ( o19 eps0.075 v4 )
        X-000.082 + 075.000 / 2 Y+002.478 * V3 Z+009.171 * V3 ( alfa = 015.120 )
        X-000.153 + 075.000 / 2 Y+003.386 * V3 Z+008.876 * V3 ( alfa = 020.880 )
        X-000.231 + 075.000 / 2 Y+004.153 * V3 Z+008.544 * V3 ( alfa = 025.920 )
        X-000.306 + 075.000 / 2 Y+004.784 * V3 Z+008.207 * V3 ( alfa = 030.240 )
        X-000.375 + 075.000 / 2 Y+005.290 * V3 Z+007.891 * V3 ( alfa = 033.840 )
        X-000.462 + 075.000 / 2 Y+005.870 * V3 Z+007.470 * V3 ( alfa = 038.160 )
        X-000.538 + 075.000 / 2 Y+006.327 * V3 Z+007.086 * V3 ( alfa = 041.760 )
        X-000.614 + 075.000 / 2 Y+006.760 * V3 Z+006.675 * V3 ( alfa = 045.360 )
        X-000.676 + 075.000 / 2 Y+007.086 * V3 Z+006.327 * V3 ( alfa = 048.240 )
        X-000.751 + 075.000 / 2 Y+007.470 * V3 Z+005.870 * V3 ( alfa = 051.840 )
        X-000.825 + 075.000 / 2 Y+007.824 * V3 Z+005.389 * V3 ( alfa = 055.440 )
        X-000.909 + 075.000 / 2 Y+008.207 * V3 Z+004.784 * V3 ( alfa = 059.760 )
        X-000.986 + 075.000 / 2 Y+008.544 * V3 Z+004.153 * V3 ( alfa = 064.080 )
        X-001.055 + 075.000 / 2 Y+008.833 * V3 Z+003.497 * V3 ( alfa = 068.400 )
        X-001.131 + 075.000 / 2 Y+009.139 * V3 Z+002.593 * V3 ( alfa = 074.160 )
        X-001.204 + 075.000 / 2 Y+009.425 * V3 Z+001.191 * V3 ( alfa = 082.800 )
        X-001.167 + 075.000 / 2 Y+009.284 * V3 Z-002.014 * V3 ( alfa = 102.240 )
        X-001.095 + 075.000 / 2 Y+008.997 * V3 Z-003.049 * V3 ( alfa = 108.720 )
        X-001.010 + 075.000 / 2 Y+008.646 * V3 Z-003.937 * V3 ( alfa = 114.480 )
        X-000.936 + 075.000 / 2 Y+008.325 * V3 Z-004.577 * V3 ( alfa = 118.800 )
        X-000.868 + 075.000 / 2 Y+008.021 * V3 Z-005.090 * V3 ( alfa = 122.400 )
        X-000.796 + 075.000 / 2 Y+007.686 * V3 Z-005.584 * V3 ( alfa = 126.000 )
        X-000.721 + 075.000 / 2 Y+007.320 * V3 Z-006.056 * V3 ( alfa = 129.600 )
        X-000.645 + 075.000 / 2 Y+006.925 * V3 Z-006.503 * V3 ( alfa = 133.200 )
        X-000.568 + 075.000 / 2 Y+006.503 * V3 Z-006.925 * V3 ( alfa = 136.800 )
        X-000.492 + 075.000 / 2 Y+006.056 * V3 Z-007.320 * V3 ( alfa = 140.400 )
        X-000.418 + 075.000 / 2 Y+005.584 * V3 Z-007.686 * V3 ( alfa = 144.000 )
        X-000.333 + 075.000 / 2 Y+004.989 * V3 Z-008.084 * V3 ( alfa = 148.320 )
        X-000.268 + 075.000 / 2 Y+004.472 * V3 Z-008.382 * V3 ( alfa = 151.920 )
        X-000.196 + 075.000 / 2 Y+003.828 * V3 Z-008.695 * V3 ( alfa = 156.240 )
        X-000.115 + 075.000 / 2 Y+002.936 * V3 Z-009.035 * V3 ( alfa = 162.000 )
        X-000.042 + 075.000 / 2 Y+001.780 * V3 Z-009.332 * V3 ( alfa = 169.200 )
        X-000.032 + 075.000 / 2 Y-001.545 * V3 Z-009.374 * V3 ( alfa = 189.360 )
        X-000.106 + 075.000 / 2 Y-002.822 * V3 Z-009.071 * V3 ( alfa = 197.280 )
        X-000.185 + 075.000 / 2 Y-003.718 * V3 Z-008.742 * V3 ( alfa = 203.040 )
        X-000.255 + 075.000 / 2 Y-004.366 * V3 Z-008.437 * V3 ( alfa = 207.360 )
        X-000.333 + 075.000 / 2 Y-004.989 * V3 Z-008.084 * V3 ( alfa = 211.680 )
        X-000.404 + 075.000 / 2 Y-005.487 * V3 Z-007.755 * V3 ( alfa = 215.280 )
        X-000.492 + 075.000 / 2 Y-006.056 * V3 Z-007.320 * V3 ( alfa = 219.600 )
        X-000.568 + 075.000 / 2 Y-006.503 * V3 Z-006.925 * V3 ( alfa = 223.200 )
        X-000.630 + 075.000 / 2 Y-006.843 * V3 Z-006.590 * V3 ( alfa = 226.080 )
        X-000.706 + 075.000 / 2 Y-007.243 * V3 Z-006.147 * V3 ( alfa = 229.680 )
        X-000.781 + 075.000 / 2 Y-007.615 * V3 Z-005.680 * V3 ( alfa = 233.280 )
