The attached page from my book should help.
Could anybody explain FANUC G75 canned grooving cycle with example.
- Need help with g code for fire control pocket on AR15 lower reciver, have G code.
- Newbie- corel.hpgl > sheetcam.tap > pronterface.g-code > slic3r.g.code> ramps 1.4 > H-BOT
- Fanucs for sale!
- Newbie- Takeout Unused G Code commands in Mastercams Generated G Code
- looking for g code 3d from bobcadcam or simmilar for indexer lpt v5 with g code soft
depending on the year of the control it could be a two line read of a one, also i think one the new controls you can use either you have to change a pram.
Say your part is 1.5 od and your using a .125 groove and you want to groove 1" past Z0
G0G54T101
G50S2000
G96S600M3
X1.6Z-1.125M8(X.100 over the part Z is groove location)
G75R.025(R is how much tool will retract after each cut)
G75X.875Q200F.006(X is the diam. of groove Q is amount per cut)
G0X1.6
Z3.M9
M1
So it will take .02 per cut till reaching .875 will retract .025 to break chips
hope this helps
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Hursty,
jackson,
Thanks for the solution. I will try and let you guys know about the result.
G00T0900
G96S250M3
G0X5.45Z1.T909M8
Z-.325 (start position for grooving)
G75F.005X4.1Z-1.94I250K1000 (x value is final dia. z value is final z wall. I value is amount of peck. k value is step over amount in z.)
I hope this helps this is for fanuc 11t)
On my machine the retract amount is set by a parmeter.
Thank you all. MY cnc is Oi Mate-TC.
I tried with above all got error but jackson format works. May be the Jackson fromat is compatible to my cnc.
G75 R0.
G75X43.5Z-37.95Q2600P500R0.5F0.1
G0Z2.
and it works.
thank you all . You all make me try and now i know something about it.
Digging old graves ?
excelente amigo , este código también es compatible con el fanuc 6t
