3axis and 4axis
Results 1 to 7 of 7
Thread: 3axis and 4axis
    Mar 2011
    Italy
    Default 3axis and 4axis
    Hi everyone, I'm about to buy my very first hobbistic cnc machine. I need some advice from the kind of you that will replay. Budget money is 2000 euros. Should I go for a 4axis (rotary) or 3axis? I mean, can a 4axis machine be used to handle a project that requires a 3axis machine? My pc doesn't have a parallel port, can an adaptor do the job? Thank you and sorry for these silly questions!
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: 3axis and 4axis
    A USB to parallel port adaptor made for printers will not work
    Motion controllers like UC100 or Smooth stepper that emulates a printerport will
    which CNC machines have you been looking at ?
    John
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi Shadow - You get a 4th axis (rotary axis I presume ) if you need one. If you are not going to do rotary work then 3 axis is the go. I recommend you get a system that uses the USB port not the printer port. $2000euro gets you a lot of hobby machine. What sort of things do you want to make? Peter
    Mar 2011
    Italy
    Hi! I was aware of this "parallel" or "usb" problem. I saw this machine ht*ps://w*w.youtube.com/watch?v=OFePQIMNwSo and I was wondering if I should buy a similar one with 3axis or 4axis. My question is... is the fourth axis a module you can unplug at will or it's just fixed and you have to stick to 4axis projects. Since the difference in price is not a big deal between a 3axis and the 4axis I mean. If I can have a machine flexibile enough to handle 3axis projects as well as the 4axis ones, I will buy it of course.
    Jul 2018
    dum dum
    Hi Shadow - The fourth axis only works if it gets signals. So if your doing a 3 axis job only 3 work. If doing 4, 4 work. The above link does not work. If you have a rotary axis it can be installed and removed from the bed. In which case its not connected so does not work. Peter
    Mar 2011
    Italy
    Thank you very much peteeng, that's the answer I was looking for. Sorry, Here's the link
    Now the last thing I'm concerned about, "machining precision". I'm not able to evaluate this, and yet I would gladly toss extra bucks for... let's say... a good recirculating ball screw that doesn't wear out in a couple of days...
    Said that, it's funny how you can find the same specifications for a 6040 usb 4axis machine with prices that can range anything between 1000€ and 8000€
  7. #7
    Mar 2011
    Italy
    ok, I think I'll get this one
    https://www.amazon.it/BTdahong-Affet...gateway&sr=8-7
    Would this be a good choice?
3axis and 4axis
3axis and 4axis
