Climb milling actually puts less load on the system because there is less rubbing of the cutter edge. As long as the machine has zero to reasonably small backlash climb milling is prefered. I use helical or tangential engagement and avoid straight plunging where possible. Where a straight plunge is required, then I drill a pilot hole when possible.
