Hi- I'd be interested in trying this software- could you please re-post to the dropbox?
Hello everybody.
I'm working in a simple software to generate G-Code for Helical Interpolation for milling a threading on Mach3.
It runs in a windows terminal.
You can do internal and external thread.
Can do it in a single or more than one pass: you enter the max step-over of the tool, and the finishing step-over. And the software calculates how many passes is necessary.
You can do: Right-hand and Left-hand thread.
And you can enter the initial angle of thread. I think it is "scroll angle"?
Some screens / prints of the software:
Video of my Sieg X2 milling a threading using a helical interpolation on Mach3:
If someone think it's useful and wanna to help me translating the software, let me know.
Download:
https://www.dropbox.com/s/quikoeaesn...glish.zip?dl=1
OUTPUT FILE GENERATED BY SOFTWARE:
Code:;Df-Major Diameter: 30.00 [mm] ;Da-Finishing Diameter: 29.00 [mm] ;Di-Minor Diameter: 27.00 [mm] ;pl-Tool Step-over: 1.00 [mm] ;pl-Tool Finishing Step-over: 0.50 [mm] ;np-Number of passes of the thread: 2 ;step-over pass: 0 diameter: 27.000 [mm] ;step-over pass: 1 diameter: 29.000 [mm] ;step-over pass: 2 diameter: 30.000 [mm] ;Depth 'L' of the thread: 15.00 [mm] ;p-Lead Thread: 4.00 [mm] ;n-Total number of pitches of thread: 3.75 fios ;Initial Angle Scroll: 0.0 [graus] -> Right ;Final Angle Scroll: 270.0 [graus] ;Thread [INTERNAL] [Right-hand >> Clockwise] ;Tool Diameter: 10.00 mm ;Precision of step: 0.148 mm ;Time: 0.6 minutos ;RPM S: 1000 rpm ;Feed-Rate (fn): 800.0 [mm / min] g00 z3 g00 x0 y0 M3 S1000 G04 P3 f800 g00 x9.500 y-0.000 ;step-over pass: 1 - pitch pass N: 1 ;diameter: 29.000 [mm] g01 x9.499 y-0.166 z-0.011 g01 x9.494 y-0.332 z-0.022 g01 x9.487 y-0.497 z-0.033 g01 x9.477 y-0.663 z-0.044 g01 x9.464 y-0.828 z-0.056 g01 x9.448 y-0.993 z-0.067 g01 x9.429 y-1.158 z-0.078 g01 x9.408 y-1.322 z-0.089 g01 x9.383 y-1.486 z-0.100 g01 x9.356 y-1.650 z-0.111 g01 x9.325 y-1.813 z-0.122 g01 x9.292 y-1.975 z-0.133 g01 x9.257 y-2.137 z-0.144 g01 x9.218 y-2.298 z-0.156 g01 x9.176 y-2.459 z-0.167 g01 x9.132 y-2.619 z-0.178 g01 x9.085 y-2.778 z-0.189 g01 x9.035 y-2.936 z-0.200 g01 x8.982 y-3.093 z-0.211 g01 x8.927 y-3.249 z-0.222 g01 x8.869 y-3.404 z-0.233 g01 x8.808 y-3.559 z-0.244 g01 x8.745 y-3.712 z-0.256 g01 x8.679 y-3.864 z-0.267 g01 x8.610 y-4.015 z-0.278 g01 x8.539 y-4.165 z-0.289 g01 x8.465 y-4.313 z-0.300 g01 x8.388 y-4.460 z-0.311 g01 x8.309 y-4.606 z-0.322 g01 x8.227 y-4.750 z-0.333 g01 x8.143 y-4.893 z-0.344 g01 x8.056 y-5.034 z-0.356 g01 x7.967 y-5.174 z-0.367 g01 x7.876 y-5.312 z-0.378 g01 x7.782 y-5.449 z-0.389 g01 x7.686 y-5.584 z-0.400 g01 x7.587 y-5.717 z-0.411 g01 x7.486 y-5.849 z-0.422 g01 x7.383 y-5.979 z-0.433 g01 x7.277 y-6.106 z-0.444 g01 x7.170 y-6.233 z-0.456 g01 x7.060 y-6.357 z-0.467 g01 x6.948 y-6.479 z-0.478 g01 x6.834 y-6.599 z-0.489 g01 x6.718 y-6.718 z-0.500 g01 x6.599 y-6.834 z-0.511 g01 x6.479 y-6.948 z-0.522 g01 x6.357 y-7.060 z-0.533 g01 x6.233 y-7.170 z-0.544 g01 x6.106 y-7.277 z-0.556 g01 x5.979 y-7.383 z-0.567 g01 x5.849 y-7.486 z-0.578 g01 x5.717 y-7.587 z-0.589 g01 x5.584 y-7.686 z-0.600 g01 x5.449 y-7.782 z-0.611 g01 x5.312 y-7.876 z-0.622 g01 x5.174 y-7.967 z-0.633 g01 x5.034 y-8.056 z-0.644 g01 x4.893 y-8.143 z-0.656 g01 x4.750 y-8.227 z-0.667 g01 x4.606 y-8.309 z-0.678 g01 x4.460 y-8.388 z-0.689 g01 x4.313 y-8.465 z-0.700 g01 x4.165 y-8.539 z-0.711 g01 x4.015 y-8.610 z-0.722 g01 x3.864 y-8.679 z-0.733 g01 x3.712 y-8.745 z-0.744 g01 x3.559 y-8.808 z-0.756 g01 x3.404 y-8.869 z-0.767 g01 x3.249 y-8.927 z-0.778 g01 x3.093 y-8.982 z-0.789 g01 x2.936 y-9.035 z-0.800 g01 x2.778 y-9.085 z-0.811 g01 x2.619 y-9.132 z-0.822 g01 x2.459 y-9.176 z-0.833 g01 x2.298 y-9.218 z-0.844 g01 x2.137 y-9.257 z-0.856 g01 x1.975 y-9.292 z-0.867 g01 x1.813 y-9.325 z-0.878 g01 x1.650 y-9.356 z-0.889 g01 x1.486 y-9.383 z-0.900 g01 x1.322 y-9.408 z-0.911 g01 x1.158 y-9.429 z-0.922 g01 x0.993 y-9.448 z-0.933 g01 x0.828 y-9.464 z-0.944 g01 x0.663 y-9.477 z-0.956 g01 x0.497 y-9.487 z-0.967 g01 x0.332 y-9.494 z-0.978 g01 x0.166 y-9.499 z-0.989 g01 x0.000 y-9.500 z-1.000 g01 x-0.166 y-9.499 z-1.011 g01 x-0.332 y-9.494 z-1.022 g01 x-0.497 y-9.487 z-1.033 g01 x-0.663 y-9.477 z-1.044 g01 x-0.828 y-9.464 z-1.056 g01 x-0.993 y-9.448 z-1.067 g01 x-1.158 y-9.429 z-1.078 g01 x-1.322 y-9.408 z-1.089 g01 x-1.486 y-9.383 z-1.100 g01 x-1.650 y-9.356 z-1.111 g01 x-1.813 y-9.325 z-1.122 g01 x-1.975 y-9.292 z-1.133 g01 x-2.137 y-9.257 z-1.144 g01 x-2.298 y-9.218 z-1.156 g01 x-2.459 y-9.176 z-1.167 g01 x-2.619 y-9.132 z-1.178 g01 x-2.778 y-9.085 z-1.189 g01 x-2.936 y-9.035 z-1.200 g01 x-3.093 y-8.982 z-1.211 g01 x-3.249 y-8.927 z-1.222 g01 x-3.404 y-8.869 z-1.233 g01 x-3.559 y-8.808 z-1.244 g01 x-3.712 y-8.745 z-1.256 g01 x-3.864 y-8.679 z-1.267 g01 x-4.015 y-8.610 z-1.278 g01 x-4.165 y-8.539 z-1.289 g01 x-4.313 y-8.465 z-1.300 g01 x-4.460 y-8.388 z-1.311 g01 x-4.606 y-8.309 z-1.322 g01 x-4.750 y-8.227 z-1.333 g01 x-4.893 y-8.143 z-1.344 g01 x-5.034 y-8.056 z-1.356 g01 x-5.174 y-7.967 z-1.367 g01 x-5.312 y-7.876 z-1.378 g01 x-5.449 y-7.782 z-1.389 g01 x-5.584 y-7.686 z-1.400 g01 x-5.717 y-7.587 z-1.411 g01 x-5.849 y-7.486 z-1.422 g01 x-5.979 y-7.383 z-1.433 g01 x-6.106 y-7.277 z-1.444 g01 x-6.233 y-7.170 z-1.456 g01 x-6.357 y-7.060 z-1.467 g01 x-6.479 y-6.948 z-1.478 g01 x-6.599 y-6.834 z-1.489 g01 x-6.718 y-6.718 z-1.500 g01 x-6.834 y-6.599 z-1.511 g01 x-6.948 y-6.479 z-1.522 g01 x-7.060 y-6.357 z-1.533 g01 x-7.170 y-6.233 z-1.544 g01 x-7.277 y-6.106 z-1.556 g01 x-7.383 y-5.979 z-1.567 g01 x-7.486 y-5.849 z-1.578 g01 x-7.587 y-5.717 z-1.589 g01 x-7.686 y-5.584 z-1.600 g01 x-7.782 y-5.449 z-1.611 g01 x-7.876 y-5.312 z-1.622 g01 x-7.967 y-5.174 z-1.633 g01 x-8.056 y-5.034 z-1.644 g01 x-8.143 y-4.893 z-1.656 g01 x-8.227 y-4.750 z-1.667 g01 x-8.309 y-4.606 z-1.678 g01 x-8.388 y-4.460 z-1.689 g01 x-8.465 y-4.313 z-1.700 g01 x-8.539 y-4.165 z-1.711 g01 x-8.610 y-4.015 z-1.722 g01 x-8.679 y-3.864 z-1.733 g01 x-8.745 y-3.712 z-1.744 g01 x-8.808 y-3.559 z-1.756 g01 x-8.869 y-3.404 z-1.767 g01 x-8.927 y-3.249 z-1.778 g01 x-8.982 y-3.093 z-1.789 g01 x-9.035 y-2.936 z-1.800 g01 x-9.085 y-2.778 z-1.811 g01 x-9.132 y-2.619 z-1.822 g01 x-9.176 y-2.459 z-1.833 g01 x-9.218 y-2.298 z-1.844 g01 x-9.257 y-2.137 z-1.856 g01 x-9.292 y-1.975 z-1.867 g01 x-9.325 y-1.813 z-1.878 g01 x-9.356 y-1.650 z-1.889 g01 x-9.383 y-1.486 z-1.900 g01 x-9.408 y-1.322 z-1.911 g01 x-9.429 y-1.158 z-1.922 g01 x-9.448 y-0.993 z-1.933 g01 x-9.464 y-0.828 z-1.944 g01 x-9.477 y-0.663 z-1.956 g01 x-9.487 y-0.497 z-1.967 g01 x-9.494 y-0.332 z-1.978 g01 x-9.499 y-0.166 z-1.989 g01 x-9.500 y-0.000 z-2.000 g01 x-9.499 y0.166 z-2.011 g01 x-9.494 y0.332 z-2.022 g01 x-9.487 y0.497 z-2.033 g01 x-9.477 y0.663 z-2.044 g01 x-9.464 y0.828 z-2.056 g01 x-9.448 y0.993 z-2.067 g01 x-9.429 y1.158 z-2.078 g01 x-9.408 y1.322 z-2.089 g01 x-9.383 y1.486 z-2.100 g01 x-9.356 y1.650 z-2.111 g01 x-9.325 y1.813 z-2.122 g01 x-9.292 y1.975 z-2.133 g01 x-9.257 y2.137 z-2.144 g01 x-9.218 y2.298 z-2.156 g01 x-9.176 y2.459 z-2.167 g01 x-9.132 y2.619 z-2.178 g01 x-9.085 y2.778 z-2.189 g01 x-9.035 y2.936 z-2.200 g01 x-8.982 y3.093 z-2.211 g01 x-8.927 y3.249 z-2.222 g01 x-8.869 y3.404 z-2.233 g01 x-8.808 y3.559 z-2.244 g01 x-8.745 y3.712 z-2.256 g01 x-8.679 y3.864 z-2.267 g01 x-8.610 y4.015 z-2.278 g01 x-8.539 y4.165 z-2.289 g01 x-8.465 y4.313 z-2.300 g01 x-8.388 y4.460 z-2.311 g01 x-8.309 y4.606 z-2.322 g01 x-8.227 y4.750 z-2.333 g01 x-8.143 y4.893 z-2.344 g01 x-8.056 y5.034 z-2.356 g01 x-7.967 y5.174 z-2.367 g01 x-7.876 y5.312 z-2.378 g01 x-7.782 y5.449 z-2.389 g01 x-7.686 y5.584 z-2.400 g01 x-7.587 y5.717 z-2.411 g01 x-7.486 y5.849 z-2.422 g01 x-7.383 y5.979 z-2.433 g01 x-7.277 y6.106 z-2.444 g01 x-7.170 y6.233 z-2.456 g01 x-7.060 y6.357 z-2.467 g01 x-6.948 y6.479 z-2.478 g01 x-6.834 y6.599 z-2.489 g01 x-6.718 y6.718 z-2.500 g01 x-6.599 y6.834 z-2.511 g01 x-6.479 y6.948 z-2.522 g01 x-6.357 y7.060 z-2.533 g01 x-6.233 y7.170 z-2.544 g01 x-6.106 y7.277 z-2.556 g01 x-5.979 y7.383 z-2.567 g01 x-5.849 y7.486 z-2.578 g01 x-5.717 y7.587 z-2.589 g01 x-5.584 y7.686 z-2.600 g01 x-5.449 y7.782 z-2.611 g01 x-5.312 y7.876 z-2.622 g01 x-5.174 y7.967 z-2.633 g01 x-5.034 y8.056 z-2.644 g01 x-4.893 y8.143 z-2.656 g01 x-4.750 y8.227 z-2.667 g01 x-4.606 y8.309 z-2.678 g01 x-4.460 y8.388 z-2.689 g01 x-4.313 y8.465 z-2.700 g01 x-4.165 y8.539 z-2.711 g01 x-4.015 y8.610 z-2.722 g01 x-3.864 y8.679 z-2.733 g01 x-3.712 y8.745 z-2.744 g01 x-3.559 y8.808 z-2.756 g01 x-3.404 y8.869 z-2.767 g01 x-3.249 y8.927 z-2.778 g01 x-3.093 y8.982 z-2.789 g01 x-2.936 y9.035 z-2.800 g01 x-2.778 y9.085 z-2.811 g01 x-2.619 y9.132 z-2.822 g01 x-2.459 y9.176 z-2.833 g01 x-2.298 y9.218 z-2.844 g01 x-2.137 y9.257 z-2.856 g01 x-1.975 y9.292 z-2.867 g01 x-1.813 y9.325 z-2.878 g01 x-1.650 y9.356 z-2.889 g01 x-1.486 y9.383 z-2.900 g01 x-1.322 y9.408 z-2.911 g01 x-1.158 y9.429 z-2.922 g01 x-0.993 y9.448 z-2.933 g01 x-0.828 y9.464 z-2.944 g01 x-0.663 y9.477 z-2.956 g01 x-0.497 y9.487 z-2.967 g01 x-0.332 y9.494 z-2.978 g01 x-0.166 y9.499 z-2.989 g01 x-0.000 y9.500 z-3.000 g01 x0.166 y9.499 z-3.011 g01 x0.332 y9.494 z-3.022 g01 x0.497 y9.487 z-3.033 g01 x0.663 y9.477 z-3.044 g01 x0.828 y9.464 z-3.056 g01 x0.993 y9.448 z-3.067 g01 x1.158 y9.429 z-3.078 g01 x1.322 y9.408 z-3.089 g01 x1.486 y9.383 z-3.100 g01 x1.650 y9.356 z-3.111 g01 x1.813 y9.325 z-3.122 g01 x1.975 y9.292 z-3.133 g01 x2.137 y9.257 z-3.144 g01 x2.298 y9.218 z-3.156 g01 x2.459 y9.176 z-3.167 g01 x2.619 y9.132 z-3.178 g01 x2.778 y9.085 z-3.189 g01 x2.936 y9.035 z-3.200 g01 x3.093 y8.982 z-3.211 g01 x3.249 y8.927 z-3.222 g01 x3.404 y8.869 