        X-000.854 + 075.000 / 2 Y-007.957 * V3 Z-005.191 * V3 ( alfa = 236.880 )
        X-000.936 + 075.000 / 2 Y-008.325 * V3 Z-004.577 * V3 ( alfa = 241.200 )
        X-001.010 + 075.000 / 2 Y-008.646 * V3 Z-003.937 * V3 ( alfa = 245.520 )
        X-001.086 + 075.000 / 2 Y-008.958 * V3 Z-003.162 * V3 ( alfa = 250.560 )
        X-001.154 + 075.000 / 2 Y-009.231 * V3 Z-002.247 * V3 ( alfa = 256.320 )
        X-001.216 + 075.000 / 2 Y-009.473 * V3 Z+000.716 * V3 ( alfa = 274.320 )
        X-001.139 + 075.000 / 2 Y-009.171 * V3 Z+002.478 * V3 ( alfa = 285.120 )
        X-001.066 + 075.000 / 2 Y-008.876 * V3 Z+003.386 * V3 ( alfa = 290.880 )
        X-000.986 + 075.000 / 2 Y-008.544 * V3 Z+004.153 * V3 ( alfa = 295.920 )
        X-000.909 + 075.000 / 2 Y-008.207 * V3 Z+004.784 * V3 ( alfa = 300.240 )
        X-000.840 + 075.000 / 2 Y-007.891 * V3 Z+005.290 * V3 ( alfa = 303.840 )
        X-000.766 + 075.000 / 2 Y-007.543 * V3 Z+005.775 * V3 ( alfa = 307.440 )
        X-000.691 + 075.000 / 2 Y-007.165 * V3 Z+006.238 * V3 ( alfa = 311.040 )
        X-000.614 + 075.000 / 2 Y-006.760 * V3 Z+006.675 * V3 ( alfa = 314.640 )
        X-000.538 + 075.000 / 2 Y-006.327 * V3 Z+007.086 * V3 ( alfa = 318.240 )
        X-000.462 + 075.000 / 2 Y-005.870 * V3 Z+007.470 * V3 ( alfa = 321.840 )
        X-000.389 + 075.000 / 2 Y-005.389 * V3 Z+007.824 * V3 ( alfa = 325.440 )
        X-000.306 + 075.000 / 2 Y-004.784 * V3 Z+008.207 * V3 ( alfa = 329.760 )
        X-000.243 + 075.000 / 2 Y-004.260 * V3 Z+008.491 * V3 ( alfa = 333.360 )
        X-000.163 + 075.000 / 2 Y-003.497 * V3 Z+008.833 * V3 ( alfa = 338.400 )
        X-000.090 + 075.000 / 2 Y-002.593 * V3 Z+009.139 * V3 ( alfa = 344.160 )
        X-000.015 + 075.000 / 2 Y-001.072 * V3 Z+009.439 * V3 ( alfa = 353.520 )
        X-000.061 + 075.000 / 2 Y+002.131 * V3 Z+009.258 * V3 ( alfa = 012.960 )
    OQ09B ( o19 eps0.075 v5 )
        X-000.002 + 075.000 / 2 Y+000.358 * V3 Z+009.493 * V3 ( alfa = 002.160 )
        X-000.007 + 075.000 / 2 Y+000.716 * V3 Z+009.473 * V3 ( alfa = 004.320 )
        X-000.015 + 075.000 / 2 Y+001.072 * V3 Z+009.439 * V3 ( alfa = 006.480 )
        X-000.027 + 075.000 / 2 Y+001.427 * V3 Z+009.392 * V3 ( alfa = 008.640 )
        X-000.037 + 075.000 / 2 Y+001.663 * V3 Z+009.353 * V3 ( alfa = 010.080 )
        X-000.054 + 075.000 / 2 Y+002.014 * V3 Z+009.284 * V3 ( alfa = 012.240 )
        X-000.074 + 075.000 / 2 Y+002.363 * V3 Z+009.202 * V3 ( alfa = 014.400 )
        X-000.098 + 075.000 / 2 Y+002.708 * V3 Z+009.106 * V3 ( alfa = 016.560 )
        X-000.124 + 075.000 / 2 Y+003.049 * V3 Z+008.997 * V3 ( alfa = 018.720 )
        X-000.143 + 075.000 / 2 Y+003.274 * V3 Z+008.918 * V3 ( alfa = 020.160 )
        X-000.174 + 075.000 / 2 Y+003.608 * V3 Z+008.788 * V3 ( alfa = 022.320 )
        X-000.207 + 075.000 / 2 Y+003.937 * V3 Z+008.646 * V3 ( alfa = 024.480 )
        X-000.243 + 075.000 / 2 Y+004.260 * V3 Z+008.491 * V3 ( alfa = 026.640 )
        X-000.268 + 075.000 / 2 Y+004.472 * V3 Z+008.382 * V3 ( alfa = 028.080 )
        X-000.347 + 075.000 / 2 Y+005.090 * V3 Z+008.021 * V3 ( alfa = 032.400 )
        X-000.389 + 075.000 / 2 Y+005.389 * V3 Z+007.824 * V3 ( alfa = 034.560 )
        X-000.433 + 075.000 / 2 Y+005.680 * V3 Z+007.615 * V3 ( alfa = 036.720 )
        X-000.507 + 075.000 / 2 Y+006.147 * V3 Z+007.243 * V3 ( alfa = 040.320 )
        X-000.553 + 075.000 / 2 Y+006.416 * V3 Z+007.006 * V3 ( alfa = 042.480 )
