- Anyone have the Freedom Patriot 4x4 CNC and what do you think of it?
Re: Anyone have the Freedom Patriot 4x4 CNC and what do you think of it?
Y axis helical rack ? how about spindle power ? control system ?
The company I worked for had 2 of the 4x8 models, and my current company has a 5x10 on the way. All 3 axis have ball screws, no rack and pinion. We had a 10hp spindle on the 2 I used, had no power issues cutting wood, plastic or aluminum, very sturdy spindle. The controls are Fagor, very robust and fairly easy to program using standard G-code, it has drill canned cycles and macros available on it. If your doing lots of repeatable parts you can do linear and rotation patterns on the control. We did a lot of counterbored holes, so I would program one and then repeat it multiple times for the others. Go to Fagors website and download the programing guide, but it's on par with the Fanuc and Haas controllers.
Malish,
What Cad/Cam software are you using?
I have a 4x8 patriot on ebay for sale. It is a very well built machine. Mine has an aluminum vac bed with t slots for clamping, so I'm sure that would still be an option on a new one. And the guy that asked about design software, I use aspire, but most programs have a post for the fagor controller.
- You may not post replies
- You may not edit your posts
Forum Rules