z-3.233 g01 x3.559 y8.808 z-3.244 g01 x3.712 y8.745 z-3.256 g01 x3.864 y8.679 z-3.267 g01 x4.015 y8.610 z-3.278 g01 x4.165 y8.539 z-3.289 g01 x4.313 y8.465 z-3.300 g01 x4.460 y8.388 z-3.311 g01 x4.606 y8.309 z-3.322 g01 x4.750 y8.227 z-3.333 g01 x4.893 y8.143 z-3.344 g01 x5.034 y8.056 z-3.356 g01 x5.174 y7.967 z-3.367 g01 x5.312 y7.876 z-3.378 g01 x5.449 y7.782 z-3.389 g01 x5.584 y7.686 z-3.400 g01 x5.717 y7.587 z-3.411 g01 x5.849 y7.486 z-3.422 g01 x5.979 y7.383 z-3.433 g01 x6.106 y7.277 z-3.444 g01 x6.233 y7.170 z-3.456 g01 x6.357 y7.060 z-3.467 g01 x6.479 y6.948 z-3.478 g01 x6.599 y6.834 z-3.489 g01 x6.718 y6.718 z-3.500 g01 x6.834 y6.599 z-3.511 g01 x6.948 y6.479 z-3.522 g01 x7.060 y6.357 z-3.533 g01 x7.170 y6.233 z-3.544 g01 x7.277 y6.106 z-3.556 g01 x7.383 y5.979 z-3.567 g01 x7.486 y5.849 z-3.578 g01 x7.587 y5.717 z-3.589 g01 x7.686 y5.584 z-3.600 g01 x7.782 y5.449 z-3.611 g01 x7.876 y5.312 z-3.622 g01 x7.967 y5.174 z-3.633 g01 x8.056 y5.034 z-3.644 g01 x8.143 y4.893 z-3.656 g01 x8.227 y4.750 z-3.667 g01 x8.309 y4.606 z-3.678 g01 x8.388 y4.460 z-3.689 g01 x8.465 y4.313 z-3.700 g01 x8.539 y4.165 z-3.711 g01 x8.610 y4.015 z-3.722 g01 x8.679 y3.864 z-3.733 g01 x8.745 y3.712 z-3.744 g01 x8.808 y3.559 z-3.756 g01 x8.869 y3.404 z-3.767 g01 x8.927 y3.249 z-3.778 g01 x8.982 y3.093 z-3.789 g01 x9.035 y2.936 z-3.800 g01 x9.085 y2.778 z-3.811 g01 x9.132 y2.619 z-3.822 g01 x9.176 y2.459 z-3.833 g01 x9.218 y2.298 z-3.844 g01 x9.257 y2.137 z-3.856 g01 x9.292 y1.975 z-3.867 g01 x9.325 y1.813 z-3.878 g01 x9.356 y1.650 z-3.889 g01 x9.383 y1.486 z-3.900 g01 x9.408 y1.322 z-3.911 g01 x9.429 y1.158 z-3.922 g01 x9.448 y0.993 z-3.933 g01 x9.464 y0.828 z-3.944 g01 x9.477 y0.663 z-3.956 g01 x9.487 y0.497 z-3.967 g01 x9.494 y0.332 z-3.978 g01 x9.499 y0.166 z-3.989 g01 x9.500 y0.000 z-4.000 ;step-over pass: 1 - pitch pass N: 2 ;diameter: 29.000 [mm] g01 x9.499 y-0.166 z-4.011 g01 x9.494 y-0.332 z-4.022 g01 x9.487 y-0.497 z-4.033 g01 x9.477 y-0.663 z-4.044 g01 x9.464 y-0.828 z-4.056 g01 x9.448 y-0.993 z-4.067 g01 x9.429 y-1.158 z-4.078 g01 x9.408 y-1.322 z-4.089 g01 x9.383 y-1.486 z-4.100 g01 x9.356 y-1.650 z-4.111 g01 x9.325 y-1.813 z-4.122 g01 x9.292 y-1.975 z-4.133 g01 x9.257 y-2.137 z-4.144 g01 x9.218 y-2.298 z-4.156 g01 x9.176 y-2.459 z-4.167 g01 x9.132 y-2.619 z-4.178 g01 x9.085 y-2.778 z-4.189 g01 x9.035 y-2.936 z-4.200 g01 x8.982 y-3.093 z-4.211 g01 x8.927 y-3.249 z-4.222 g01 x8.869 y-3.404 z-4.233 g01 x8.808 y-3.559 z-4.244 g01 x8.745 y-3.712 z-4.256 g01 x8.679 y-3.864 z-4.267 g01 x8.610 y-4.015 z-4.278 g01 x8.539 y-4.165 z-4.289 g01 x8.465 y-4.313 z-4.300 g01 x8.388 y-4.460 z-4.311 g01 x8.309 y-4.606 z-4.322 g01 x8.227 y-4.750 z-4.333 g01 x8.143 y-4.893 z-4.344 g01 x8.056 y-5.034 z-4.356 g01 x7.967 y-5.174 z-4.367 g01 x7.876 y-5.312 z-4.378 g01 x7.782 y-5.449 z-4.389 g01 x7.686 y-5.584 z-4.400 g01 x7.587 y-5.717 z-4.411 g01 x7.486 y-5.849 z-4.422 g01 x7.383 y-5.979 z-4.433 g01 x7.277 y-6.106 z-4.444 g01 x7.170 y-6.233 z-4.456 g01 x7.060 y-6.357 z-4.467 g01 x6.948 y-6.479 z-4.478 g01 x6.834 y-6.599 z-4.489 g01 x6.718 y-6.718 z-4.500 g01 x6.599 y-6.834 z-4.511 g01 x6.479 y-6.948 z-4.522 g01 x6.357 y-7.060 z-4.533 g01 x6.233 y-7.170 z-4.544 g01 x6.106 y-7.277 z-4.556 g01 x5.979 y-7.383 z-4.567 g01 x5.849 y-7.486 z-4.578 g01 x5.717 y-7.587 z-4.589 g01 x5.584 y-7.686 z-4.600 g01 x5.449 y-7.782 z-4.611 g01 x5.312 y-7.876 z-4.622 g01 x5.174 y-7.967 z-4.633 g01 x5.034 y-8.056 z-4.644 g01 x4.893 y-8.143 z-4.656 g01 x4.750 y-8.227 z-4.667 g01 x4.606 y-8.309 z-4.678 g01 x4.460 y-8.388 z-4.689 g01 x4.313 y-8.465 z-4.700 g01 x4.165 y-8.539 z-4.711 g01 x4.015 y-8.610 z-4.722 g01 x3.864 y-8.679 z-4.733 g01 x3.712 y-8.745 z-4.744 g01 x3.559 y-8.808 z-4.756 g01 x3.404 y-8.869 z-4.767 g01 x3.249 y-8.927 z-4.778 g01 x3.093 y-8.982 z-4.789 g01 x2.936 y-9.035 z-4.800 g01 x2.778 y-9.085 z-4.811 g01 x2.619 y-9.132 z-4.822 g01 x2.459 y-9.176 z-4.833 g01 x2.298 y-9.218 z-4.844 g01 x2.137 y-9.257 z-4.856 g01 x1.975 y-9.292 z-4.867 g01 x1.813 y-9.325 z-4.878 g01 x1.650 y-9.356 z-4.889 g01 x1.486 y-9.383 z-4.900 g01 x1.322 y-9.408 z-4.911 g01 x1.158 y-9.429 z-4.922 g01 x0.993 y-9.448 z-4.933 g01 x0.828 y-9.464 z-4.944 g01 x0.663 y-9.477 z-4.956 g01 x0.497 y-9.487 z-4.967 g01 x0.332 y-9.494 z-4.978 g01 x0.166 y-9.499 z-4.989 g01 x0.000 y-9.500 z-5.000 g01 x-0.166 y-9.499 z-5.011 g01 x-0.332 y-9.494 z-5.022 g01 x-0.497 y-9.487 z-5.033 g01 x-0.663 y-9.477 z-5.044 g01 x-0.828 y-9.464 z-5.056 g01 x-0.993 y-9.448 z-5.067 g01 x-1.158 y-9.429 z-5.078 g01 x-1.322 y-9.408 z-5.089 g01 x-1.486 y-9.383 z-5.100 g01 x-1.650 y-9.356 z-5.111 g01 x-1.813 y-9.325 z-5.122 g01 x-1.975 y-9.292 z-5.133 g01 x-2.137 y-9.257 z-5.144 g01 x-2.298 y-9.218 z-5.156 g01 x-2.459 y-9.176 z-5.167 g01 x-2.619 y-9.132 z-5.178 g01 x-2.778 y-9.085 z-5.189 g01 x-2.936 y-9.035 z-5.200 g01 x-3.093 y-8.982 z-5.211 g01 x-3.249 y-8.927 z-5.222 g01 x-3.404 y-8.869 z-5.233 g01 x-3.559 y-8.808 z-5.244 g01 x-3.712 y-8.745 z-5.256 g01 x-3.864 y-8.679 z-5.267 g01 x-4.015 y-8.610 z-5.278 g01 x-4.165 y-8.539 z-5.289 g01 x-4.313 y-8.465 z-5.300 g01 x-4.460 y-8.388 z-5.311 g01 x-4.606 y-8.309 z-5.322 g01 x-4.750 y-8.227 z-5.333 g01 x-4.893 y-8.143 z-5.344 g01 x-5.034 y-8.056 z-5.356 g01 x-5.174 y-7.967 z-5.367 g01 x-5.312 y-7.876 z-5.378 g01 x-5.449 y-7.782 z-5.389 g01 x-5.584 y-7.686 z-5.400 g01 x-5.717 y-7.587 z-5.411 g01 x-5.849 y-7.486 z-5.422 g01 x-5.979 y-7.383 z-5.433 g01 x-6.106 y-7.277 z-5.444 g01 x-6.233 y-7.170 z-5.456 g01 x-6.357 y-7.060 z-5.467 g01 x-6.479 y-6.948 z-5.478 g01 x-6.599 y-6.834 z-5.489 g01 x-6.718 y-6.718 z-5.500 g01 x-6.834 y-6.599 z-5.511 g01 x-6.948 y-6.479 z-5.522 g01 x-7.060 y-6.357 z-5.533 g01 x-7.170 y-6.233 z-5.544 g01 x-7.277 y-6.106 z-5.556 g01 x-7.383 y-5.979 z-5.567 g01 x-7.486 y-5.849 z-5.578 g01 x-7.587 y-5.717 z-5.589 g01 x-7.686 y-5.584 z-5.600 g01 x-7.782 y-5.449 z-5.611 g01 x-7.876 y-5.312 z-5.622 g01 x-7.967 y-5.174 z-5.633 g01 x-8.056 y-5.034 z-5.644 g01 x-8.143 y-4.893 z-5.656 g01 x-8.227 y-4.750 z-5.667 g01 x-8.309 y-4.606 z-5.678 g01 x-8.388 y-4.460 z-5.689 g01 x-8.465 y-4.313 z-5.700 g01 x-8.539 y-4.165 z-5.711 g01 x-8.610 y-4.015 z-5.722 g01 x-8.679 y-3.864 z-5.733 g01 x-8.745 y-3.712 z-5.744 g01 x-8.808 y-3.559 z-5.756 g01 x-8.869 y-3.404 z-5.767 g01 x-8.927 y-3.249 z-5.778 g01 x-8.982 y-3.093 z-5.789 g01 x-9.035 y-2.936 z-5.800 g01 x-9.085 y-2.778 z-5.811 g01 x-9.132 y-2.619 z-5.822 g01 x-9.176 y-2.459 z-5.833 g01 x-9.218 y-2.298 z-5.844 g01 x-9.257 y-2.137 z-5.856 g01 x-9.292 y-1.975 z-5.867 g01 x-9.325 y-1.813 z-5.878 g01 x-9.356 y-1.650 z-5.889 g01 x-9.383 y-1.486 z-5.900 g01 x-9.408 y-1.322 z-5.911 g01 x-9.429 y-1.158 z-5.922 g01 x-9.448 y-0.993 z-5.933 g01 x-9.464 y-0.828 z-5.944 g01 x-9.477 y-0.663 z-5.956 g01 x-9.487 y-0.497 z-5.967 g01 x-9.494 y-0.332 z-5.978 g01 x-9.499 y-0.166 z-5.989 g01 x-9.500 y-0.000 z-6.000 g01 x-9.499 y0.166 z-6.011 g01 x-9.494 y0.332 z-6.022 g01 x-9.487 y0.497 z-6.033 g01 x-9.477 y0.663 z-6.044 g01 x-9.464 y0.828 z-6.056 g01 x-9.448 y0.993 z-6.067 g01 x-9.429 y1.158 z-6.078 g01 x-9.408 y1.322 z-6.089 g01 x-9.383 y1.486 z-6.100 g01 x-9.356 y1.650 z-6.111 g01 x-9.325 y1.813 z-6.122 g01 x-9.292 y1.975 z-6.133 g01 x-9.257 y2.137 z-6.144 g01 x-9.218 y2.298 z-6.156 g01 x-9.176 y2.459 z-6.167 g01 x-9.132 y2.619 z-6.178 g01 x-9.085 y2.778 z-6.189 g01 x-9.035 y2.936 z-6.200 g01 x-8.982 y3.093 z-6.211 g01 x-8.927 y3.249 z-6.222 g01 x-8.869 y3.404 z-6.233 g01 x-8.808 y3.559 z-6.244 g01 x-8.745 y3.712 z-6.256 g01 x-8.679 y3.864 z-6.267 g01 x-8.610 y4.015 z-6.278 g01 x-8.539 y4.165 z-6.289 g01 x-8.465 y4.313 z-6.300 g01 x-8.388 y4.460 z-6.311 g01 x-8.309 y4.606 z-6.322 g01 x-8.227 y4.750 z-6.333 g01 x-8.143 y4.893 z-6.344 g01 x-8.056 y5.034 z-6.356 g01 x-7.967 y5.174 z-6.367 g01 x-7.876 y5.312 z-6.378 g01 x-7.782 y5.449 z-6.389 g01 x-7.686 y5.584 z-6.400 g01 x-7.587 y5.717 z-6.411 g01 x-7.486 y5.849 z-6.422 g01 x-7.383 y5.979 z-6.433 g01 x-7.277 y6.106 z-6.444 g01 x-7.170 y6.233 z-6.456 g01 x-7.060 y6.357 z-6.467 g01 x-6.948 y6.479 z-6.478 g01 x-6.834 y6.599 z-6.489 g01 x-6.718 y6.718 z-6.500 g01 x-6.599 y6.834 z-6.511 g01 x-6.479 y6.948 z-6.522 g01 x-6.357 y7.060 z-6.533 g01 x-6.233 y7.170 z-6.544 g01 x-6.106 y7.277 z-6.556 g01 x-5.979 y7.383 z-6.567 g01 x-5.849 y7.486 z-6.578 g01 x-5.717 y7.587 z-6.589 g01 x-5.584 y7.686 z-6.600 g01 x-5.449 y7.782 z-6.611 g01 x-5.312 y7.876 z-6.622 g01 x-5.174 y7.967 z-6.633 g01 x-5.034 y8.056 z-6.644 g01 x-4.893 y8.143 z-6.656 g01 x-4.750 y8.227 z-6.667 g01 x-4.606 y8.309 z-6.678 g01 x-4.460 y8.388 z-6.689 g01 x-4.313 y8.465 z-6.700 g01 x-4.165 y8.539 z-6.711 g01 x-4.015 y8.610 z-6.722 g01 x-3.864 y8.679 z-6.733 g01 x-3.712 y8.745 z-6.744 g01 x-3.559 y8.808 z-6.756 g01 x-3.404 y8.869 z-6.767 g01 x-3.249 y8.927 z-6.778 g01 x-3.093 y8.982 z-6.789 g01 x-2.936 y9.035 z-6.800 g01 x-2.778 y9.085 z-6.811 g01 x-2.619 y9.132 z-6.822 g01 x-2.459 y9.176 z-6.833 g01 x-2.298 y9.218 z-6.844 g01 x-2.137 y9.257 z-6.856 g01 x-1.975 y9.292 z-6.867 g01 x-1.813 y9.325 z-6.878 g01 x-1.650 y9.356 z-6.889 g01 x-1.486 y9.383 z-6.900 g01 x-1.322 y9.408 z-6.911 g01 x-1.158 y9.429 z-6.922 g01 x-0.993 y9.448 z-6.933 g01 x-0.828 y9.464 z-6.944 g01 x-0.663 y9.477 z-6.956 g01 x-0.497 y9.487 z-6.967 g01 x-0.332 y9.494 z-6.978 g01 x-0.166 y9.499 z-6.989 g01 x-0.000 y9.500 z-7.000 g01 x0.166 y9.499 z-7.011 g01 x0.332 y9.494 z-7.022 g01 x0.497 y9.487 z-7.033 g01 x0.663 y9.477 z-7.044 g01 x0.828 y9.464 z-7.056 g01 x0.993 y9.448 z-7.067 g01 x1.158 y9.429 z-7.078 g01 x1.322 y9.408 z-7.089 g01 x1.486 y9.383 z-7.100 g01 x1.650 y9.356 z-7.111 g01 x1.813 y9.325 z-7.122 g01 x1.975 y9.292 z-7.133 g01 x2.137 y9.257 z-7.144 g01 x2.298 y9.218 z-7.156 g01 x2.459 