        X-000.599 + 075.000 / 2 Y+006.675 * V3 Z+006.760 * V3 ( alfa = 044.640 )
        X-000.630 + 075.000 / 2 Y+006.843 * V3 Z+006.590 * V3 ( alfa = 046.080 )
        X-000.721 + 075.000 / 2 Y+007.320 * V3 Z+006.056 * V3 ( alfa = 050.400 )
        X-000.766 + 075.000 / 2 Y+007.543 * V3 Z+005.775 * V3 ( alfa = 052.560 )
        X-000.796 + 075.000 / 2 Y+007.686 * V3 Z+005.584 * V3 ( alfa = 054.000 )
        X-000.840 + 075.000 / 2 Y+007.891 * V3 Z+005.290 * V3 ( alfa = 056.160 )
        X-000.882 + 075.000 / 2 Y+008.084 * V3 Z+004.989 * V3 ( alfa = 058.320 )
        X-000.923 + 075.000 / 2 Y+008.267 * V3 Z+004.681 * V3 ( alfa = 060.480 )
        X-000.961 + 075.000 / 2 Y+008.437 * V3 Z+004.366 * V3 ( alfa = 062.640 )
        X-001.022 + 075.000 / 2 Y+008.695 * V3 Z+003.828 * V3 ( alfa = 066.240 )
        X-001.086 + 075.000 / 2 Y+008.958 * V3 Z+003.162 * V3 ( alfa = 070.560 )
        X-001.105 + 075.000 / 2 Y+009.035 * V3 Z+002.936 * V3 ( alfa = 072.000 )
        X-001.154 + 075.000 / 2 Y+009.231 * V3 Z+002.247 * V3 ( alfa = 076.320 )
        X-001.174 + 075.000 / 2 Y+009.309 * V3 Z+001.897 * V3 ( alfa = 078.480 )
        X-001.190 + 075.000 / 2 Y+009.374 * V3 Z+001.545 * V3 ( alfa = 080.640 )
        X-001.200 + 075.000 / 2 Y+009.409 * V3 Z+001.309 * V3 ( alfa = 082.080 )
        X-001.211 + 075.000 / 2 Y+009.452 * V3 Z+000.953 * V3 ( alfa = 084.240 )
        X-001.218 + 075.000 / 2 Y+009.481 * V3 Z+000.597 * V3 ( alfa = 086.400 )
        X-001.223 + 075.000 / 2 Y+009.497 * V3 Z+000.239 * V3 ( alfa = 088.560 )
        X-001.223 + 075.000 / 2 Y+009.499 * V3 Z-000.119 * V3 ( alfa = 090.720 )
        X-001.222 + 075.000 / 2 Y+009.493 * V3 Z-000.358 * V3 ( alfa = 092.160 )
        X-001.216 + 075.000 / 2 Y+009.473 * V3 Z-000.716 * V3 ( alfa = 094.320 )
        X-001.207 + 075.000 / 2 Y+009.439 * V3 Z-001.072 * V3 ( alfa = 096.480 )
        X-001.195 + 075.000 / 2 Y+009.392 * V3 Z-001.427 * V3 ( alfa = 098.640 )
        X-001.185 + 075.000 / 2 Y+009.353 * V3 Z-001.663 * V3 ( alfa = 100.080 )
        X-001.146 + 075.000 / 2 Y+009.202 * V3 Z-002.363 * V3 ( alfa = 104.400 )
        X-001.122 + 075.000 / 2 Y+009.106 * V3 Z-002.708 * V3 ( alfa = 106.560 )
        X-001.076 + 075.000 / 2 Y+008.918 * V3 Z-003.274 * V3 ( alfa = 110.160 )
        X-001.044 + 075.000 / 2 Y+008.788 * V3 Z-003.608 * V3 ( alfa = 112.320 )
        X-000.974 + 075.000 / 2 Y+008.491 * V3 Z-004.260 * V3 ( alfa = 116.640 )
        X-000.949 + 075.000 / 2 Y+008.382 * V3 Z-004.472 * V3 ( alfa = 118.080 )
        X-000.909 + 075.000 / 2 Y+008.207 * V3 Z-004.784 * V3 ( alfa = 120.240 )
        X-000.825 + 075.000 / 2 Y+007.824 * V3 Z-005.389 * V3 ( alfa = 124.560 )
        X-000.781 + 075.000 / 2 Y+007.615 * V3 Z-005.680 * V3 ( alfa = 126.720 )
        X-000.751 + 075.000 / 2 Y+007.470 * V3 Z-005.870 * V3 ( alfa = 128.160 )
        X-000.706 + 075.000 / 2 Y+007.243 * V3 Z-006.147 * V3 ( alfa = 130.320 )
        X-000.660 + 075.000 / 2 Y+007.006 * V3 Z-006.416 * V3 ( alfa = 132.480 )
        X-000.614 + 075.000 / 2 Y+006.760 * V3 Z-006.675 * V3 ( alfa = 134.640 )
        X-000.584 + 075.000 / 2 Y+006.590 * V3 Z-006.843 * V3 ( alfa = 136.080 )
        X-000.538 + 075.000 / 2 Y+006.327 * V3 Z-007.086 * V3 ( alfa = 138.240 )
        X-000.447 + 075.000 / 2 Y+005.775 * V3 Z-007.543 * V3 ( alfa = 142.560 )
        X-000.375 + 075.000 / 2 Y+005.290 * V3 Z-007.891 * V3 ( alfa = 146.160 )
        X-000.293 + 075.000 / 2 Y+004.681 * V3 Z-008.267 * V3 ( alfa = 150.480 )
