I need to build a 10' x 7' cnc router...resources?
Results 1 to 2 of 2
Thread: I need to build a 10' x 7' cnc router...resources?
    Default I need to build a 10' x 7' cnc router...resources?
    I'm working on a sculpture that requires approx. 25,000 3/8" holes in 3/4" wood slab. Ideally I've envisioned mounting rails to the sides of the wood slab as the finished dimension of the slab will be 9'6" x 6'6" with the area of holes being 9' x 6'.
    Can anyone suggest a router kit with rails that might work for this project? I'm not looking for high end over the top expensive. I would like to keep my budget around the $3000 if that's possible.
    Any suggestions and or resources would be greatly appreciated.
    Doug
    Jul 2013
    Default Re: I need to build a 10' x 7' cnc router...resources?
    Where are you located?