y9.176 z-7.167 g01 x2.619 y9.132 z-7.178 g01 x2.778 y9.085 z-7.189 g01 x2.936 y9.035 z-7.200 g01 x3.093 y8.982 z-7.211 g01 x3.249 y8.927 z-7.222 g01 x3.404 y8.869 z-7.233 g01 x3.559 y8.808 z-7.244 g01 x3.712 y8.745 z-7.256 g01 x3.864 y8.679 z-7.267 g01 x4.015 y8.610 z-7.278 g01 x4.165 y8.539 z-7.289 g01 x4.313 y8.465 z-7.300 g01 x4.460 y8.388 z-7.311 g01 x4.606 y8.309 z-7.322 g01 x4.750 y8.227 z-7.333 g01 x4.893 y8.143 z-7.344 g01 x5.034 y8.056 z-7.356 g01 x5.174 y7.967 z-7.367 g01 x5.312 y7.876 z-7.378 g01 x5.449 y7.782 z-7.389 g01 x5.584 y7.686 z-7.400 g01 x5.717 y7.587 z-7.411 g01 x5.849 y7.486 z-7.422 g01 x5.979 y7.383 z-7.433 g01 x6.106 y7.277 z-7.444 g01 x6.233 y7.170 z-7.456 g01 x6.357 y7.060 z-7.467 g01 x6.479 y6.948 z-7.478 g01 x6.599 y6.834 z-7.489 g01 x6.718 y6.718 z-7.500 g01 x6.834 y6.599 z-7.511 g01 x6.948 y6.479 z-7.522 g01 x7.060 y6.357 z-7.533 g01 x7.170 y6.233 z-7.544 g01 x7.277 y6.106 z-7.556 g01 x7.383 y5.979 z-7.567 g01 x7.486 y5.849 z-7.578 g01 x7.587 y5.717 z-7.589 g01 x7.686 y5.584 z-7.600 g01 x7.782 y5.449 z-7.611 g01 x7.876 y5.312 z-7.622 g01 x7.967 y5.174 z-7.633 g01 x8.056 y5.034 z-7.644 g01 x8.143 y4.893 z-7.656 g01 x8.227 y4.750 z-7.667 g01 x8.309 y4.606 z-7.678 g01 x8.388 y4.460 z-7.689 g01 x8.465 y4.313 z-7.700 g01 x8.539 y4.165 z-7.711 g01 x8.610 y4.015 z-7.722 g01 x8.679 y3.864 z-7.733 g01 x8.745 y3.712 z-7.744 g01 x8.808 y3.559 z-7.756 g01 x8.869 y3.404 z-7.767 g01 x8.927 y3.249 z-7.778 g01 x8.982 y3.093 z-7.789 g01 x9.035 y2.936 z-7.800 g01 x9.085 y2.778 z-7.811 g01 x9.132 y2.619 z-7.822 g01 x9.176 y2.459 z-7.833 g01 x9.218 y2.298 z-7.844 g01 x9.257 y2.137 z-7.856 g01 x9.292 y1.975 z-7.867 g01 x9.325 y1.813 z-7.878 g01 x9.356 y1.650 z-7.889 g01 x9.383 y1.486 z-7.900 g01 x9.408 y1.322 z-7.911 g01 x9.429 y1.158 z-7.922 g01 x9.448 y0.993 z-7.933 g01 x9.464 y0.828 z-7.944 g01 x9.477 y0.663 z-7.956 g01 x9.487 y0.497 z-7.967 g01 x9.494 y0.332 z-7.978 g01 x9.499 y0.166 z-7.989 g01 x9.500 y0.000 z-8.000 ;step-over pass: 1 - pitch pass N: 3 ;diameter: 29.000 [mm] g01 x9.499 y-0.166 z-8.011 g01 x9.494 y-0.332 z-8.022 g01 x9.487 y-0.497 z-8.033 g01 x9.477 y-0.663 z-8.044 g01 x9.464 y-0.828 z-8.056 g01 x9.448 y-0.993 z-8.067 g01 x9.429 y-1.158 z-8.078 g01 x9.408 y-1.322 z-8.089 g01 x9.383 y-1.486 z-8.100 g01 x9.356 y-1.650 z-8.111 g01 x9.325 y-1.813 z-8.122 g01 x9.292 y-1.975 z-8.133 g01 x9.257 y-2.137 z-8.144 g01 x9.218 y-2.298 z-8.156 g01 x9.176 y-2.459 z-8.167 g01 x9.132 y-2.619 z-8.178 g01 x9.085 y-2.778 z-8.189 g01 x9.035 y-2.936 z-8.200 g01 x8.982 y-3.093 z-8.211 g01 x8.927 y-3.249 z-8.222 g01 x8.869 y-3.404 z-8.233 g01 x8.808 y-3.559 z-8.244 g01 x8.745 y-3.712 z-8.256 g01 x8.679 y-3.864 z-8.267 g01 x8.610 y-4.015 z-8.278 g01 x8.539 y-4.165 z-8.289 g01 x8.465 y-4.313 z-8.300 g01 x8.388 y-4.460 z-8.311 g01 x8.309 y-4.606 z-8.322 g01 x8.227 y-4.750 z-8.333 g01 x8.143 y-4.893 z-8.344 g01 x8.056 y-5.034 z-8.356 g01 x7.967 y-5.174 z-8.367 g01 x7.876 y-5.312 z-8.378 g01 x7.782 y-5.449 z-8.389 g01 x7.686 y-5.584 z-8.400 g01 x7.587 y-5.717 z-8.411 g01 x7.486 y-5.849 z-8.422 g01 x7.383 y-5.979 z-8.433 g01 x7.277 y-6.106 z-8.444 g01 x7.170 y-6.233 z-8.456 g01 x7.060 y-6.357 z-8.467 g01 x6.948 y-6.479 z-8.478 g01 x6.834 y-6.599 z-8.489 g01 x6.718 y-6.718 z-8.500 g01 x6.599 y-6.834 z-8.511 g01 x6.479 y-6.948 z-8.522 g01 x6.357 y-7.060 z-8.533 g01 x6.233 y-7.170 z-8.544 g01 x6.106 y-7.277 z-8.556 g01 x5.979 y-7.383 z-8.567 g01 x5.849 y-7.486 z-8.578 g01 x5.717 y-7.587 z-8.589 g01 x5.584 y-7.686 z-8.600 g01 x5.449 y-7.782 z-8.611 g01 x5.312 y-7.876 z-8.622 g01 x5.174 y-7.967 z-8.633 g01 x5.034 y-8.056 z-8.644 g01 x4.893 y-8.143 z-8.656 g01 x4.750 y-8.227 z-8.667 g01 x4.606 y-8.309 z-8.678 g01 x4.460 y-8.388 z-8.689 g01 x4.313 y-8.465 z-8.700 g01 x4.165 y-8.539 z-8.711 g01 x4.015 y-8.610 z-8.722 g01 x3.864 y-8.679 z-8.733 g01 x3.712 y-8.745 z-8.744 g01 x3.559 y-8.808 z-8.756 g01 x3.404 y-8.869 z-8.767 g01 x3.249 y-8.927 z-8.778 g01 x3.093 y-8.982 z-8.789 g01 x2.936 y-9.035 z-8.800 g01 x2.778 y-9.085 z-8.811 g01 x2.619 y-9.132 z-8.822 g01 x2.459 y-9.176 z-8.833 g01 x2.298 y-9.218 z-8.844 g01 x2.137 y-9.257 z-8.856 g01 x1.975 y-9.292 z-8.867 g01 x1.813 y-9.325 z-8.878 g01 x1.650 y-9.356 z-8.889 g01 x1.486 y-9.383 z-8.900 g01 x1.322 y-9.408 z-8.911 g01 x1.158 y-9.429 z-8.922 g01 x0.993 y-9.448 z-8.933 g01 x0.828 y-9.464 z-8.944 g01 x0.663 y-9.477 z-8.956 g01 x0.497 y-9.487 z-8.967 g01 x0.332 y-9.494 z-8.978 g01 x0.166 y-9.499 z-8.989 g01 x0.000 y-9.500 z-9.000 g01 x-0.166 y-9.499 z-9.011 g01 x-0.332 y-9.494 z-9.022 g01 x-0.497 y-9.487 z-9.033 g01 x-0.663 y-9.477 z-9.044 g01 x-0.828 y-9.464 z-9.056 g01 x-0.993 y-9.448 z-9.067 g01 x-1.158 y-9.429 z-9.078 g01 x-1.322 y-9.408 z-9.089 g01 x-1.486 y-9.383 z-9.100 g01 x-1.650 y-9.356 z-9.111 g01 x-1.813 y-9.325 z-9.122 g01 x-1.975 y-9.292 z-9.133 g01 x-2.137 y-9.257 z-9.144 g01 x-2.298 y-9.218 z-9.156 g01 x-2.459 y-9.176 z-9.167 g01 x-2.619 y-9.132 z-9.178 g01 x-2.778 y-9.085 z-9.189 g01 x-2.936 y-9.035 z-9.200 g01 x-3.093 y-8.982 z-9.211 g01 x-3.249 y-8.927 z-9.222 g01 x-3.404 y-8.869 z-9.233 g01 x-3.559 y-8.808 z-9.244 g01 x-3.712 y-8.745 z-9.256 g01 x-3.864 y-8.679 z-9.267 g01 x-4.015 y-8.610 z-9.278 g01 x-4.165 y-8.539 z-9.289 g01 x-4.313 y-8.465 z-9.300 g01 x-4.460 y-8.388 z-9.311 g01 x-4.606 y-8.309 z-9.322 g01 x-4.750 y-8.227 z-9.333 g01 x-4.893 y-8.143 z-9.344 g01 x-5.034 y-8.056 z-9.356 g01 x-5.174 y-7.967 z-9.367 g01 x-5.312 y-7.876 z-9.378 g01 x-5.449 y-7.782 z-9.389 g01 x-5.584 y-7.686 z-9.400 g01 x-5.717 y-7.587 z-9.411 g01 x-5.849 y-7.486 z-9.422 g01 x-5.979 y-7.383 z-9.433 g01 x-6.106 y-7.277 z-9.444 g01 x-6.233 y-7.170 z-9.456 g01 x-6.357 y-7.060 z-9.467 g01 x-6.479 y-6.948 z-9.478 g01 x-6.599 y-6.834 z-9.489 g01 x-6.718 y-6.718 z-9.500 g01 x-6.834 y-6.599 z-9.511 g01 x-6.948 y-6.479 z-9.522 g01 x-7.060 y-6.357 z-9.533 g01 x-7.170 y-6.233 z-9.544 g01 x-7.277 y-6.106 z-9.556 g01 x-7.383 y-5.979 z-9.567 g01 x-7.486 y-5.849 z-9.578 g01 x-7.587 y-5.717 z-9.589 g01 x-7.686 y-5.584 z-9.600 g01 x-7.782 y-5.449 z-9.611 g01 x-7.876 y-5.312 z-9.622 g01 x-7.967 y-5.174 z-9.633 g01 x-8.056 y-5.034 z-9.644 g01 x-8.143 y-4.893 z-9.656 g01 x-8.227 y-4.750 z-9.667 g01 x-8.309 y-4.606 z-9.678 g01 x-8.388 y-4.460 z-9.689 g01 x-8.465 y-4.313 z-9.700 g01 x-8.539 y-4.165 z-9.711 g01 x-8.610 y-4.015 z-9.722 g01 x-8.679 y-3.864 z-9.733 g01 x-8.745 y-3.712 z-9.744 g01 x-8.808 y-3.559 z-9.756 g01 x-8.869 y-3.404 z-9.767 g01 x-8.927 y-3.249 z-9.778 g01 x-8.982 y-3.093 z-9.789 g01 x-9.035 y-2.936 z-9.800 g01 x-9.085 y-2.778 z-9.811 g01 x-9.132 y-2.619 z-9.822 g01 x-9.176 y-2.459 z-9.833 g01 x-9.218 y-2.298 z-9.844 g01 x-9.257 y-2.137 z-9.856 g01 x-9.292 y-1.975 z-9.867 g01 x-9.325 y-1.813 z-9.878 g01 x-9.356 y-1.650 z-9.889 g01 x-9.383 y-1.486 z-9.900 g01 x-9.408 y-1.322 z-9.911 g01 x-9.429 y-1.158 z-9.922 g01 x-9.448 y-0.993 z-9.933 g01 x-9.464 y-0.828 z-9.944 g01 x-9.477 y-0.663 z-9.956 g01 x-9.487 y-0.497 z-9.967 g01 x-9.494 y-0.332 z-9.978 g01 x-9.499 y-0.166 z-9.989 g01 x-9.500 y-0.000 z-10.000 g01 x-9.499 y0.166 z-10.011 g01 x-9.494 y0.332 z-10.022 g01 x-9.487 y0.497 z-10.033 g01 x-9.477 y0.663 z-10.044 g01 x-9.464 y0.828 z-10.056 g01 x-9.448 y0.993 z-10.067 g01 x-9.429 y1.158 z-10.078 g01 x-9.408 y1.322 z-10.089 g01 x-9.383 y1.486 z-10.100 g01 x-9.356 y1.650 z-10.111 g01 x-9.325 y1.813 z-10.122 g01 x-9.292 y1.975 z-10.133 g01 x-9.257 y2.137 z-10.144 g01 x-9.218 y2.298 z-10.156 g01 x-9.176 y2.459 z-10.167 g01 x-9.132 y2.619 z-10.178 g01 x-9.085 y2.778 z-10.189 g01 x-9.035 y2.936 z-10.200 g01 x-8.982 y3.093 z-10.211 g01 x-8.927 y3.249 z-10.222 g01 x-8.869 y3.404 z-10.233 g01 x-8.808 y3.559 z-10.244 g01 x-8.745 y3.712 z-10.256 g01 x-8.679 y3.864 z-10.267 g01 x-8.610 y4.015 z-10.278 g01 x-8.539 y4.165 z-10.289 g01 x-8.465 y4.313 z-10.300 g01 x-8.388 y4.460 z-10.311 g01 x-8.309 y4.606 z-10.322 g01 x-8.227 y4.750 z-10.333 g01 x-8.143 y4.893 z-10.344 g01 x-8.056 y5.034 z-10.356 g01 x-7.967 y5.174 z-10.367 g01 x-7.876 y5.312 z-10.378 g01 x-7.782 y5.449 z-10.389 g01 x-7.686 y5.584 z-10.400 g01 x-7.587 y5.717 z-10.411 g01 x-7.486 y5.849 z-10.422 g01 x-7.383 y5.979 z-10.433 g01 x-7.277 y6.106 z-10.444 g01 x-7.170 y6.233 z-10.456 g01 x-7.060 y6.357 z-10.467 g01 x-6.948 y6.479 z-10.478 g01 x-6.834 y6.599 z-10.489 g01 x-6.718 y6.718 z-10.500 g01 x-6.599 y6.834 z-10.511 g01 x-6.479 y6.948 z-10.522 g01 x-6.357 y7.060 z-10.533 g01 x-6.233 y7.170 z-10.544 g01 x-6.106 y7.277 z-10.556 g01 x-5.979 y7.383 z-10.567 g01 x-5.849 y7.486 z-10.578 g01 x-5.717 y7.587 z-10.589 g01 x-5.584 y7.686 z-10.600 g01 x-5.449 y7.782 z-10.611 g01 x-5.312 y7.876 z-10.622 g01 x-5.174 y7.967 z-10.633 g01 x-5.034 y8.056 z-10.644 g01 x-4.893 y8.143 z-10.656 g01 x-4.750 y8.227 z-10.667 g01 x-4.606 y8.309 z-10.678 g01 x-4.460 y8.388 z-10.689 g01 x-4.313 y8.465 z-10.700 g01 x-4.165 y8.539 z-10.711 g01 x-4.015 y8.610 z-10.722 g01 x-3.864 y8.679 z-10.733 g01 x-3.712 y8.745 z-10.744 g01 x-3.559 y8.808 z-10.756 g01 x-3.404 y8.869 z-10.767 g01 x-3.249 y8.927 z-10.778 g01 x-3.093 y8.982 z-10.789 g01 x-2.936 y9.035 z-10.800 g01 x-2.778 y9.085 z-10.811 g01 x-2.619 y9.132 z-10.822 g01 x-2.459 y9.176 z-10.833 g01 x-2.298 y9.218 z-10.844 g01 x-2.137 y9.257 z-10.856 g01 x-1.975 y9.292 z-10.867 g01 x-1.813 y9.325 z-10.878 g01 x-1.650 y9.356 z-10.889 g01 x-1.486 y9.383 z-10.900 g01 x-1.322 y9.408 z-10.911 g01 x-1.158 y9.429 z-10.922 g01 x-0.993 y9.448 z-10.933 g01 x-0.828 y9.464 z-10.944 g01 x-0.663 y9.477 z-10.956 g01 x-0.497 y9.487 z-10.967 g01 x-0.332 y9.494 z-10.978 g01 x-0.166 y9.499 z-10.989 g01 x-0.000 y9.500 z-11.000 g01 x0.166 y9.499 z-11.011 g01 x0.332 y9.494 z-11.022 g01 x0.497 y9.487 z-11.033 g01 x0.663 y9.477 z-11.044 g01 x0.828 y9.464 