        X-000.255 + 075.000 / 2 Y+004.366 * V3 Z-008.437 * V3 ( alfa = 152.640 )
        X-000.231 + 075.000 / 2 Y+004.153 * V3 Z-008.544 * V3 ( alfa = 154.080 )
        X-000.163 + 075.000 / 2 Y+003.497 * V3 Z-008.833 * V3 ( alfa = 158.400 )
        X-000.134 + 075.000 / 2 Y+003.162 * V3 Z-008.958 * V3 ( alfa = 160.560 )
        X-000.090 + 075.000 / 2 Y+002.593 * V3 Z-009.139 * V3 ( alfa = 164.160 )
        X-000.067 + 075.000 / 2 Y+002.247 * V3 Z-009.231 * V3 ( alfa = 166.320 )
        X-000.048 + 075.000 / 2 Y+001.897 * V3 Z-009.309 * V3 ( alfa = 168.480 )
        X-000.032 + 075.000 / 2 Y+001.545 * V3 Z-009.374 * V3 ( alfa = 170.640 )
        X-000.023 + 075.000 / 2 Y+001.309 * V3 Z-009.409 * V3 ( alfa = 172.080 )
        X-000.012 + 075.000 / 2 Y+000.953 * V3 Z-009.452 * V3 ( alfa = 174.240 )
        X-000.005 + 075.000 / 2 Y+000.597 * V3 Z-009.481 * V3 ( alfa = 176.400 )
        X-000.001 + 075.000 / 2 Y+000.239 * V3 Z-009.497 * V3 ( alfa = 178.560 )
        X+000.000 + 075.000 / 2 Y-000.119 * V3 Z-009.499 * V3 ( alfa = 180.720 )
        X-000.002 + 075.000 / 2 Y-000.358 * V3 Z-009.493 * V3 ( alfa = 182.160 )
        X-000.007 + 075.000 / 2 Y-000.716 * V3 Z-009.473 * V3 ( alfa = 184.320 )
        X-000.015 + 075.000 / 2 Y-001.072 * V3 Z-009.439 * V3 ( alfa = 186.480 )
        X-000.027 + 075.000 / 2 Y-001.427 * V3 Z-009.392 * V3 ( alfa = 188.640 )
        X-000.037 + 075.000 / 2 Y-001.663 * V3 Z-009.353 * V3 ( alfa = 190.080 )
        X-000.054 + 075.000 / 2 Y-002.014 * V3 Z-009.284 * V3 ( alfa = 192.240 )
        X-000.074 + 075.000 / 2 Y-002.363 * V3 Z-009.202 * V3 ( alfa = 194.400 )
        X-000.098 + 075.000 / 2 Y-002.708 * V3 Z-009.106 * V3 ( alfa = 196.560 )
        X-000.124 + 075.000 / 2 Y-003.049 * V3 Z-008.997 * V3 ( alfa = 198.720 )
        X-000.143 + 075.000 / 2 Y-003.274 * V3 Z-008.918 * V3 ( alfa = 200.160 )
        X-000.174 + 075.000 / 2 Y-003.608 * V3 Z-008.788 * V3 ( alfa = 202.320 )
        X-000.207 + 075.000 / 2 Y-003.937 * V3 Z-008.646 * V3 ( alfa = 204.480 )
        X-000.243 + 075.000 / 2 Y-004.260 * V3 Z-008.491 * V3 ( alfa = 206.640 )
        X-000.268 + 075.000 / 2 Y-004.472 * V3 Z-008.382 * V3 ( alfa = 208.080 )
        X-000.306 + 075.000 / 2 Y-004.784 * V3 Z-008.207 * V3 ( alfa = 210.240 )
        X-000.347 + 075.000 / 2 Y-005.090 * V3 Z-008.021 * V3 ( alfa = 212.400 )
        X-000.389 + 075.000 / 2 Y-005.389 * V3 Z-007.824 * V3 ( alfa = 214.560 )
        X-000.433 + 075.000 / 2 Y-005.680 * V3 Z-007.615 * V3 ( alfa = 216.720 )
        X-000.462 + 075.000 / 2 Y-005.870 * V3 Z-007.470 * V3 ( alfa = 218.160 )
        X-000.507 + 075.000 / 2 Y-006.147 * V3 Z-007.243 * V3 ( alfa = 220.320 )
        X-000.553 + 075.000 / 2 Y-006.416 * V3 Z-007.006 * V3 ( alfa = 222.480 )
        X-000.599 + 075.000 / 2 Y-006.675 * V3 Z-006.760 * V3 ( alfa = 224.640 )
        X-000.676 + 075.000 / 2 Y-007.086 * V3 Z-006.327 * V3 ( alfa = 228.240 )
        X-000.721 + 075.000 / 2 Y-007.320 * V3 Z-006.056 * V3 ( alfa = 230.400 )
        X-000.766 + 075.000 / 2 Y-007.543 * V3 Z-005.775 * V3 ( alfa = 232.560 )
        X-000.796 + 075.000 / 2 Y-007.686 * V3 Z-005.584 * V3 ( alfa = 234.000 )
        X-000.840 + 075.000 / 2 Y-007.891 * V3 Z-005.290 * V3 ( alfa = 236.160 )
        X-000.882 + 075.000 / 2 Y-008.084 * V3 Z-004.989 * V3 ( alfa = 238.320 )
        X-000.923 + 075.000 / 2 Y-008.267 * V3 Z-004.681 * V3 ( alfa = 240.480 )
        X-000.961 + 075.000 / 2 Y-008.437 * V3 Z-004.366 * V3 ( alfa = 242.640 )
