Need Help! HELP ON RADIUS - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: HELP ON RADIUS
  1. #21
    Dec 2011
    Default Re: HELP ON RADIUS
    maybe try to put the g19 in its own line before the g2?...
  2. #22
    Registered slowdigits2's Avatar
    Nov 2014
    canada
    tried your suggestion same results i'm sure i must be missin g something is it possible because the tool comp is not turned on? or does it not apply in this case?
  3. #23
    Banned
    May 2008
    Please post a drawing, will try to code something for you.
    Jeff
  4. #24
    Dec 2011
    Quote Originally Posted by slowdigits2 View Post
    That was a code I copied off this thread of discussion.I see there is no height offset callup.here is how I would have written it.I am assuming those generic motions are what your looking for.this goes to tool centerline.
    G17 G40 g80
    T3 mo6
    G0 g90 g54 x8.0 y-3.25 s1550 m03
    G43 h03 z1.0
    Z.1
    G01 z-1.875 f25.0
    X-8.0 f7.0
    G19
    G02 y3.25 j3.25 k-2.9375
    G01 x8.0
    G03 y-3.25 j-3.25 k-2.9375
    G01 x7.87
    G0 z10.
  5. #25
    Dec 2011
    Quote Originally Posted by MetalCarpenter View Post
    G17 G40 g80
    T3 mo6
    G43 h03 z1.0
    Z.1
    G01 z-1.875 f25.0
    X-8.0 f7.0
    G19
    G01 x8.0
    G01 x7.87
    G0 z10.
    Try to switch the g2/g3 in your program first to make sure thats not why its alarming out to begin with
  6. #26
    Nov 2014
    canada
    this is just a rectangle 16"x7" this program works fine right up to the radius cut stops with the rad error the pc is 9.625 round which im trying to cut the plate out of there is a picture with the chalk line of whats coming out on the 2nd page of this thread
    thanks
    G17 G20 G40 G80
    G90 G54
    M6 T3*
    M3 S1550*
    G0 X8. Y-3.25
    G0 Z0 1. M08
    G90 G0 X8. Y-3.25 Z-1.875 F5.
    G1 X-8. Y-3.25 F20.
    G2 G19 y3.25 J3.25 K-2.9375
    G1 G17 X8. Y3.25
    G3 G19 y-3.25 J--3.25 K-2.9375
    G1 G17 X7.87
    G0 Z10. M9
    G0 G40 X0 Y3.5
    G91 G28 Z0.
    G91 G28 Y0.
    G90
    M30
    - - - Updated - - -
    tried this it would not even start cutting
  7. #27
    Dec 2014
    THIS IS HOW I'D DO IT :
    G17 G20 G40 G80
    G90 G54
    M6 T3
    M3 S1550
    G0 Z0.8 M08
    G90 G0 X8. Y-3.25
    Z-0.875 F5. (REMOVED 'D2')
    G1 G41 D2 X-8. Y-3.25 (ADDED 'D2')
    G19 (ADDED)
    G2 Y3.25 R4.8125 (REMOVED 'G1' - CONFLICT WITH 'G2' - REMOVED 'Y-3.25) ( I THINK IT SHOULD BE 'G3')(MAYBE MISSING 'Z' ON ABOVE LINE ???)
    G17
    G1 X8. Y3.25
    G2 Y-3.25 R4.8125 (SAME AS ABOVE NOTES )
    G17
    G1X7.87
    G0 Z10. M9
    G0 G40 X0 Y3.5
    G91 G28 Z0.
    G91 G28 Y0.
    G90
    M30
    Joe Elson - Engineering
    email: jelson@monitorsinmotion.com
  8. #28
    Dec 2014
    METALCARPENTER IS CORRECT :
    Use g19 to arc in yz axis.use ijk when programming radius is my suggestion not R...trust me.k is center of arc in
    Z axis, j is center of arc in y axis.
  9. #29
    Nov 2014
    canada
    sorry i have been super busy i have tried this latest code i get illegal address at the first arc, this seems alot more complicated than it should be is it possible im doing something wrong i really apprecate everyones help i have treied using G2 and G3 same problem Thanks Guys
HELP ON RADIUS
HELP ON RADIUS