z-11.056 g01 x0.993 y9.448 z-11.067 g01 x1.158 y9.429 z-11.078 g01 x1.322 y9.408 z-11.089 g01 x1.486 y9.383 z-11.100 g01 x1.650 y9.356 z-11.111 g01 x1.813 y9.325 z-11.122 g01 x1.975 y9.292 z-11.133 g01 x2.137 y9.257 z-11.144 g01 x2.298 y9.218 z-11.156 g01 x2.459 y9.176 z-11.167 g01 x2.619 y9.132 z-11.178 g01 x2.778 y9.085 z-11.189 g01 x2.936 y9.035 z-11.200 g01 x3.093 y8.982 z-11.211 g01 x3.249 y8.927 z-11.222 g01 x3.404 y8.869 z-11.233 g01 x3.559 y8.808 z-11.244 g01 x3.712 y8.745 z-11.256 g01 x3.864 y8.679 z-11.267 g01 x4.015 y8.610 z-11.278 g01 x4.165 y8.539 z-11.289 g01 x4.313 y8.465 z-11.300 g01 x4.460 y8.388 z-11.311 g01 x4.606 y8.309 z-11.322 g01 x4.750 y8.227 z-11.333 g01 x4.893 y8.143 z-11.344 g01 x5.034 y8.056 z-11.356 g01 x5.174 y7.967 z-11.367 g01 x5.312 y7.876 z-11.378 g01 x5.449 y7.782 z-11.389 g01 x5.584 y7.686 z-11.400 g01 x5.717 y7.587 z-11.411 g01 x5.849 y7.486 z-11.422 g01 x5.979 y7.383 z-11.433 g01 x6.106 y7.277 z-11.444 g01 x6.233 y7.170 z-11.456 g01 x6.357 y7.060 z-11.467 g01 x6.479 y6.948 z-11.478 g01 x6.599 y6.834 z-11.489 g01 x6.718 y6.718 z-11.500 g01 x6.834 y6.599 z-11.511 g01 x6.948 y6.479 z-11.522 g01 x7.060 y6.357 z-11.533 g01 x7.170 y6.233 z-11.544 g01 x7.277 y6.106 z-11.556 g01 x7.383 y5.979 z-11.567 g01 x7.486 y5.849 z-11.578 g01 x7.587 y5.717 z-11.589 g01 x7.686 y5.584 z-11.600 g01 x7.782 y5.449 z-11.611 g01 x7.876 y5.312 z-11.622 g01 x7.967 y5.174 z-11.633 g01 x8.056 y5.034 z-11.644 g01 x8.143 y4.893 z-11.656 g01 x8.227 y4.750 z-11.667 g01 x8.309 y4.606 z-11.678 g01 x8.388 y4.460 z-11.689 g01 x8.465 y4.313 z-11.700 g01 x8.539 y4.165 z-11.711 g01 x8.610 y4.015 z-11.722 g01 x8.679 y3.864 z-11.733 g01 x8.745 y3.712 z-11.744 g01 x8.808 y3.559 z-11.756 g01 x8.869 y3.404 z-11.767 g01 x8.927 y3.249 z-11.778 g01 x8.982 y3.093 z-11.789 g01 x9.035 y2.936 z-11.800 g01 x9.085 y2.778 z-11.811 g01 x9.132 y2.619 z-11.822 g01 x9.176 y2.459 z-11.833 g01 x9.218 y2.298 z-11.844 g01 x9.257 y2.137 z-11.856 g01 x9.292 y1.975 z-11.867 g01 x9.325 y1.813 z-11.878 g01 x9.356 y1.650 z-11.889 g01 x9.383 y1.486 z-11.900 g01 x9.408 y1.322 z-11.911 g01 x9.429 y1.158 z-11.922 g01 x9.448 y0.993 z-11.933 g01 x9.464 y0.828 z-11.944 g01 x9.477 y0.663 z-11.956 g01 x9.487 y0.497 z-11.967 g01 x9.494 y0.332 z-11.978 g01 x9.499 y0.166 z-11.989 g01 x9.500 y0.000 z-12.000 ;step-over pass: 1 - pitch pass N: 4 ;diameter: 29.000 [mm] g01 x9.499 y-0.166 z-12.011 g01 x9.494 y-0.332 z-12.022 g01 x9.487 y-0.497 z-12.033 g01 x9.477 y-0.663 z-12.044 g01 x9.464 y-0.828 z-12.056 g01 x9.448 y-0.993 z-12.067 g01 x9.429 y-1.158 z-12.078 g01 x9.408 y-1.322 z-12.089 g01 x9.383 y-1.486 z-12.100 g01 x9.356 y-1.650 z-12.111 g01 x9.325 y-1.813 z-12.122 g01 x9.292 y-1.975 z-12.133 g01 x9.257 y-2.137 z-12.144 g01 x9.218 y-2.298 z-12.156 g01 x9.176 y-2.459 z-12.167 g01 x9.132 y-2.619 z-12.178 g01 x9.085 y-2.778 z-12.189 g01 x9.035 y-2.936 z-12.200 g01 x8.982 y-3.093 z-12.211 g01 x8.927 y-3.249 z-12.222 g01 x8.869 y-3.404 z-12.233 g01 x8.808 y-3.559 z-12.244 g01 x8.745 y-3.712 z-12.256 g01 x8.679 y-3.864 z-12.267 g01 x8.610 y-4.015 z-12.278 g01 x8.539 y-4.165 z-12.289 g01 x8.465 y-4.313 z-12.300 g01 x8.388 y-4.460 z-12.311 g01 x8.309 y-4.606 z-12.322 g01 x8.227 y-4.750 z-12.333 g01 x8.143 y-4.893 z-12.344 g01 x8.056 y-5.034 z-12.356 g01 x7.967 y-5.174 z-12.367 g01 x7.876 y-5.312 z-12.378 g01 x7.782 y-5.449 z-12.389 g01 x7.686 y-5.584 z-12.400 g01 x7.587 y-5.717 z-12.411 g01 x7.486 y-5.849 z-12.422 g01 x7.383 y-5.979 z-12.433 g01 x7.277 y-6.106 z-12.444 g01 x7.170 y-6.233 z-12.456 g01 x7.060 y-6.357 z-12.467 g01 x6.948 y-6.479 z-12.478 g01 x6.834 y-6.599 z-12.489 g01 x6.718 y-6.718 z-12.500 g01 x6.599 y-6.834 z-12.511 g01 x6.479 y-6.948 z-12.522 g01 x6.357 y-7.060 z-12.533 g01 x6.233 y-7.170 z-12.544 g01 x6.106 y-7.277 z-12.556 g01 x5.979 y-7.383 z-12.567 g01 x5.849 y-7.486 z-12.578 g01 x5.717 y-7.587 z-12.589 g01 x5.584 y-7.686 z-12.600 g01 x5.449 y-7.782 z-12.611 g01 x5.312 y-7.876 z-12.622 g01 x5.174 y-7.967 z-12.633 g01 x5.034 y-8.056 z-12.644 g01 x4.893 y-8.143 z-12.656 g01 x4.750 y-8.227 z-12.667 g01 x4.606 y-8.309 z-12.678 g01 x4.460 y-8.388 z-12.689 g01 x4.313 y-8.465 z-12.700 g01 x4.165 y-8.539 z-12.711 g01 x4.015 y-8.610 z-12.722 g01 x3.864 y-8.679 z-12.733 g01 x3.712 y-8.745 z-12.744 g01 x3.559 y-8.808 z-12.756 g01 x3.404 y-8.869 z-12.767 g01 x3.249 y-8.927 z-12.778 g01 x3.093 y-8.982 z-12.789 g01 x2.936 y-9.035 z-12.800 g01 x2.778 y-9.085 z-12.811 g01 x2.619 y-9.132 z-12.822 g01 x2.459 y-9.176 z-12.833 g01 x2.298 y-9.218 z-12.844 g01 x2.137 y-9.257 z-12.856 g01 x1.975 y-9.292 z-12.867 g01 x1.813 y-9.325 z-12.878 g01 x1.650 y-9.356 z-12.889 g01 x1.486 y-9.383 z-12.900 g01 x1.322 y-9.408 z-12.911 g01 x1.158 y-9.429 z-12.922 g01 x0.993 y-9.448 z-12.933 g01 x0.828 y-9.464 z-12.944 g01 x0.663 y-9.477 z-12.956 g01 x0.497 y-9.487 z-12.967 g01 x0.332 y-9.494 z-12.978 g01 x0.166 y-9.499 z-12.989 g01 x0.000 y-9.500 z-13.000 g01 x-0.166 y-9.499 z-13.011 g01 x-0.332 y-9.494 z-13.022 g01 x-0.497 y-9.487 z-13.033 g01 x-0.663 y-9.477 z-13.044 g01 x-0.828 y-9.464 z-13.056 g01 x-0.993 y-9.448 z-13.067 g01 x-1.158 y-9.429 z-13.078 g01 x-1.322 y-9.408 z-13.089 g01 x-1.486 y-9.383 z-13.100 g01 x-1.650 y-9.356 z-13.111 g01 x-1.813 y-9.325 z-13.122 g01 x-1.975 y-9.292 z-13.133 g01 x-2.137 y-9.257 z-13.144 g01 x-2.298 y-9.218 z-13.156 g01 x-2.459 y-9.176 z-13.167 g01 x-2.619 y-9.132 z-13.178 g01 x-2.778 y-9.085 z-13.189 g01 x-2.936 y-9.035 z-13.200 g01 x-3.093 y-8.982 z-13.211 g01 x-3.249 y-8.927 z-13.222 g01 x-3.404 y-8.869 z-13.233 g01 x-3.559 y-8.808 z-13.244 g01 x-3.712 y-8.745 z-13.256 g01 x-3.864 y-8.679 z-13.267 g01 x-4.015 y-8.610 z-13.278 g01 x-4.165 y-8.539 z-13.289 g01 x-4.313 y-8.465 z-13.300 g01 x-4.460 y-8.388 z-13.311 g01 x-4.606 y-8.309 z-13.322 g01 x-4.750 y-8.227 z-13.333 g01 x-4.893 y-8.143 z-13.344 g01 x-5.034 y-8.056 z-13.356 g01 x-5.174 y-7.967 z-13.367 g01 x-5.312 y-7.876 z-13.378 g01 x-5.449 y-7.782 z-13.389 g01 x-5.584 y-7.686 z-13.400 g01 x-5.717 y-7.587 z-13.411 g01 x-5.849 y-7.486 z-13.422 g01 x-5.979 y-7.383 z-13.433 g01 x-6.106 y-7.277 z-13.444 g01 x-6.233 y-7.170 z-13.456 g01 x-6.357 y-7.060 z-13.467 g01 x-6.479 y-6.948 z-13.478 g01 x-6.599 y-6.834 z-13.489 g01 x-6.718 y-6.718 z-13.500 g01 x-6.834 y-6.599 z-13.511 g01 x-6.948 y-6.479 z-13.522 g01 x-7.060 y-6.357 z-13.533 g01 x-7.170 y-6.233 z-13.544 g01 x-7.277 y-6.106 z-13.556 g01 x-7.383 y-5.979 z-13.567 g01 x-7.486 y-5.849 z-13.578 g01 x-7.587 y-5.717 z-13.589 g01 x-7.686 y-5.584 z-13.600 g01 x-7.782 y-5.449 z-13.611 g01 x-7.876 y-5.312 z-13.622 g01 x-7.967 y-5.174 z-13.633 g01 x-8.056 y-5.034 z-13.644 g01 x-8.143 y-4.893 z-13.656 g01 x-8.227 y-4.750 z-13.667 g01 x-8.309 y-4.606 z-13.678 g01 x-8.388 y-4.460 z-13.689 g01 x-8.465 y-4.313 z-13.700 g01 x-8.539 y-4.165 z-13.711 g01 x-8.610 y-4.015 z-13.722 g01 x-8.679 y-3.864 z-13.733 g01 x-8.745 y-3.712 z-13.744 g01 x-8.808 y-3.559 z-13.756 g01 x-8.869 y-3.404 z-13.767 g01 x-8.927 y-3.249 z-13.778 g01 x-8.982 y-3.093 z-13.789 g01 x-9.035 y-2.936 z-13.800 g01 x-9.085 y-2.778 z-13.811 g01 x-9.132 y-2.619 z-13.822 g01 x-9.176 y-2.459 z-13.833 g01 x-9.218 y-2.298 z-13.844 g01 x-9.257 y-2.137 z-13.856 g01 x-9.292 y-1.975 z-13.867 g01 x-9.325 y-1.813 z-13.878 g01 x-9.356 y-1.650 z-13.889 g01 x-9.383 y-1.486 z-13.900 g01 x-9.408 y-1.322 z-13.911 g01 x-9.429 y-1.158 z-13.922 g01 x-9.448 y-0.993 z-13.933 g01 x-9.464 y-0.828 z-13.944 g01 x-9.477 y-0.663 z-13.956 g01 x-9.487 y-0.497 z-13.967 g01 x-9.494 y-0.332 z-13.978 g01 x-9.499 y-0.166 z-13.989 g01 x-9.500 y-0.000 z-14.000 g01 x-9.499 y0.166 z-14.011 g01 x-9.494 y0.332 z-14.022 g01 x-9.487 y0.497 z-14.033 g01 x-9.477 y0.663 z-14.044 g01 x-9.464 y0.828 z-14.056 g01 x-9.448 y0.993 z-14.067 g01 x-9.429 y1.158 z-14.078 g01 x-9.408 y1.322 z-14.089 g01 x-9.383 y1.486 z-14.100 g01 x-9.356 y1.650 z-14.111 g01 x-9.325 y1.813 z-14.122 g01 x-9.292 y1.975 z-14.133 g01 x-9.257 y2.137 z-14.144 g01 x-9.218 y2.298 z-14.156 g01 x-9.176 y2.459 z-14.167 g01 x-9.132 y2.619 z-14.178 g01 x-9.085 y2.778 z-14.189 g01 x-9.035 y2.936 z-14.200 g01 x-8.982 y3.093 z-14.211 g01 x-8.927 y3.249 z-14.222 g01 x-8.869 y3.404 z-14.233 g01 x-8.808 y3.559 z-14.244 g01 x-8.745 y3.712 z-14.256 g01 x-8.679 y3.864 z-14.267 g01 x-8.610 y4.015 z-14.278 g01 x-8.539 y4.165 z-14.289 g01 x-8.465 y4.313 z-14.300 g01 x-8.388 y4.460 z-14.311 g01 x-8.309 y4.606 z-14.322 g01 x-8.227 y4.750 z-14.333 g01 x-8.143 y4.893 z-14.344 g01 x-8.056 y5.034 z-14.356 g01 x-7.967 y5.174 z-14.367 g01 x-7.876 y5.312 z-14.378 g01 x-7.782 y5.449 z-14.389 g01 x-7.686 y5.584 z-14.400 g01 x-7.587 y5.717 z-14.411 g01 x-7.486 y5.849 z-14.422 g01 x-7.383 y5.979 z-14.433 g01 x-7.277 y6.106 z-14.444 g01 x-7.170 y6.233 z-14.456 g01 x-7.060 y6.357 z-14.467 g01 x-6.948 y6.479 z-14.478 g01 x-6.834 y6.599 z-14.489 g01 x-6.718 y6.718 z-14.500 g01 x-6.599 y6.834 z-14.511 g01 x-6.479 y6.948 z-14.522 g01 x-6.357 y7.060 z-14.533 g01 x-6.233 y7.170 z-14.544 g01 x-6.106 y7.277 z-14.556 g01 x-5.979 y7.383 z-14.567 g01 x-5.849 y7.486 z-14.578 g01 x-5.717 y7.587 z-14.589 g01 x-5.584 y7.686 z-14.600 g01 x-5.449 y7.782 z-14.611 g01 x-5.312 y7.876 z-14.622 g01 x-5.174 y7.967 z-14.633 g01 x-5.034 y8.056 z-14.644 g01 x-4.893 y8.143 z-14.656 g01 x-4.750 y8.227 z-14.667 g01 x-4.606 y8.309 z-14.678 g01 x-4.460 y8.388 z-14.689 g01 x-4.313 y8.465 z-14.700 g01 x-4.165 y8.539 z-14.711 g01 x-4.015 y8.610 z-14.722 g01 x-3.864 y8.679 z-14.733 g01 x-3.712 y8.745 z-14.744 g01 x-3.559 y8.808 z-14.756 g01 x-3.404 y8.869 z-14.767 g01 x-3.249 y8.927 z-14.778 g01 x-3.093 y8.982 z-14.789 g01 x-2.936 y9.035 z-14.800 g01 x-2.778 y9.085 z-14.811 g01 x-2.619 y9.132 z-14.822 g01 x-2.459 y9.176 z-14.833 g01 x-2.298 y9.218 z-14.844 