        X-000.986 + 075.000 / 2 Y-008.544 * V3 Z-004.153 * V3 ( alfa = 244.080 )
        X-001.022 + 075.000 / 2 Y-008.695 * V3 Z-003.828 * V3 ( alfa = 246.240 )
        X-001.055 + 075.000 / 2 Y-008.833 * V3 Z-003.497 * V3 ( alfa = 248.400 )
        X-001.105 + 075.000 / 2 Y-009.035 * V3 Z-002.936 * V3 ( alfa = 252.000 )
        X-001.131 + 075.000 / 2 Y-009.139 * V3 Z-002.593 * V3 ( alfa = 254.160 )
        X-001.174 + 075.000 / 2 Y-009.309 * V3 Z-001.897 * V3 ( alfa = 258.480 )
        X-001.190 + 075.000 / 2 Y-009.374 * V3 Z-001.545 * V3 ( alfa = 260.640 )
        X-001.200 + 075.000 / 2 Y-009.409 * V3 Z-001.309 * V3 ( alfa = 262.080 )
        X-001.211 + 075.000 / 2 Y-009.452 * V3 Z-000.953 * V3 ( alfa = 264.240 )
        X-001.218 + 075.000 / 2 Y-009.481 * V3 Z-000.597 * V3 ( alfa = 266.400 )
        X-001.223 + 075.000 / 2 Y-009.497 * V3 Z-000.239 * V3 ( alfa = 268.560 )
        X-001.223 + 075.000 / 2 Y-009.499 * V3 Z+000.119 * V3 ( alfa = 270.720 )
        X-001.222 + 075.000 / 2 Y-009.493 * V3 Z+000.358 * V3 ( alfa = 272.160 )
        X-001.207 + 075.000 / 2 Y-009.439 * V3 Z+001.072 * V3 ( alfa = 276.480 )
        X-001.195 + 075.000 / 2 Y-009.392 * V3 Z+001.427 * V3 ( alfa = 278.640 )
        X-001.185 + 075.000 / 2 Y-009.353 * V3 Z+001.663 * V3 ( alfa = 280.080 )
        X-001.167 + 075.000 / 2 Y-009.284 * V3 Z+002.014 * V3 ( alfa = 282.240 )
        X-001.146 + 075.000 / 2 Y-009.202 * V3 Z+002.363 * V3 ( alfa = 284.400 )
        X-001.122 + 075.000 / 2 Y-009.106 * V3 Z+002.708 * V3 ( alfa = 286.560 )
        X-001.095 + 075.000 / 2 Y-008.997 * V3 Z+003.049 * V3 ( alfa = 288.720 )
        X-001.076 + 075.000 / 2 Y-008.918 * V3 Z+003.274 * V3 ( alfa = 290.160 )
        X-001.044 + 075.000 / 2 Y-008.788 * V3 Z+003.608 * V3 ( alfa = 292.320 )
        X-001.010 + 075.000 / 2 Y-008.646 * V3 Z+003.937 * V3 ( alfa = 294.480 )
        X-000.974 + 075.000 / 2 Y-008.491 * V3 Z+004.260 * V3 ( alfa = 296.640 )
        X-000.949 + 075.000 / 2 Y-008.382 * V3 Z+004.472 * V3 ( alfa = 298.080 )
        X-000.868 + 075.000 / 2 Y-008.021 * V3 Z+005.090 * V3 ( alfa = 302.400 )
        X-000.825 + 075.000 / 2 Y-007.824 * V3 Z+005.389 * V3 ( alfa = 304.560 )
        X-000.781 + 075.000 / 2 Y-007.615 * V3 Z+005.680 * V3 ( alfa = 306.720 )
        X-000.751 + 075.000 / 2 Y-007.470 * V3 Z+005.870 * V3 ( alfa = 308.160 )
        X-000.706 + 075.000 / 2 Y-007.243 * V3 Z+006.147 * V3 ( alfa = 310.320 )
        X-000.660 + 075.000 / 2 Y-007.006 * V3 Z+006.416 * V3 ( alfa = 312.480 )
        X-000.584 + 075.000 / 2 Y-006.590 * V3 Z+006.843 * V3 ( alfa = 316.080 )
        X-000.492 + 075.000 / 2 Y-006.056 * V3 Z+007.320 * V3 ( alfa = 320.400 )
        X-000.447 + 075.000 / 2 Y-005.775 * V3 Z+007.543 * V3 ( alfa = 322.560 )
        X-000.418 + 075.000 / 2 Y-005.584 * V3 Z+007.686 * V3 ( alfa = 324.000 )
        X-000.375 + 075.000 / 2 Y-005.290 * V3 Z+007.891 * V3 ( alfa = 326.160 )
        X-000.333 + 075.000 / 2 Y-004.989 * V3 Z+008.084 * V3 ( alfa = 328.320 )
        X-000.293 + 075.000 / 2 Y-004.681 * V3 Z+008.267 * V3 ( alfa = 330.480 )
        X-000.255 + 075.000 / 2 Y-004.366 * V3 Z+008.437 * V3 ( alfa = 332.640 )
        X-000.231 + 075.000 / 2 Y-004.153 * V3 Z+008.544 * V3 ( alfa = 334.080 )
        X-000.196 + 075.000 / 2 Y-003.828 * V3 Z+008.695 * V3 ( alfa = 336.240 )
        X-000.134 + 075.000 / 2 Y-003.162 * V3 Z+008.958 * V3 ( alfa = 340.560 )
        X-000.115 + 075.000 / 2 Y-002.936 * V3 Z+009.035 * V3 ( alfa = 342.000 )
