hy techno spanner, i am sorry, i can't explain the G76, but if you wish i can explain the code syntax for Okuma code is a bit different, but same stuff happens : pls check attached image
however, main problem is not understanding the code, but machine cinematics, because it is possible that the cnc won't perform as you expect
near a thread end, all cncs are losing syncronization between Z and S
similar, near a thread start, all cncs are building the syncronization between Z and S
there is a certain portion, in between, where the quality of the syncro is at its best
fact is that a portion of the back chamfer is executed among the desincronization palier, and the controller will put accent on the deceleration, and not on the back chamfer
this does not mean that the back chamfer is not executed; it is executed, but not at the best sync quality ( it is not prioritized ) : one consequence is that "good code" may lead to signifiant downtime
the back chamfer ( or the pull-out movement ), may be executed :
... accordingly to specific code, that has "back chamfer" parameters
... even if the code does not have "back chamfer" parameters : for example, it may happen, as default, during the last spindle revolution
on quick servos, inertia has a very important role, and may lead to negative diff, thus the "detected value" will go in front of the "calculated value" : in that moment, the Z servo will break even harder, and the "pull out movement" will be out of sync aggressive threading will increase backlash, especially when high Z feeds are used on heavy turrets for short threads + fast rapids, with quick accel/decel
- is hard to measure the back chamfer, but not impossible
- is possible to log cinematic data, so to have an idea about the numbers, but this is not common
a good alternative, when there is no undercut, would be feeding each pass at a shorter Z, so to reduce stress on the insert near the thread end
kindly