g01 x-2.137 y9.257 z-14.856 g01 x-1.975 y9.292 z-14.867 g01 x-1.813 y9.325 z-14.878 g01 x-1.650 y9.356 z-14.889 g01 x-1.486 y9.383 z-14.900 g01 x-1.322 y9.408 z-14.911 g01 x-1.158 y9.429 z-14.922 g01 x-0.993 y9.448 z-14.933 g01 x-0.828 y9.464 z-14.944 g01 x-0.663 y9.477 z-14.956 g01 x-0.497 y9.487 z-14.967 g01 x-0.332 y9.494 z-14.978 g01 x-0.166 y9.499 z-14.989 g01 x-0.000 y9.500 z-15.000 g0 x0 y0 g0 z5 g00 x10.000 y-0.000 ;step-over pass: 2 - pitch pass N: 1 ;diameter: 30.000 [mm] g01 x9.998 y-0.175 z-0.011 g01 x9.994 y-0.349 z-0.022 g01 x9.986 y-0.523 z-0.033 g01 x9.976 y-0.698 z-0.044 g01 x9.962 y-0.872 z-0.056 g01 x9.945 y-1.045 z-0.067 g01 x9.925 y-1.219 z-0.078 g01 x9.903 y-1.392 z-0.089 g01 x9.877 y-1.564 z-0.100 g01 x9.848 y-1.736 z-0.111 g01 x9.816 y-1.908 z-0.122 g01 x9.781 y-2.079 z-0.133 g01 x9.744 y-2.250 z-0.144 g01 x9.703 y-2.419 z-0.156 g01 x9.659 y-2.588 z-0.167 g01 x9.613 y-2.756 z-0.178 g01 x9.563 y-2.924 z-0.189 g01 x9.511 y-3.090 z-0.200 g01 x9.455 y-3.256 z-0.211 g01 x9.397 y-3.420 z-0.222 g01 x9.336 y-3.584 z-0.233 g01 x9.272 y-3.746 z-0.244 g01 x9.205 y-3.907 z-0.256 g01 x9.135 y-4.067 z-0.267 g01 x9.063 y-4.226 z-0.278 g01 x8.988 y-4.384 z-0.289 g01 x8.910 y-4.540 z-0.300 g01 x8.829 y-4.695 z-0.311 g01 x8.746 y-4.848 z-0.322 g01 x8.660 y-5.000 z-0.333 g01 x8.572 y-5.150 z-0.344 g01 x8.480 y-5.299 z-0.356 g01 x8.387 y-5.446 z-0.367 g01 x8.290 y-5.592 z-0.378 g01 x8.192 y-5.736 z-0.389 g01 x8.090 y-5.878 z-0.400 g01 x7.986 y-6.018 z-0.411 g01 x7.880 y-6.157 z-0.422 g01 x7.771 y-6.293 z-0.433 g01 x7.660 y-6.428 z-0.444 g01 x7.547 y-6.561 z-0.456 g01 x7.431 y-6.691 z-0.467 g01 x7.314 y-6.820 z-0.478 g01 x7.193 y-6.947 z-0.489 g01 x7.071 y-7.071 z-0.500 g01 x6.947 y-7.193 z-0.511 g01 x6.820 y-7.314 z-0.522 g01 x6.691 y-7.431 z-0.533 g01 x6.561 y-7.547 z-0.544 g01 x6.428 y-7.660 z-0.556 g01 x6.293 y-7.771 z-0.567 g01 x6.157 y-7.880 z-0.578 g01 x6.018 y-7.986 z-0.589 g01 x5.878 y-8.090 z-0.600 g01 x5.736 y-8.192 z-0.611 g01 x5.592 y-8.290 z-0.622 g01 x5.446 y-8.387 z-0.633 g01 x5.299 y-8.480 z-0.644 g01 x5.150 y-8.572 z-0.656 g01 x5.000 y-8.660 z-0.667 g01 x4.848 y-8.746 z-0.678 g01 x4.695 y-8.829 z-0.689 g01 x4.540 y-8.910 z-0.700 g01 x4.384 y-8.988 z-0.711 g01 x4.226 y-9.063 z-0.722 g01 x4.067 y-9.135 z-0.733 g01 x3.907 y-9.205 z-0.744 g01 x3.746 y-9.272 z-0.756 g01 x3.584 y-9.336 z-0.767 g01 x3.420 y-9.397 z-0.778 g01 x3.256 y-9.455 z-0.789 g01 x3.090 y-9.511 z-0.800 g01 x2.924 y-9.563 z-0.811 g01 x2.756 y-9.613 z-0.822 g01 x2.588 y-9.659 z-0.833 g01 x2.419 y-9.703 z-0.844 g01 x2.250 y-9.744 z-0.856 g01 x2.079 y-9.781 z-0.867 g01 x1.908 y-9.816 z-0.878 g01 x1.736 y-9.848 z-0.889 g01 x1.564 y-9.877 z-0.900 g01 x1.392 y-9.903 z-0.911 g01 x1.219 y-9.925 z-0.922 g01 x1.045 y-9.945 z-0.933 g01 x0.872 y-9.962 z-0.944 g01 x0.698 y-9.976 z-0.956 g01 x0.523 y-9.986 z-0.967 g01 x0.349 y-9.994 z-0.978 g01 x0.175 y-9.998 z-0.989 g01 x0.000 y-10.000 z-1.000 g01 x-0.175 y-9.998 z-1.011 g01 x-0.349 y-9.994 z-1.022 g01 x-0.523 y-9.986 z-1.033 g01 x-0.698 y-9.976 z-1.044 g01 x-0.872 y-9.962 z-1.056 g01 x-1.045 y-9.945 z-1.067 g01 x-1.219 y-9.925 z-1.078 g01 x-1.392 y-9.903 z-1.089 g01 x-1.564 y-9.877 z-1.100 g01 x-1.736 y-9.848 z-1.111 g01 x-1.908 y-9.816 z-1.122 g01 x-2.079 y-9.781 z-1.133 g01 x-2.250 y-9.744 z-1.144 g01 x-2.419 y-9.703 z-1.156 g01 x-2.588 y-9.659 z-1.167 g01 x-2.756 y-9.613 z-1.178 g01 x-2.924 y-9.563 z-1.189 g01 x-3.090 y-9.511 z-1.200 g01 x-3.256 y-9.455 z-1.211 g01 x-3.420 y-9.397 z-1.222 g01 x-3.584 y-9.336 z-1.233 g01 x-3.746 y-9.272 z-1.244 g01 x-3.907 y-9.205 z-1.256 g01 x-4.067 y-9.135 z-1.267 g01 x-4.226 y-9.063 z-1.278 g01 x-4.384 y-8.988 z-1.289 g01 x-4.540 y-8.910 z-1.300 g01 x-4.695 y-8.829 z-1.311 g01 x-4.848 y-8.746 z-1.322 g01 x-5.000 y-8.660 z-1.333 g01 x-5.150 y-8.572 z-1.344 g01 x-5.299 y-8.480 z-1.356 g01 x-5.446 y-8.387 z-1.367 g01 x-5.592 y-8.290 z-1.378 g01 x-5.736 y-8.192 z-1.389 g01 x-5.878 y-8.090 z-1.400 g01 x-6.018 y-7.986 z-1.411 g01 x-6.157 y-7.880 z-1.422 g01 x-6.293 y-7.771 z-1.433 g01 x-6.428 y-7.660 z-1.444 g01 x-6.561 y-7.547 z-1.456 g01 x-6.691 y-7.431 z-1.467 g01 x-6.820 y-7.314 z-1.478 g01 x-6.947 y-7.193 z-1.489 g01 x-7.071 y-7.071 z-1.500 g01 x-7.193 y-6.947 z-1.511 g01 x-7.314 y-6.820 z-1.522 g01 x-7.431 y-6.691 z-1.533 g01 x-7.547 y-6.561 z-1.544 g01 x-7.660 y-6.428 z-1.556 g01 x-7.771 y-6.293 z-1.567 g01 x-7.880 y-6.157 z-1.578 g01 x-7.986 y-6.018 z-1.589 g01 x-8.090 y-5.878 z-1.600 g01 x-8.192 y-5.736 z-1.611 g01 x-8.290 y-5.592 z-1.622 g01 x-8.387 y-5.446 z-1.633 g01 x-8.480 y-5.299 z-1.644 g01 x-8.572 y-5.150 z-1.656 g01 x-8.660 y-5.000 z-1.667 g01 x-8.746 y-4.848 z-1.678 g01 x-8.829 y-4.695 z-1.689 g01 x-8.910 y-4.540 z-1.700 g01 x-8.988 y-4.384 z-1.711 g01 x-9.063 y-4.226 z-1.722 g01 x-9.135 y-4.067 z-1.733 g01 x-9.205 y-3.907 z-1.744 g01 x-9.272 y-3.746 z-1.756 g01 x-9.336 y-3.584 z-1.767 g01 x-9.397 y-3.420 z-1.778 g01 x-9.455 y-3.256 z-1.789 g01 x-9.511 y-3.090 z-1.800 g01 x-9.563 y-2.924 z-1.811 g01 x-9.613 y-2.756 z-1.822 g01 x-9.659 y-2.588 z-1.833 g01 x-9.703 y-2.419 z-1.844 g01 x-9.744 y-2.250 z-1.856 g01 x-9.781 y-2.079 z-1.867 g01 x-9.816 y-1.908 z-1.878 g01 x-9.848 y-1.736 z-1.889 g01 x-9.877 y-1.564 z-1.900 g01 x-9.903 y-1.392 z-1.911 g01 x-9.925 y-1.219 z-1.922 g01 x-9.945 y-1.045 z-1.933 g01 x-9.962 y-0.872 z-1.944 g01 x-9.976 y-0.698 z-1.956 g01 x-9.986 y-0.523 z-1.967 g01 x-9.994 y-0.349 z-1.978 g01 x-9.998 y-0.175 z-1.989 g01 x-10.000 y-0.000 z-2.000 g01 x-9.998 y0.175 z-2.011 g01 x-9.994 y0.349 z-2.022 g01 x-9.986 y0.523 z-2.033 g01 x-9.976 y0.698 z-2.044 g01 x-9.962 y0.872 z-2.056 g01 x-9.945 y1.045 z-2.067 g01 x-9.925 y1.219 z-2.078 g01 x-9.903 y1.392 z-2.089 g01 x-9.877 y1.564 z-2.100 g01 x-9.848 y1.736 z-2.111 g01 x-9.816 y1.908 z-2.122 g01 x-9.781 y2.079 z-2.133 g01 x-9.744 y2.250 z-2.144 g01 x-9.703 y2.419 z-2.156 g01 x-9.659 y2.588 z-2.167 g01 x-9.613 y2.756 z-2.178 g01 x-9.563 y2.924 z-2.189 g01 x-9.511 y3.090 z-2.200 g01 x-9.455 y3.256 z-2.211 g01 x-9.397 y3.420 z-2.222 g01 x-9.336 y3.584 z-2.233 g01 x-9.272 y3.746 z-2.244 g01 x-9.205 y3.907 z-2.256 g01 x-9.135 y4.067 z-2.267 g01 x-9.063 y4.226 z-2.278 g01 x-8.988 y4.384 z-2.289 g01 x-8.910 y4.540 z-2.300 g01 x-8.829 y4.695 z-2.311 g01 x-8.746 y4.848 z-2.322 g01 x-8.660 y5.000 z-2.333 g01 x-8.572 y5.150 z-2.344 g01 x-8.480 y5.299 z-2.356 g01 x-8.387 y5.446 z-2.367 g01 x-8.290 y5.592 z-2.378 g01 x-8.192 y5.736 z-2.389 g01 x-8.090 y5.878 z-2.400 g01 x-7.986 y6.018 z-2.411 g01 x-7.880 y6.157 z-2.422 g01 x-7.771 y6.293 z-2.433 g01 x-7.660 y6.428 z-2.444 g01 x-7.547 y6.561 z-2.456 g01 x-7.431 y6.691 z-2.467 g01 x-7.314 y6.820 z-2.478 g01 x-7.193 y6.947 z-2.489 g01 x-7.071 y7.071 z-2.500 g01 x-6.947 y7.193 z-2.511 g01 x-6.820 y7.314 z-2.522 g01 x-6.691 y7.431 z-2.533 g01 x-6.561 y7.547 z-2.544 g01 x-6.428 y7.660 z-2.556 g01 x-6.293 y7.771 z-2.567 g01 x-6.157 y7.880 z-2.578 g01 x-6.018 y7.986 z-2.589 g01 x-5.878 y8.090 z-2.600 g01 x-5.736 y8.192 z-2.611 g01 x-5.592 y8.290 z-2.622 g01 x-5.446 y8.387 z-2.633 g01 x-5.299 y8.480 z-2.644 g01 x-5.150 y8.572 z-2.656 g01 x-5.000 y8.660 z-2.667 g01 x-4.848 y8.746 z-2.678 g01 x-4.695 y8.829 z-2.689 g01 x-4.540 y8.910 z-2.700 g01 x-4.384 y8.988 z-2.711 g01 x-4.226 y9.063 z-2.722 g01 x-4.067 y9.135 z-2.733 g01 x-3.907 y9.205 z-2.744 g01 x-3.746 y9.272 z-2.756 g01 x-3.584 y9.336 z-2.767 g01 x-3.420 y9.397 z-2.778 g01 x-3.256 y9.455 z-2.789 g01 x-3.090 y9.511 z-2.800 g01 x-2.924 y9.563 z-2.811 g01 x-2.756 y9.613 z-2.822 g01 x-2.588 y9.659 z-2.833 g01 x-2.419 y9.703 z-2.844 g01 x-2.250 y9.744 z-2.856 g01 x-2.079 y9.781 z-2.867 g01 x-1.908 y9.816 z-2.878 g01 x-1.736 y9.848 z-2.889 g01 x-1.564 y9.877 z-2.900 g01 x-1.392 y9.903 z-2.911 g01 x-1.219 y9.925 z-2.922 g01 x-1.045 y9.945 z-2.933 g01 x-0.872 y9.962 z-2.944 g01 x-0.698 y9.976 z-2.956 g01 x-0.523 y9.986 z-2.967 g01 x-0.349 y9.994 z-2.978 g01 x-0.175 y9.998 z-2.989 g01 x-0.000 y10.000 z-3.000 g01 x0.175 y9.998 z-3.011 g01 x0.349 y9.994 z-3.022 g01 x0.523 y9.986 z-3.033 g01 x0.698 y9.976 z-3.044 g01 x0.872 y9.962 z-3.056 g01 x1.045 y9.945 z-3.067 g01 x1.219 y9.925 z-3.078 g01 x1.392 y9.903 z-3.089 g01 x1.564 y9.877 z-3.100 g01 x1.736 y9.848 z-3.111 g01 x1.908 y9.816 z-3.122 g01 x2.079 y9.781 z-3.133 g01 x2.250 y9.744 z-3.144 g01 x2.419 y9.703 z-3.156 g01 x2.588 y9.659 z-3.167 g01 x2.756 y9.613 z-3.178 g01 x2.924 y9.563 z-3.189 g01 x3.090 y9.511 z-3.200 g01 x3.256 y9.455 z-3.211 g01 x3.420 y9.397 z-3.222 g01 x3.584 y9.336 z-3.233 g01 x3.746 y9.272 z-3.244 g01 x3.907 y9.205 z-3.256 g01 x4.067 y9.135 z-3.267 g01 x4.226 y9.063 z-3.278 g01 x4.384 y8.988 z-3.289 g01 x4.540 y8.910 z-3.300 g01 x4.695 y8.829 z-3.311 g01 x4.848 y8.746 z-3.322 g01 x5.000 y8.660 z-3.333 g01 x5.150 y8.572 z-3.344 g01 x5.299 y8.480 z-3.356 g01 x5.446 y8.387 z-3.367 g01 x5.592 y8.290 z-3.378 g01 x5.736 y8.192 z-3.389 g01 x5.878 y8.090 z-3.400 g01 x6.018 y7.986 z-3.411 g01 x6.157 y7.880 z-3.422 g01 x6.293 y7.771 z-3.433 g01 x6.428 y7.660 z-3.444 g01 x6.561 y7.547 z-3.456 g01 x6.691 y7.431 z-3.467 g01 x6.820 y7.314 z-3.478 g01 x6.947 y7.193 z-3.489 g01 x7.071 y7.071 z-3.500 g01 x7.193 y6.947 z-3.511 g01 x7.314 y6.820 z-3.522 g01 x7.431 y6.691 z-3.533 g01 x7.547 y6.561 z-3.544 g01 x7.660 y6.428 z-3.556 g01 x7.771 y6.293 z-3.567 g01 x7.880 y6.157 z-3.578 g01 x7.986 y6.018 z-3.589 g01 x8.090 y5.878 z-3.600 g01 x8.192 y5.736 z-3.611 g01 x8.290 y5.592 z-3.622 g01 x8.387 y5.446 z-3.633 g01 x8.480 y5.299 z-3.644 g01 x8.572 y5.150 z-3.656 g01 x8.660 y5.000 z-3.667 g01 x8.746 y4.848 z-3.678 g01 x8.829 y4.695 z-3.689 g01 x8.910 y4.540 z-3.700 g01 x8.988 y4.384 z-3.711 g01 x9.063 y4.226 z-3.722 g01 x9.135 y4.067 z-3.733 g01 x9.205 y3.907 z-3.744 g01 