        X-000.067 + 075.000 / 2 Y-002.247 * V3 Z+009.231 * V3 ( alfa = 346.320 )
        X-000.048 + 075.000 / 2 Y-001.897 * V3 Z+009.309 * V3 ( alfa = 348.480 )
        X-000.032 + 075.000 / 2 Y-001.545 * V3 Z+009.374 * V3 ( alfa = 350.640 )
        X-000.023 + 075.000 / 2 Y-001.309 * V3 Z+009.409 * V3 ( alfa = 352.080 )
        X-000.012 + 075.000 / 2 Y-000.953 * V3 Z+009.452 * V3 ( alfa = 354.240 )
        X-000.005 + 075.000 / 2 Y-000.597 * V3 Z+009.481 * V3 ( alfa = 356.400 )
        X-000.001 + 075.000 / 2 Y-000.239 * V3 Z+009.497 * V3 ( alfa = 358.560 )
        X+000.000 + 075.000 / 2 Y+000.119 * V3 Z+009.499 * V3 ( alfa = 000.720 )
    Code:
    OS10
        NGHOST G305
        NOEX V3  = 75         ( cilinder )
        NOEX V4  = 29         ( hole     )
        NOEX V5  =  1         ( scale factor )
        NOEX V6  = 100        ( resolution   )
        NOEX V4  = V4 / 2
        G304
        CALL ODYNX LPOS=V3+3 LCTR=2 LDS=0
        SB=V1 M13 M08 G00 X+V3+3 Z[V4-5]*V5 C0 M63 F+V2 G95
        G00 X+V3 M147
        NOEX V12 = VDIN [ 1000 ]
        G01     Z+V4   * V5
        G138
               NOEX V07 = 0
        NAGAIN NOEX V07 = V07 + 1
               NOEX V08 = MOD [ 360 * V7 / V6 , 360 ]
               NOEX V09 = V04 * COS [ V08 ]
               NOEX V10 = V04 * SIN [ V08 ]
               NOEX V11 = SQRT [ V3 * V3 / 4 - V10 * V10 ]
               X + V11 Y + V10 * V05 Z + V09 * V05
        IF [ V07 LT V06 ] NAGAIN
        G136
        G01     Z[V4-5]* V5
        G00 X+V3+3
        NOEX V12 = VDIN [ 1000 ] - V12
        M12 M146
        M0
        NEND NOEX
  13. #13
    Jun 2015
    Antarctica
    hello there is a problem with parametric codes, especially for 3d toolpaths with high resolution
    code shared by mcode at post #8 is a linear type : performs the best
    2nd code shared at post #12 is a parametric type : allows fast code iterations, but may lead to downtime, depending on how the controller handles the calculations inside the loop + how the code is written
    the downtime is lower than 0.1seconds ( perhaps even 0.01 ), but it simply sums up at each loop, and in the end, the cycle time may be signifiant longer
    this post is about downtime elimination for parametric codes, so to make them perform as fast as linear codes : goal is to keep the parametric advantage without cycle downtime
    this will allow rendering fast different toolpaths near the machine, and this is faster than going at the pc and changing the CAM parameters + sending the code to the cnc
    after a few trials with the parametric code, there should be a nice operation output; now, when the operation looks nice, the parametric code should be run again including a data-output soubroutine
    data output can be done in ( at least ) 2 ways :
    ... coordinate output : x_value y_value z_value
    ... G-code output : ... G01 X = x_value Y = y_value Z = z_value
    about the codes that will be shared in this post :
    ... 1st one is a parametric code that outputs data : coordinates ( ODD1 ) and G-code ( ODD2 )
    ... 2nd one reads the coordinates, outputed by ODD1 , and generates the movement into the cnc
    ... 3rd one is edited : inside it is pasted the code outputed by ODD2
    attached file " coords-odd1.txt " was created by ODD1 soubroutine
    attached file " coords-odd2.txt " was created by ODD1 soubroutine
    about execution times :
    ... parametric without data output : 37286ms
