guessing here
S4500 M3
G04 X600.
S12000
G04X600.
S18000
G04S600.
I recently had my spindle redone and I'm looking to write a program that turns on the spindle at 4500rpms for 10 minutes then 12000rpms for 10 minutes then 18000rpms for 10 mins.
Anyone have an idea as to how to write the Gcode?
Take your time and do it right, do not rush.
guessing here
S4500 M3
G04 X600.
S12000
G04X600.
S18000
G04S600.
yup.
then put the M5 at the end.
and an M30
I'd also put a T_M6 at the beginning to select a tool you know is safe to run at the 18000rpms (I'm assuming you don't want to run the spindle empty)
This way if there's not a tool in or if there is an unacceptable tool in the machine will correct the problem with no operator intervention.
What kind of machine, this could make a difference in code...