x9.272 y3.746 z-3.756 g01 x9.336 y3.584 z-3.767 g01 x9.397 y3.420 z-3.778 g01 x9.455 y3.256 z-3.789 g01 x9.511 y3.090 z-3.800 g01 x9.563 y2.924 z-3.811 g01 x9.613 y2.756 z-3.822 g01 x9.659 y2.588 z-3.833 g01 x9.703 y2.419 z-3.844 g01 x9.744 y2.250 z-3.856 g01 x9.781 y2.079 z-3.867 g01 x9.816 y1.908 z-3.878 g01 x9.848 y1.736 z-3.889 g01 x9.877 y1.564 z-3.900 g01 x9.903 y1.392 z-3.911 g01 x9.925 y1.219 z-3.922 g01 x9.945 y1.045 z-3.933 g01 x9.962 y0.872 z-3.944 g01 x9.976 y0.698 z-3.956 g01 x9.986 y0.523 z-3.967 g01 x9.994 y0.349 z-3.978 g01 x9.998 y0.175 z-3.989 g01 x10.000 y0.000 z-4.000 ;step-over pass: 2 - pitch pass N: 2 ;diameter: 30.000 [mm] g01 x9.998 y-0.175 z-4.011 g01 x9.994 y-0.349 z-4.022 g01 x9.986 y-0.523 z-4.033 g01 x9.976 y-0.698 z-4.044 g01 x9.962 y-0.872 z-4.056 g01 x9.945 y-1.045 z-4.067 g01 x9.925 y-1.219 z-4.078 g01 x9.903 y-1.392 z-4.089 g01 x9.877 y-1.564 z-4.100 g01 x9.848 y-1.736 z-4.111 g01 x9.816 y-1.908 z-4.122 g01 x9.781 y-2.079 z-4.133 g01 x9.744 y-2.250 z-4.144 g01 x9.703 y-2.419 z-4.156 g01 x9.659 y-2.588 z-4.167 g01 x9.613 y-2.756 z-4.178 g01 x9.563 y-2.924 z-4.189 g01 x9.511 y-3.090 z-4.200 g01 x9.455 y-3.256 z-4.211 g01 x9.397 y-3.420 z-4.222 g01 x9.336 y-3.584 z-4.233 g01 x9.272 y-3.746 z-4.244 g01 x9.205 y-3.907 z-4.256 g01 x9.135 y-4.067 z-4.267 g01 x9.063 y-4.226 z-4.278 g01 x8.988 y-4.384 z-4.289 g01 x8.910 y-4.540 z-4.300 g01 x8.829 y-4.695 z-4.311 g01 x8.746 y-4.848 z-4.322 g01 x8.660 y-5.000 z-4.333 g01 x8.572 y-5.150 z-4.344 g01 x8.480 y-5.299 z-4.356 g01 x8.387 y-5.446 z-4.367 g01 x8.290 y-5.592 z-4.378 g01 x8.192 y-5.736 z-4.389 g01 x8.090 y-5.878 z-4.400 g01 x7.986 y-6.018 z-4.411 g01 x7.880 y-6.157 z-4.422 g01 x7.771 y-6.293 z-4.433 g01 x7.660 y-6.428 z-4.444 g01 x7.547 y-6.561 z-4.456 g01 x7.431 y-6.691 z-4.467 g01 x7.314 y-6.820 z-4.478 g01 x7.193 y-6.947 z-4.489 g01 x7.071 y-7.071 z-4.500 g01 x6.947 y-7.193 z-4.511 g01 x6.820 y-7.314 z-4.522 g01 x6.691 y-7.431 z-4.533 g01 x6.561 y-7.547 z-4.544 g01 x6.428 y-7.660 z-4.556 g01 x6.293 y-7.771 z-4.567 g01 x6.157 y-7.880 z-4.578 g01 x6.018 y-7.986 z-4.589 g01 x5.878 y-8.090 z-4.600 g01 x5.736 y-8.192 z-4.611 g01 x5.592 y-8.290 z-4.622 g01 x5.446 y-8.387 z-4.633 g01 x5.299 y-8.480 z-4.644 g01 x5.150 y-8.572 z-4.656 g01 x5.000 y-8.660 z-4.667 g01 x4.848 y-8.746 z-4.678 g01 x4.695 y-8.829 z-4.689 g01 x4.540 y-8.910 z-4.700 g01 x4.384 y-8.988 z-4.711 g01 x4.226 y-9.063 z-4.722 g01 x4.067 y-9.135 z-4.733 g01 x3.907 y-9.205 z-4.744 g01 x3.746 y-9.272 z-4.756 g01 x3.584 y-9.336 z-4.767 g01 x3.420 y-9.397 z-4.778 g01 x3.256 y-9.455 z-4.789 g01 x3.090 y-9.511 z-4.800 g01 x2.924 y-9.563 z-4.811 g01 x2.756 y-9.613 z-4.822 g01 x2.588 y-9.659 z-4.833 g01 x2.419 y-9.703 z-4.844 g01 x2.250 y-9.744 z-4.856 g01 x2.079 y-9.781 z-4.867 g01 x1.908 y-9.816 z-4.878 g01 x1.736 y-9.848 z-4.889 g01 x1.564 y-9.877 z-4.900 g01 x1.392 y-9.903 z-4.911 g01 x1.219 y-9.925 z-4.922 g01 x1.045 y-9.945 z-4.933 g01 x0.872 y-9.962 z-4.944 g01 x0.698 y-9.976 z-4.956 g01 x0.523 y-9.986 z-4.967 g01 x0.349 y-9.994 z-4.978 g01 x0.175 y-9.998 z-4.989 g01 x0.000 y-10.000 z-5.000 g01 x-0.175 y-9.998 z-5.011 g01 x-0.349 y-9.994 z-5.022 g01 x-0.523 y-9.986 z-5.033 g01 x-0.698 y-9.976 z-5.044 g01 x-0.872 y-9.962 z-5.056 g01 x-1.045 y-9.945 z-5.067 g01 x-1.219 y-9.925 z-5.078 g01 x-1.392 y-9.903 z-5.089 g01 x-1.564 y-9.877 z-5.100 g01 x-1.736 y-9.848 z-5.111 g01 x-1.908 y-9.816 z-5.122 g01 x-2.079 y-9.781 z-5.133 g01 x-2.250 y-9.744 z-5.144 g01 x-2.419 y-9.703 z-5.156 g01 x-2.588 y-9.659 z-5.167 g01 x-2.756 y-9.613 z-5.178 g01 x-2.924 y-9.563 z-5.189 g01 x-3.090 y-9.511 z-5.200 g01 x-3.256 y-9.455 z-5.211 g01 x-3.420 y-9.397 z-5.222 g01 x-3.584 y-9.336 z-5.233 g01 x-3.746 y-9.272 z-5.244 g01 x-3.907 y-9.205 z-5.256 g01 x-4.067 y-9.135 z-5.267 g01 x-4.226 y-9.063 z-5.278 g01 x-4.384 y-8.988 z-5.289 g01 x-4.540 y-8.910 z-5.300 g01 x-4.695 y-8.829 z-5.311 g01 x-4.848 y-8.746 z-5.322 g01 x-5.000 y-8.660 z-5.333 g01 x-5.150 y-8.572 z-5.344 g01 x-5.299 y-8.480 z-5.356 g01 x-5.446 y-8.387 z-5.367 g01 x-5.592 y-8.290 z-5.378 g01 x-5.736 y-8.192 z-5.389 g01 x-5.878 y-8.090 z-5.400 g01 x-6.018 y-7.986 z-5.411 g01 x-6.157 y-7.880 z-5.422 g01 x-6.293 y-7.771 z-5.433 g01 x-6.428 y-7.660 z-5.444 g01 x-6.561 y-7.547 z-5.456 g01 x-6.691 y-7.431 z-5.467 g01 x-6.820 y-7.314 z-5.478 g01 x-6.947 y-7.193 z-5.489 g01 x-7.071 y-7.071 z-5.500 g01 x-7.193 y-6.947 z-5.511 g01 x-7.314 y-6.820 z-5.522 g01 x-7.431 y-6.691 z-5.533 g01 x-7.547 y-6.561 z-5.544 g01 x-7.660 y-6.428 z-5.556 g01 x-7.771 y-6.293 z-5.567 g01 x-7.880 y-6.157 z-5.578 g01 x-7.986 y-6.018 z-5.589 g01 x-8.090 y-5.878 z-5.600 g01 x-8.192 y-5.736 z-5.611 g01 x-8.290 y-5.592 z-5.622 g01 x-8.387 y-5.446 z-5.633 g01 x-8.480 y-5.299 z-5.644 g01 x-8.572 y-5.150 z-5.656 g01 x-8.660 y-5.000 z-5.667 g01 x-8.746 y-4.848 z-5.678 g01 x-8.829 y-4.695 z-5.689 g01 x-8.910 y-4.540 z-5.700 g01 x-8.988 y-4.384 z-5.711 g01 x-9.063 y-4.226 z-5.722 g01 x-9.135 y-4.067 z-5.733 g01 x-9.205 y-3.907 z-5.744 g01 x-9.272 y-3.746 z-5.756 g01 x-9.336 y-3.584 z-5.767 g01 x-9.397 y-3.420 z-5.778 g01 x-9.455 y-3.256 z-5.789 g01 x-9.511 y-3.090 z-5.800 g01 x-9.563 y-2.924 z-5.811 g01 x-9.613 y-2.756 z-5.822 g01 x-9.659 y-2.588 z-5.833 g01 x-9.703 y-2.419 z-5.844 g01 x-9.744 y-2.250 z-5.856 g01 x-9.781 y-2.079 z-5.867 g01 x-9.816 y-1.908 z-5.878 g01 x-9.848 y-1.736 z-5.889 g01 x-9.877 y-1.564 z-5.900 g01 x-9.903 y-1.392 z-5.911 g01 x-9.925 y-1.219 z-5.922 g01 x-9.945 y-1.045 z-5.933 g01 x-9.962 y-0.872 z-5.944 g01 x-9.976 y-0.698 z-5.956 g01 x-9.986 y-0.523 z-5.967 g01 x-9.994 y-0.349 z-5.978 g01 x-9.998 y-0.175 z-5.989 g01 x-10.000 y-0.000 z-6.000 g01 x-9.998 y0.175 z-6.011 g01 x-9.994 y0.349 z-6.022 g01 x-9.986 y0.523 z-6.033 g01 x-9.976 y0.698 z-6.044 g01 x-9.962 y0.872 z-6.056 g01 x-9.945 y1.045 z-6.067 g01 x-9.925 y1.219 z-6.078 g01 x-9.903 y1.392 z-6.089 g01 x-9.877 y1.564 z-6.100 g01 x-9.848 y1.736 z-6.111 g01 x-9.816 y1.908 z-6.122 g01 x-9.781 y2.079 z-6.133 g01 x-9.744 y2.250 z-6.144 g01 x-9.703 y2.419 z-6.156 g01 x-9.659 y2.588 z-6.167 g01 x-9.613 y2.756 z-6.178 g01 x-9.563 y2.924 z-6.189 g01 x-9.511 y3.090 z-6.200 g01 x-9.455 y3.256 z-6.211 g01 x-9.397 y3.420 z-6.222 g01 x-9.336 y3.584 z-6.233 g01 x-9.272 y3.746 z-6.244 g01 x-9.205 y3.907 z-6.256 g01 x-9.135 y4.067 z-6.267 g01 x-9.063 y4.226 z-6.278 g01 x-8.988 y4.384 z-6.289 g01 x-8.910 y4.540 z-6.300 g01 x-8.829 y4.695 z-6.311 g01 x-8.746 y4.848 z-6.322 g01 x-8.660 y5.000 z-6.333 g01 x-8.572 y5.150 z-6.344 g01 x-8.480 y5.299 z-6.356 g01 x-8.387 y5.446 z-6.367 g01 x-8.290 y5.592 z-6.378 g01 x-8.192 y5.736 z-6.389 g01 x-8.090 y5.878 z-6.400 g01 x-7.986 y6.018 z-6.411 g01 x-7.880 y6.157 z-6.422 g01 x-7.771 y6.293 z-6.433 g01 x-7.660 y6.428 z-6.444 g01 x-7.547 y6.561 z-6.456 g01 x-7.431 y6.691 z-6.467 g01 x-7.314 y6.820 z-6.478 g01 x-7.193 y6.947 z-6.489 g01 x-7.071 y7.071 z-6.500 g01 x-6.947 y7.193 z-6.511 g01 x-6.820 y7.314 z-6.522 g01 x-6.691 y7.431 z-6.533 g01 x-6.561 y7.547 z-6.544 g01 x-6.428 y7.660 z-6.556 g01 x-6.293 y7.771 z-6.567 g01 x-6.157 y7.880 z-6.578 g01 x-6.018 y7.986 z-6.589 g01 x-5.878 y8.090 z-6.600 g01 x-5.736 y8.192 z-6.611 g01 x-5.592 y8.290 z-6.622 g01 x-5.446 y8.387 z-6.633 g01 x-5.299 y8.480 z-6.644 g01 x-5.150 y8.572 z-6.656 g01 x-5.000 y8.660 z-6.667 g01 x-4.848 y8.746 z-6.678 g01 x-4.695 y8.829 z-6.689 g01 x-4.540 y8.910 z-6.700 g01 x-4.384 y8.988 z-6.711 g01 x-4.226 y9.063 z-6.722 g01 x-4.067 y9.135 z-6.733 g01 x-3.907 y9.205 z-6.744 g01 x-3.746 y9.272 z-6.756 g01 x-3.584 y9.336 z-6.767 g01 x-3.420 y9.397 z-6.778 g01 x-3.256 y9.455 z-6.789 g01 x-3.090 y9.511 z-6.800 g01 x-2.924 y9.563 z-6.811 g01 x-2.756 y9.613 z-6.822 g01 x-2.588 y9.659 z-6.833 g01 x-2.419 y9.703 z-6.844 g01 x-2.250 y9.744 z-6.856 g01 x-2.079 y9.781 z-6.867 g01 x-1.908 y9.816 z-6.878 g01 x-1.736 y9.848 z-6.889 g01 x-1.564 y9.877 z-6.900 g01 x-1.392 y9.903 z-6.911 g01 x-1.219 y9.925 z-6.922 g01 x-1.045 y9.945 z-6.933 g01 x-0.872 y9.962 z-6.944 g01 x-0.698 y9.976 z-6.956 g01 x-0.523 y9.986 z-6.967 g01 x-0.349 y9.994 z-6.978 g01 x-0.175 y9.998 z-6.989 g01 x-0.000 y10.000 z-7.000 g01 x0.175 y9.998 z-7.011 g01 x0.349 y9.994 z-7.022 g01 x0.523 y9.986 z-7.033 g01 x0.698 y9.976 z-7.044 g01 x0.872 y9.962 z-7.056 g01 x1.045 y9.945 z-7.067 g01 x1.219 y9.925 z-7.078 g01 x1.392 y9.903 z-7.089 g01 x1.564 y9.877 z-7.100 g01 x1.736 y9.848 z-7.111 g01 x1.908 y9.816 z-7.122 g01 x2.079 y9.781 z-7.133 g01 x2.250 y9.744 z-7.144 g01 x2.419 y9.703 z-7.156 g01 x2.588 y9.659 z-7.167 g01 x2.756 y9.613 z-7.178 g01 x2.924 y9.563 z-7.189 g01 x3.090 y9.511 z-7.200 g01 x3.256 y9.455 z-7.211 g01 x3.420 y9.397 z-7.222 g01 x3.584 y9.336 z-7.233 g01 x3.746 y9.272 z-7.244 g01 x3.907 y9.205 z-7.256 g01 x4.067 y9.135 z-7.267 g01 x4.226 y9.063 z-7.278 g01 x4.384 y8.988 z-7.289 g01 x4.540 y8.910 z-7.300 g01 x4.695 y8.829 z-7.311 g01 x4.848 y8.746 z-7.322 g01 x5.000 y8.660 z-7.333 g01 x5.150 y8.572 z-7.344 g01 x5.299 y8.480 z-7.356 g01 x5.446 y8.387 z-7.367 g01 x5.592 y8.290 z-7.378 g01 x5.736 y8.192 z-7.389 g01 x5.878 y8.090 z-7.400 g01 x6.018 y7.986 z-7.411 g01 x6.157 y7.880 z-7.422 g01 x6.293 y7.771 z-7.433 g01 x6.428 y7.660 z-7.444 g01 x6.561 y7.547 z-7.456 g01 x6.691 y7.431 z-7.467 g01 x6.820 y7.314 z-7.478 g01 x6.947 y7.193 z-7.489 g01 x7.071 y7.071 z-7.500 g01 x7.193 y6.947 z-7.511 g01 x7.314 y6.820 z-7.522 g01 x7.431 y6.691 z-7.533 g01 x7.547 y6.561 z-7.544 g01 x7.660 y6.428 z-7.556 g01 x7.771 y6.293 z-7.567 g01 x7.880 y6.157 z-7.578 g01 x7.986 y6.018 z-7.589 g01 x8.090 y5.878 z-7.600 g01 x8.192 y5.736 z-7.611 g01 x8.290 y5.592 z-7.622 g01 x8.387 y5.446 z-7.633 g01 x8.480 y5.299 z-7.644 g01 x8.572 y5.150 z-7.656 g01 x8.660 y5.000 z-7.667 g01 x8.746 y4.848 z-7.678 