    ... parametric with data output : 39883ms ( a bit longer, of course )
    ... 2nd program : 40937ms ( it is even longer, because is harder to read data than to write it )
    ... 3rd program : 37280ms ( same as the parametric without data outputs )
    if possible, is preferable to write a parametric code that performs as fast as a G-code
    Code:
    OS10
        NGHOST G305
        NOEX V4  = V4 / 2
        G304
        G00 X+V3 M147
        CLOSE C   ( close olog )            (* 1/4)
        FWRITC coords.txt;A                 (* 2/4)
        G01     Z+V4   * V5
        G138
               NOEX V07 = 0
               NOEX V09 = DROUND [ V04 * COS [ V08 ] ]                * V05
               NOEX V10 = DROUND [ V04 * SIN [ V08 ] ]                * V05
               NOEX V11 = DROUND [ SQRT [ V3 * V3 / 4 - V10 * V10 ] ]
               X + V11 Y + V10 Z + V09
               CALL ODD2                    (* 3/4)
        G136
        G01     Z[V4-5]* V5
        G00 X+V3+3
        CLOSE C                             (* 4/4)
        M12 M146
        M0
        NEND NOEX
    ODD1 ( data dump v1 )
      NOEX PUT V11
      NOEX PUT '    '
      NOEX PUT V10
      NOEX PUT '    '
      NOEX PUT V09
      WRITE C
    ODD2 ( data dump v2 )
      NOEX PUT 'X'
      NOEX PUT V11
      NOEX PUT 'Y'
      NOEX PUT V10
      NOEX PUT 'Z'
      NOEX PUT V09
      WRITE C
    Code:
    OS11
        NGHOST G305
        NOEX V4  = V4 / 2
        G304
        G00 X+V3 M147
      ( CLOSE C )  ( close olog )
        FOPENA coords-odd1.txt;A
        G01     Z+V4   * V5
        G138
               NOEX V07 = 0
               READ A
               NOEX GET V11 , 10
               NOEX GET     , 01
               NOEX GET V10 , 10
               NOEX GET     , 01
               NOEX GET V09 , 10
               NOEX V09 = V09 * V05
               NOEX V10 = V10 * V05
        G136
        G01     Z[V4-5]* V5
        G00 X+V3+3
        CLOSE A
        M12 M146
        M0
        NEND NOEX
    Code:
    OS12
        NGHOST G305
      ( NOEX V6  = 100 )      ( resolution   )
        NOEX V4  = V4 / 2
        G304
        G00 X+V3 M147
        G01     Z+V4   * V5
        G138
        CALL OQ12
        G136
        G01     Z[V4-5]* V5
        G00 X+V3+3
        M12 M146
        M0
        NEND NOEX
    OQ12
    X    37.489Y      0.91Z    14.471
    X    37.456Y     1.817Z    14.386
    X    37.401Y     2.717Z    14.243
    X    37.326Y     3.606Z    14.044
    X    37.231Y     4.481Z     13.79
    X    37.118Y     5.338Z    13.482
    X    36.988Y     6.174Z     13.12
    X    36.844Y     6.985Z    12.706
    X    36.686Y     7.769Z    12.243
    X    36.519Y     8.523Z    11.731
    X    36.343Y     9.243Z    11.172
    X    36.162Y     9.926Z     10.57
    X     35.98Y     10.57Z     9.926
    X    35.797Y    11.172Z     9.243
    X    35.618Y    11.731Z     8.523
    X    35.445Y    12.243Z     7.769
    X    35.282Y    12.706Z     6.985
    X     35.13Y     13.12Z     6.174
    X    34.993Y    13.482Z     5.338
    X    34.872Y     13.79Z     4.481
    X    34.771Y    14.044Z     3.606
    X     34.69Y    14.243Z     2.717
    X    34.631Y    14.386Z     1.817
    X    34.595Y    14.471Z      0.91
    X    34.583Y      14.5Z         0
    X    34.595Y    14.471Z     -0.91
    X    34.631Y    14.386Z    -1.817
    X     34.69Y    14.243Z    -2.717
    X    34.771Y    14.044Z    -3.606
    X    34.872Y     13.79Z    -4.481
    X    34.993Y    13.482Z    -5.338