g01 x8.829 y4.695 z-7.689 g01 x8.910 y4.540 z-7.700 g01 x8.988 y4.384 z-7.711 g01 x9.063 y4.226 z-7.722 g01 x9.135 y4.067 z-7.733 g01 x9.205 y3.907 z-7.744 g01 x9.272 y3.746 z-7.756 g01 x9.336 y3.584 z-7.767 g01 x9.397 y3.420 z-7.778 g01 x9.455 y3.256 z-7.789 g01 x9.511 y3.090 z-7.800 g01 x9.563 y2.924 z-7.811 g01 x9.613 y2.756 z-7.822 g01 x9.659 y2.588 z-7.833 g01 x9.703 y2.419 z-7.844 g01 x9.744 y2.250 z-7.856 g01 x9.781 y2.079 z-7.867 g01 x9.816 y1.908 z-7.878 g01 x9.848 y1.736 z-7.889 g01 x9.877 y1.564 z-7.900 g01 x9.903 y1.392 z-7.911 g01 x9.925 y1.219 z-7.922 g01 x9.945 y1.045 z-7.933 g01 x9.962 y0.872 z-7.944 g01 x9.976 y0.698 z-7.956 g01 x9.986 y0.523 z-7.967 g01 x9.994 y0.349 z-7.978 g01 x9.998 y0.175 z-7.989 g01 x10.000 y0.000 z-8.000 ;step-over pass: 2 - pitch pass N: 3 ;diameter: 30.000 [mm] g01 x9.998 y-0.175 z-8.011 g01 x9.994 y-0.349 z-8.022 g01 x9.986 y-0.523 z-8.033 g01 x9.976 y-0.698 z-8.044 g01 x9.962 y-0.872 z-8.056 g01 x9.945 y-1.045 z-8.067 g01 x9.925 y-1.219 z-8.078 g01 x9.903 y-1.392 z-8.089 g01 x9.877 y-1.564 z-8.100 g01 x9.848 y-1.736 z-8.111 g01 x9.816 y-1.908 z-8.122 g01 x9.781 y-2.079 z-8.133 g01 x9.744 y-2.250 z-8.144 g01 x9.703 y-2.419 z-8.156 g01 x9.659 y-2.588 z-8.167 g01 x9.613 y-2.756 z-8.178 g01 x9.563 y-2.924 z-8.189 g01 x9.511 y-3.090 z-8.200 g01 x9.455 y-3.256 z-8.211 g01 x9.397 y-3.420 z-8.222 g01 x9.336 y-3.584 z-8.233 g01 x9.272 y-3.746 z-8.244 g01 x9.205 y-3.907 z-8.256 g01 x9.135 y-4.067 z-8.267 g01 x9.063 y-4.226 z-8.278 g01 x8.988 y-4.384 z-8.289 g01 x8.910 y-4.540 z-8.300 g01 x8.829 y-4.695 z-8.311 g01 x8.746 y-4.848 z-8.322 g01 x8.660 y-5.000 z-8.333 g01 x8.572 y-5.150 z-8.344 g01 x8.480 y-5.299 z-8.356 g01 x8.387 y-5.446 z-8.367 g01 x8.290 y-5.592 z-8.378 g01 x8.192 y-5.736 z-8.389 g01 x8.090 y-5.878 z-8.400 g01 x7.986 y-6.018 z-8.411 g01 x7.880 y-6.157 z-8.422 g01 x7.771 y-6.293 z-8.433 g01 x7.660 y-6.428 z-8.444 g01 x7.547 y-6.561 z-8.456 g01 x7.431 y-6.691 z-8.467 g01 x7.314 y-6.820 z-8.478 g01 x7.193 y-6.947 z-8.489 g01 x7.071 y-7.071 z-8.500 g01 x6.947 y-7.193 z-8.511 g01 x6.820 y-7.314 z-8.522 g01 x6.691 y-7.431 z-8.533 g01 x6.561 y-7.547 z-8.544 g01 x6.428 y-7.660 z-8.556 g01 x6.293 y-7.771 z-8.567 g01 x6.157 y-7.880 z-8.578 g01 x6.018 y-7.986 z-8.589 g01 x5.878 y-8.090 z-8.600 g01 x5.736 y-8.192 z-8.611 g01 x5.592 y-8.290 z-8.622 g01 x5.446 y-8.387 z-8.633 g01 x5.299 y-8.480 z-8.644 g01 x5.150 y-8.572 z-8.656 g01 x5.000 y-8.660 z-8.667 g01 x4.848 y-8.746 z-8.678 g01 x4.695 y-8.829 z-8.689 g01 x4.540 y-8.910 z-8.700 g01 x4.384 y-8.988 z-8.711 g01 x4.226 y-9.063 z-8.722 g01 x4.067 y-9.135 z-8.733 g01 x3.907 y-9.205 z-8.744 g01 x3.746 y-9.272 z-8.756 g01 x3.584 y-9.336 z-8.767 g01 x3.420 y-9.397 z-8.778 g01 x3.256 y-9.455 z-8.789 g01 x3.090 y-9.511 z-8.800 g01 x2.924 y-9.563 z-8.811 g01 x2.756 y-9.613 z-8.822 g01 x2.588 y-9.659 z-8.833 g01 x2.419 y-9.703 z-8.844 g01 x2.250 y-9.744 z-8.856 g01 x2.079 y-9.781 z-8.867 g01 x1.908 y-9.816 z-8.878 g01 x1.736 y-9.848 z-8.889 g01 x1.564 y-9.877 z-8.900 g01 x1.392 y-9.903 z-8.911 g01 x1.219 y-9.925 z-8.922 g01 x1.045 y-9.945 z-8.933 g01 x0.872 y-9.962 z-8.944 g01 x0.698 y-9.976 z-8.956 g01 x0.523 y-9.986 z-8.967 g01 x0.349 y-9.994 z-8.978 g01 x0.175 y-9.998 z-8.989 g01 x0.000 y-10.000 z-9.000 g01 x-0.175 y-9.998 z-9.011 g01 x-0.349 y-9.994 z-9.022 g01 x-0.523 y-9.986 z-9.033 g01 x-0.698 y-9.976 z-9.044 g01 x-0.872 y-9.962 z-9.056 g01 x-1.045 y-9.945 z-9.067 g01 x-1.219 y-9.925 z-9.078 g01 x-1.392 y-9.903 z-9.089 g01 x-1.564 y-9.877 z-9.100 g01 x-1.736 y-9.848 z-9.111 g01 x-1.908 y-9.816 z-9.122 g01 x-2.079 y-9.781 z-9.133 g01 x-2.250 y-9.744 z-9.144 g01 x-2.419 y-9.703 z-9.156 g01 x-2.588 y-9.659 z-9.167 g01 x-2.756 y-9.613 z-9.178 g01 x-2.924 y-9.563 z-9.189 g01 x-3.090 y-9.511 z-9.200 g01 x-3.256 y-9.455 z-9.211 g01 x-3.420 y-9.397 z-9.222 g01 x-3.584 y-9.336 z-9.233 g01 x-3.746 y-9.272 z-9.244 g01 x-3.907 y-9.205 z-9.256 g01 x-4.067 y-9.135 z-9.267 g01 x-4.226 y-9.063 z-9.278 g01 x-4.384 y-8.988 z-9.289 g01 x-4.540 y-8.910 z-9.300 g01 x-4.695 y-8.829 z-9.311 g01 x-4.848 y-8.746 z-9.322 g01 x-5.000 y-8.660 z-9.333 g01 x-5.150 y-8.572 z-9.344 g01 x-5.299 y-8.480 z-9.356 g01 x-5.446 y-8.387 z-9.367 g01 x-5.592 y-8.290 z-9.378 g01 x-5.736 y-8.192 z-9.389 g01 x-5.878 y-8.090 z-9.400 g01 x-6.018 y-7.986 z-9.411 g01 x-6.157 y-7.880 z-9.422 g01 x-6.293 y-7.771 z-9.433 g01 x-6.428 y-7.660 z-9.444 g01 x-6.561 y-7.547 z-9.456 g01 x-6.691 y-7.431 z-9.467 g01 x-6.820 y-7.314 z-9.478 g01 x-6.947 y-7.193 z-9.489 g01 x-7.071 y-7.071 z-9.500 g01 x-7.193 y-6.947 z-9.511 g01 x-7.314 y-6.820 z-9.522 g01 x-7.431 y-6.691 z-9.533 g01 x-7.547 y-6.561 z-9.544 g01 x-7.660 y-6.428 z-9.556 g01 x-7.771 y-6.293 z-9.567 g01 x-7.880 y-6.157 z-9.578 g01 x-7.986 y-6.018 z-9.589 g01 x-8.090 y-5.878 z-9.600 g01 x-8.192 y-5.736 z-9.611 g01 x-8.290 y-5.592 z-9.622 g01 x-8.387 y-5.446 z-9.633 g01 x-8.480 y-5.299 z-9.644 g01 x-8.572 y-5.150 z-9.656 g01 x-8.660 y-5.000 z-9.667 g01 x-8.746 y-4.848 z-9.678 g01 x-8.829 y-4.695 z-9.689 g01 x-8.910 y-4.540 z-9.700 g01 x-8.988 y-4.384 z-9.711 g01 x-9.063 y-4.226 z-9.722 g01 x-9.135 y-4.067 z-9.733 g01 x-9.205 y-3.907 z-9.744 g01 x-9.272 y-3.746 z-9.756 g01 x-9.336 y-3.584 z-9.767 g01 x-9.397 y-3.420 z-9.778 g01 x-9.455 y-3.256 z-9.789 g01 x-9.511 y-3.090 z-9.800 g01 x-9.563 y-2.924 z-9.811 g01 x-9.613 y-2.756 z-9.822 g01 x-9.659 y-2.588 z-9.833 g01 x-9.703 y-2.419 z-9.844 g01 x-9.744 y-2.250 z-9.856 g01 x-9.781 y-2.079 z-9.867 g01 x-9.816 y-1.908 z-9.878 g01 x-9.848 y-1.736 z-9.889 g01 x-9.877 y-1.564 z-9.900 g01 x-9.903 y-1.392 z-9.911 g01 x-9.925 y-1.219 z-9.922 g01 x-9.945 y-1.045 z-9.933 g01 x-9.962 y-0.872 z-9.944 g01 x-9.976 y-0.698 z-9.956 g01 x-9.986 y-0.523 z-9.967 g01 x-9.994 y-0.349 z-9.978 g01 x-9.998 y-0.175 z-9.989 g01 x-10.000 y-0.000 z-10.000 g01 x-9.998 y0.175 z-10.011 g01 x-9.994 y0.349 z-10.022 g01 x-9.986 y0.523 z-10.033 g01 x-9.976 y0.698 z-10.044 g01 x-9.962 y0.872 z-10.056 g01 x-9.945 y1.045 z-10.067 g01 x-9.925 y1.219 z-10.078 g01 x-9.903 y1.392 z-10.089 g01 x-9.877 y1.564 z-10.100 g01 x-9.848 y1.736 z-10.111 g01 x-9.816 y1.908 z-10.122 g01 x-9.781 y2.079 z-10.133 g01 x-9.744 y2.250 z-10.144 g01 x-9.703 y2.419 z-10.156 g01 x-9.659 y2.588 z-10.167 g01 x-9.613 y2.756 z-10.178 g01 x-9.563 y2.924 z-10.189 g01 x-9.511 y3.090 z-10.200 g01 x-9.455 y3.256 z-10.211 g01 x-9.397 y3.420 z-10.222 g01 x-9.336 y3.584 z-10.233 g01 x-9.272 y3.746 z-10.244 g01 x-9.205 y3.907 z-10.256 g01 x-9.135 y4.067 z-10.267 g01 x-9.063 y4.226 z-10.278 g01 x-8.988 y4.384 z-10.289 g01 x-8.910 y4.540 z-10.300 g01 x-8.829 y4.695 z-10.311 g01 x-8.746 y4.848 z-10.322 g01 x-8.660 y5.000 z-10.333 g01 x-8.572 y5.150 z-10.344 g01 x-8.480 y5.299 z-10.356 g01 x-8.387 y5.446 z-10.367 g01 x-8.290 y5.592 z-10.378 g01 x-8.192 y5.736 z-10.389 g01 x-8.090 y5.878 z-10.400 g01 x-7.986 y6.018 z-10.411 g01 x-7.880 y6.157 z-10.422 g01 x-7.771 y6.293 z-10.433 g01 x-7.660 y6.428 z-10.444 g01 x-7.547 y6.561 z-10.456 g01 x-7.431 y6.691 z-10.467 g01 x-7.314 y6.820 z-10.478 g01 x-7.193 y6.947 z-10.489 g01 x-7.071 y7.071 z-10.500 g01 x-6.947 y7.193 z-10.511 g01 x-6.820 y7.314 z-10.522 g01 x-6.691 y7.431 z-10.533 g01 x-6.561 y7.547 z-10.544 g01 x-6.428 y7.660 z-10.556 g01 x-6.293 y7.771 z-10.567 g01 x-6.157 y7.880 z-10.578 g01 x-6.018 y7.986 z-10.589 g01 x-5.878 y8.090 z-10.600 g01 x-5.736 y8.192 z-10.611 g01 x-5.592 y8.290 z-10.622 g01 x-5.446 y8.387 z-10.633 g01 x-5.299 y8.480 z-10.644 g01 x-5.150 y8.572 z-10.656 g01 x-5.000 y8.660 z-10.667 g01 x-4.848 y8.746 z-10.678 g01 x-4.695 y8.829 z-10.689 g01 x-4.540 y8.910 z-10.700 g01 x-4.384 y8.988 z-10.711 g01 x-4.226 y9.063 z-10.722 g01 x-4.067 y9.135 z-10.733 g01 x-3.907 y9.205 z-10.744 g01 x-3.746 y9.272 z-10.756 g01 x-3.584 y9.336 z-10.767 g01 x-3.420 y9.397 z-10.778 g01 x-3.256 y9.455 z-10.789 g01 x-3.090 y9.511 z-10.800 g01 x-2.924 y9.563 z-10.811 g01 x-2.756 y9.613 z-10.822 g01 x-2.588 y9.659 z-10.833 g01 x-2.419 y9.703 z-10.844 g01 x-2.250 y9.744 z-10.856 g01 x-2.079 y9.781 z-10.867 g01 x-1.908 y9.816 z-10.878 g01 x-1.736 y9.848 z-10.889 g01 x-1.564 y9.877 z-10.900 g01 x-1.392 y9.903 z-10.911 g01 x-1.219 y9.925 z-10.922 g01 x-1.045 y9.945 z-10.933 g01 x-0.872 y9.962 z-10.944 g01 x-0.698 y9.976 z-10.956 g01 x-0.523 y9.986 z-10.967 g01 x-0.349 y9.994 z-10.978 g01 x-0.175 y9.998 z-10.989 g01 x-0.000 y10.000 z-11.000 g01 x0.175 y9.998 z-11.011 g01 x0.349 y9.994 z-11.022 g01 x0.523 y9.986 z-11.033 g01 x0.698 y9.976 z-11.044 g01 x0.872 y9.962 z-11.056 g01 x1.045 y9.945 z-11.067 g01 x1.219 y9.925 z-11.078 g01 x1.392 y9.903 z-11.089 g01 x1.564 y9.877 z-11.100 g01 x1.736 y9.848 z-11.111 g01 x1.908 y9.816 z-11.122 g01 x2.079 y9.781 z-11.133 g01 x2.250 y9.744 z-11.144 g01 x2.419 y9.703 z-11.156 g01 x2.588 y9.659 z-11.167 g01 x2.756 y9.613 z-11.178 g01 x2.924 y9.563 z-11.189 g01 x3.090 y9.511 z-11.200 g01 x3.256 y9.455 z-11.211 g01 x3.420 y9.397 z-11.222 g01 x3.584 y9.336 z-11.233 g01 x3.746 y9.272 z-11.244 g01 x3.907 y9.205 z-11.256 g01 x4.067 y9.135 z-11.267 g01 x4.226 y9.063 z-11.278 g01 x4.384 y8.988 z-11.289 g01 x4.540 y8.910 z-11.300 g01 x4.695 y8.829 z-11.311 g01 x4.848 y8.746 z-11.322 g01 x5.000 y8.660 z-11.333 g01 x5.150 y8.572 z-11.344 g01 x5.299 y8.480 z-11.356 g01 x5.446 y8.387 z-11.367 g01 x5.592 y8.290 z-11.378 g01 x5.736 y8.192 z-11.389 g01 x5.878 y8.090 z-11.400 g01 x6.018 y7.986 z-11.411 g01 x6.157 y7.880 z-11.422 g01 x6.293 y7.771 z-11.433 g01 x6.428 y7.660 z-11.444 g01 x6.561 y7.547 z-11.456 g01 x6.691 y7.431 z-11.467 g01 x6.820 y7.314 z-11.478 g01 x6.947 y7.193 z-11.489 g01 x7.071 y7.071 z-11.500 g01 x7.193 y6.947 z-11.511 g01 x7.314 y6.820 z-11.522 g01 x7.431 y6.691 z-11.533 g01 x7.547 y6.561 z-11.544 g01 x7.660 y6.428 z-11.556 g01 x7.771 y6.293 z-11.567 g01 x7.880 y6.157 z-11.578 g01 x7.986 y6.018 z-11.589 g01 x8.090 y5.878 z-11.600 g01 x8.192 y5.736 z-11.611 g01 x8.290 y5.592 z-11.622 g01 x8.387 y5.446 z-11.633 g01 x8.480 y5.299 z-11.644 g01 x8.572 y5.150 z-11.656 g01 x8.660 y5.000 z-11.667 g01 x8.746 y4.848 z-11.678 g01 x8.829 y4.695 z-11.689 g01 x8.910 y4.540 z-11.700 g01 x8.988 y4.384 z-11.711 g01 x9.063 y4.226 z-11.722 g01 x9.135 y4.067 z-11.733 g01 x9.205 y3.907 z-11.744 g01 x9.272 y3.746 z-11.756 g01 x9.336 y3.584 z-11.767 g01 x9.397 y3.420 z-11.778 g01 x9.455 y3.256 z-11.789 g01 x9.511 y3.090 z-11.800 g01 x9.563 y2.924 z-11.811 g01 x9.613 y2.756 z-11.822 g01 x9.659 y2.588 z-11.833 g01 x9.703 y2.419 z-11.844 g01 x9.744 y2.250 z-11.856 g01 x9.781 y2.079 z-11.867 g01 x9.816 y1.908 z-11.878 g01 x9.848 y1.736 z-11.889 g01 x9.877 y1.564 z-11.900 g01 x9.903 y1.392 z-11.911 g01 x9.925 y1.219 z-11.922 g01 x9.945 y1.045 z-11.933 g01 x9.962 y0.872 z-11.944 g01 x9.976 y0.698 z-11.956 g01 x9.986 y0.523 z-11.967 g01 x9.994 y0.349 z-11.978 g01 x9.998 y0.175 z-11.989 g01 x10.000 y0.000 z-12.000 ;step-over pass: 2 - pitch pass N: 4 ;diameter: 30.000 [mm] g01 x9.998 y-0.175 z-12.011 g01 x9.994 y-0.349 z-12.022 g01 x9.986 y-0.523 z-12.033 g01 x9.976 y-0.698 z-12.044 g01 x9.962 y-0.872 z-12.056 g01 x9.945 y-1.045 z-12.067 g01 x9.925 y-1.219 z-12.078 g01 x9.903 y-1.392 z-12.089 g01 x9.877 y-1.564 z-12.100 g01 x9.848 y-1.736 z-12.111 g01 x9.816 y-1.908 z-12.122 g01 x9.781 y-2.079 z-12.133 g01 x9.744 y-2.250 z-12.144 g01 x9.703 y-2.419 z-12.156 g01 x9.659 y-2.588 z-12.167 g01 x9.613 y-2.756 z-12.178 g01 x9.563 y-2.924 z-12.189 g01 x9.511 y-3.090 z-12.200 g01 x9.455 y-3.256 z-12.211 g01 x9.397 y-3.420 z-12.222 g01 x9.336 y-3.584 z-12.233 g01 x9.272 y-3.746 z-12.244 g01 x9.205 y-3.907 z-12.256 g01 x9.135 y-4.067 z-12.267 g01 x9.063 y-4.226 z-12.278 g01 x8.988 y-4.384 z-12.289 g01 x8.910 y-4.540 z-12.300 g01 x8.829 y-4.695 z-12.311 g01 x8.746 y-4.848 z-12.322 g01 x8.660 y-5.000 z-12.333 g01 x8.572 y-5.150 z-12.344 g01 x8.480 y-5.299 z-12.356 g01 x8.387 y-5.446 z-12.367 g01 x8.290 y-5.592 z-12.378 g01 x8.192 y-5.736 z-12.389 g01 x8.090 y-5.878 z-12.400 g01 x7.986 y-6.018 z-12.411 g01 x7.880 y-6.157 z-12.422 g01 x7.771 y-6.293 z-12.433 g01 x7.660 y-6.428 z-12.444 g01 x7.547 y-6.561 z-12.456 g01 x7.431 y-6.691 z-12.467 g01 x7.314 y-6.820 z-12.478 g01 x7.193 y-6.947 z-12.489 g01 x7.071 y-7.071 z-12.500 g01 x6.947 y-7.193 z-12.511 g01 x6.820 y-7.314 z-12.522 g01 x6.691 y-7.431 z-12.533 g01 x6.561 y-7.547 z-12.544 g01 x6.428 y-7.660 z-12.556 g01 x6.293 y-7.771 z-12.567 g01 x6.157 y-7.880 z-12.578 g01 x6.018 y-7.986 z-12.589 g01 x5.878 y-8.090 z-12.600 g01 x5.736 y-8.192 z-12.611 g01 x5.592 y-8.290 z-12.622 g01 x5.446 y-8.387 z-12.633 g01 x5.299 y-8.480 z-12.644 g01 x5.150 y-8.572 z-12.656 g01 x5.000 y-8.660 z-12.667 g01 x4.848 y-8.746 z-12.678 g01 x4.695 y-8.829 z-12.689 g01 x4.540 y-8.910 z-12.700 g01 x4.384 y-8.988 z-12.711 g01 x4.226 y-9.063 z-12.722 g01 x4.067 y-9.135 z-12.733 g01 x3.907 y-9.205 z-12.744 g01 x3.746 y-9.272 z-12.756 g01 x3.584 y-9.336 z-12.767 g01 x3.420 y-9.397 z-12.778 g01 x3.256 y-9.455 z-12.789 g01 x3.090 y-9.511 z-12.800 g01 x2.924 y-9.563 z-12.811 g01 x2.756 y-9.613 z-12.822 g01 x2.588 y-9.659 z-12.833 g01 x2.419 y-9.703 z-12.844 g01 x2.250 y-9.744 z-12.856 g01 x2.079 y-9.781 z-12.867 g01 x1.908 y-9.816 z-12.878 g01 x1.736 y-9.848 z-12.889 g01 x1.564 y-9.877 z-12.900 g01 x1.392 y-9.903 z-12.911 g01 x1.219 y-9.925 z-12.922 g01 x1.045 y-9.945 z-12.933 g01 x0.872 y-9.962 z-12.944 g01 x0.698 y-9.976 z-12.956 g01 x0.523 y-9.986 z-12.967 g01 x0.349 y-9.994 z-12.978 g01 x0.175 y-9.998 z-12.989 g01 x0.000 y-10.000 z-13.000 g01 x-0.175 y-9.998 z-13.011 g01 x-0.349 y-9.994 z-13.022 g01 x-0.523 y-9.986 z-13.033 g01 x-0.698 y-9.976 z-13.044 g01 x-0.872 y-9.962 z-13.056 g01 x-1.045 y-9.945 z-13.067 g01 x-1.219 y-9.925 z-13.078 g01 x-1.392 y-9.903 z-13.089 g01 x-1.564 y-9.877 z-13.100 g01 x-1.736 y-9.848 z-13.111 g01 x-1.908 y-9.816 z-13.122 g01 x-2.079 y-9.781 z-13.133 g01 x-2.250 y-9.744 z-13.144 g01 x-2.419 y-9.703 z-13.156 g01 x-2.588 y-9.659 z-13.167 g01 x-2.756 y-9.613 z-13.178 g01 x-2.924 y-9.563 z-13.189 g01 x-3.090 y-9.511 z-13.200 g01 x-3.256 y-9.455 z-13.211 g01 x-3.420 y-9.397 z-13.222 g01 x-3.584 y-9.336 z-13.233 g01 x-3.746 y-9.272 z-13.244 g01 x-3.907 y-9.205 z-13.256 g01 x-4.067 y-9.135 z-13.267 g01 x-4.226 y-9.063 z-13.278 g01 x-4.384 y-8.988 z-13.289 g01 x-4.540 y-8.910 z-13.300 g01 x-4.695 y-8.829 z-13.311 g01 x-4.848 y-8.746 z-13.322 g01 x-5.000 y-8.660 z-13.333 g01 x-5.150 y-8.572 z-13.344 g01 x-5.299 y-8.480 z-13.356 g01 x-5.446 y-8.387 z-13.367 g01 x-5.592 y-8.290 z-13.378 g01 x-5.736 y-8.192 z-13.389 g01 x-5.878 y-8.090 z-13.400 g01 x-6.018 y-7.986 z-13.411 g01 x-6.157 y-7.880 z-13.422 g01 x-6.293 y-7.771 z-13.433 g01 x-6.428 y-7.660 z-13.444 g01 x-6.561 y-7.547 z-13.456 g01 x-6.691 y-7.431 z-13.467 g01 x-6.820 y-7.314 z-13.478 g01 x-6.947 y-7.193 z-13.489 g01 x-7.071 y-7.071 z-13.500 g01 x-7.193 y-6.947 z-13.511 g01 x-7.314 y-6.820 z-13.522 g01 x-7.431 y-6.691 z-13.533 g01 x-7.547 y-6.561 z-13.544 g01 x-7.660 y-6.428 z-13.556 g01 x-7.771 y-6.293 z-13.567 g01 x-7.880 y-6.157 z-13.578 g01 x-7.986 y-6.018 z-13.589 g01 x-8.090 y-5.878 z-13.600 g01 x-8.192 y-5.736 z-13.611 g01 x-8.290 y-5.592 z-13.622 g01 x-8.387 y-5.446 z-13.633 g01 x-8.480 y-5.299 z-13.644 g01 x-8.572 y-5.150 z-13.656 g01 x-8.660 y-5.000 z-13.667 g01 x-8.746 y-4.848 z-13.678 g01 x-8.829 y-4.695 z-13.689 g01 x-8.910 y-4.540 z-13.700 g01 x-8.988 y-4.384 z-13.711 g01 x-9.063 y-4.226 z-13.722 g01 x-9.135 y-4.067 z-13.733 g01 x-9.205 y-3.907 z-13.744 g01 x-9.272 y-3.746 z-13.756 g01 x-9.336 y-3.584 z-13.767 g01 x-9.397 y-3.420 z-13.778 g01 x-9.455 y-3.256 z-13.789 g01 x-9.511 y-3.090 z-13.800 g01 x-9.563 y-2.924 z-13.811 g01 x-9.613 y-2.756 z-13.822 g01 x-9.659 y-2.588 z-13.833 g01 x-9.703 y-2.419 z-13.844 g01 x-9.744 y-2.250 z-13.856 g01 x-9.781 y-2.079 z-13.867 g01 x-9.816 y-1.908 z-13.878 g01 x-9.848 y-1.736 z-13.889 g01 x-9.877 y-1.564 z-13.900 g01 x-9.903 y-1.392 z-13.911 g01 x-9.925 y-1.219 z-13.922 g01 x-9.945 y-1.045 z-13.933 g01 x-9.962 y-0.872 z-13.944 g01 x-9.976 y-0.698 z-13.956 g01 x-9.986 y-0.523 z-13.967 g01 x-9.994 y-0.349 z-13.978 g01 x-9.998 y-0.175 z-13.989 g01 x-10.000 y-0.000 z-14.000 g01 x-9.998 y0.175 z-14.011 g01 x-9.994 y0.349 z-14.022 g01 x-9.986 y0.523 z-14.033 g01 x-9.976 y0.698 z-14.044 g01 x-9.962 y0.872 z-14.056 g01 x-9.945 y1.045 z-14.067 g01 x-9.925 y1.219 z-14.078 g01 x-9.903 y1.392 z-14.089 g01 x-9.877 y1.564 z-14.100 g01 x-9.848 y1.736 z-14.111 g01 x-9.816 y1.908 z-14.122 g01 x-9.781 y2.079 z-14.133 g01 x-9.744 y2.250 z-14.144 g01 x-9.703 y2.419 z-14.156 g01 x-9.659 y2.588 z-14.167 g01 x-9.613 y2.756 z-14.178 g01 x-9.563 y2.924 z-14.189 g01 x-9.511 y3.090 z-14.200 g01 x-9.455 y3.256 z-14.211 g01 x-9.397 y3.420 z-14.222 g01 x-9.336 y3.584 z-14.233 g01 x-9.272 y3.746 z-14.244 g01 x-9.205 y3.907 z-14.256 g01 x-9.135 y4.067 z-14.267 g01 x-9.063 y4.226 z-14.278 g01 x-8.988 y4.384 z-14.289 g01 x-8.910 y4.540 z-14.300 g01 x-8.829 y4.695 z-14.311 g01 x-8.746 y4.848 z-14.322 g01 x-8.660 y5.000 z-14.333 g01 x-8.572 y5.150 z-14.344 g01 x-8.480 y5.299 z-14.356 g01 x-8.387 y5.446 z-14.367 g01 x-8.290 y5.592 z-14.378 g01 x-8.192 y5.736 z-14.389 g01 x-8.090 y5.878 z-14.400 g01 x-7.986 y6.018 z-14.411 g01 x-7.880 y6.157 z-14.422 g01 x-7.771 y6.293 z-14.433 g01 x-7.660 y6.428 z-14.444 g01 x-7.547 y6.561 z-14.456 g01 x-7.431 y6.691 z-14.467 g01 x-7.314 y6.820 z-14.478 g01 x-7.193 y6.947 z-14.489 g01 x-7.071 y7.071 z-14.500 g01 x-6.947 y7.193 z-14.511 g01 x-6.820 y7.314 z-14.522 g01 x-6.691 y7.431 z-14.533 g01 x-6.561 y7.547 z-14.544 g01 x-6.428 y7.660 z-14.556 g01 x-6.293 y7.771 z-14.567 g01 x-6.157 y7.880 z-14.578 g01 x-6.018 y7.986 z-14.589 g01 x-5.878 y8.090 z-14.600 g01 x-5.736 y8.192 z-14.611 g01 x-5.592 y8.290 z-14.622 g01 x-5.446 y8.387 z-14.633 g01 x-5.299 y8.480 z-14.644 g01 x-5.150 y8.572 z-14.656 g01 x-5.000 y8.660 z-14.667 g01 x-4.848 y8.746 z-14.678 g01 x-4.695 y8.829 z-14.689 g01 x-4.540 y8.910 z-14.700 g01 x-4.384 y8.988 z-14.711 g01 x-4.226 y9.063 z-14.722 g01 x-4.067 y9.135 z-14.733 g01 x-3.907 y9.205 z-14.744 g01 x-3.746 y9.272 z-14.756 g01 x-3.584 y9.336 z-14.767 g01 x-3.420 y9.397 z-14.778 g01 x-3.256 y9.455 z-14.789 g01 x-3.090 y9.511 z-14.800 g01 x-2.924 y9.563 z-14.811 g01 x-2.756 y9.613 z-14.822 g01 x-2.588 y9.659 z-14.833 g01 x-2.419 y9.703 z-14.844 g01 x-2.250 y9.744 z-14.856 g01 x-2.079 y9.781 z-14.867 g01 x-1.908 y9.816 z-14.878 g01 x-1.736 y9.848 z-14.889 g01 x-1.564 y9.877 z-14.900 g01 x-1.392 y9.903 z-14.911 g01 x-1.219 y9.925 z-14.922 g01 x-1.045 y9.945 z-14.933 g01 x-0.872 y9.962 z-14.944 g01 x-0.698 y9.976 z-14.956 g01 x-0.523 y9.986 z-14.967 g01 x-0.349 y9.994 z-14.978 g01 x-0.175 y9.998 z-14.989 g01 x-0.000 y10.000 z-15.000 g0 x0 y0 g0 z5 M5 M30
Last edited by cebaldocchi; 01-23-2018 at 10:34 AM. Reason: Add an example of G-Code output by software
Hi- I'd be interested in trying this software- could you please re-post to the dropbox?
[url]www.CNC-Joe.com[/url]
CNC Is Not Just My Passion.. It's My Addiction !!!!
Hello Jon.
Thanks for your answer.
I have done some improvements in my program but Portuguese version.
I have just made a rapid translation for English. There is a lot of mistakes that if you want you can help me to translate.
This video shows my new milling machine running my G-Code generated by this software.
DOWNLOAD LINK:
http://www.m1automacao.com.br/suport...erpolation.zip
I have got more Wizards to generate G-Code for drilling, conical milling...
You can add me: 55 11 99431-8558 whatsapp
HD Video