    X     35.13Y     13.12Z    -6.174
    X    35.282Y    12.706Z    -6.985
    X    35.445Y    12.243Z    -7.769
    X    35.618Y    11.731Z    -8.523
    X    35.797Y    11.172Z    -9.243
    X     35.98Y     10.57Z    -9.926
    X    36.162Y     9.926Z    -10.57
    X    36.343Y     9.243Z   -11.172
    X    36.519Y     8.523Z   -11.731
    X    36.686Y     7.769Z   -12.243
    X    36.844Y     6.985Z   -12.706
    X    36.988Y     6.174Z    -13.12
    X    37.118Y     5.338Z   -13.482
    X    37.231Y     4.481Z    -13.79
    X    37.326Y     3.606Z   -14.044
    X    37.401Y     2.717Z   -14.243
    X    37.456Y     1.817Z   -14.386
    X    37.489Y      0.91Z   -14.471
    X      37.5Y         0Z     -14.5
    X    37.489Y     -0.91Z   -14.471
    X    37.456Y    -1.817Z   -14.386
    X    37.401Y    -2.717Z   -14.243
    X    37.326Y    -3.606Z   -14.044
    X    37.231Y    -4.481Z    -13.79
    X    37.118Y    -5.338Z   -13.482
    X    36.988Y    -6.174Z    -13.12
    X    36.844Y    -6.985Z   -12.706
    X    36.686Y    -7.769Z   -12.243
    X    36.519Y    -8.523Z   -11.731
    X    36.343Y    -9.243Z   -11.172
    X    36.162Y    -9.926Z    -10.57
    X     35.98Y    -10.57Z    -9.926
    X    35.797Y   -11.172Z    -9.243
    X    35.618Y   -11.731Z    -8.523
    X    35.445Y   -12.243Z    -7.769
    X    35.282Y   -12.706Z    -6.985
    X     35.13Y    -13.12Z    -6.174
    X    34.993Y   -13.482Z    -5.338
    X    34.872Y    -13.79Z    -4.481
    X    34.771Y   -14.044Z    -3.606
    X     34.69Y   -14.243Z    -2.717
    X    34.631Y   -14.386Z    -1.817
    X    34.595Y   -14.471Z     -0.91
    X    34.583Y     -14.5Z         0
    X    34.595Y   -14.471Z      0.91
    X    34.631Y   -14.386Z     1.817
    X     34.69Y   -14.243Z     2.717
    X    34.771Y   -14.044Z     3.606
    X    34.872Y    -13.79Z     4.481
    X    34.993Y   -13.482Z     5.338
    X     35.13Y    -13.12Z     6.174
    X    35.282Y   -12.706Z     6.985
    X    35.445Y   -12.243Z     7.769
    X    35.618Y   -11.731Z     8.523
    X    35.797Y   -11.172Z     9.243
    X     35.98Y    -10.57Z     9.926
    X    36.162Y    -9.926Z     10.57
    X    36.343Y    -9.243Z    11.172
    X    36.519Y    -8.523Z    11.731
    X    36.686Y    -7.769Z    12.243
    X    36.844Y    -6.985Z    12.706
    X    36.988Y    -6.174Z     13.12
    X    37.118Y    -5.338Z    13.482
    X    37.231Y    -4.481Z     13.79
    X    37.326Y    -3.606Z    14.044
    X    37.401Y    -2.717Z    14.243
    X    37.456Y    -1.817Z    14.386
    X    37.489Y     -0.91Z    14.471
    X      37.5Y         0Z      14.5
  14. #14
    Jun 2015
    Antarctica
    one more thing : advantages of a nice performing parametric, that allows fast iterations near the cnc is a nice thing ( fast editable ), especially because it spares one from going to the pc to re-render the toolpath, and back to the cnc
    even if editing the parametric code involves keystrokes near the cnc control panel, this action is faster than editing the CAM
    next step is a signifiant reduced operation time near the control panel, by reducing drastically the required number of keystrokes
    this is done by a software that changes the program highways without the need to re-select the program : for example, changing specs and toolpath geometry & resolution can be done by a single keystroke
    i won't go into this right now, i only wanna share that it is possible / kindly
