Bumping thread on industryarena.com
Results 1 to 7 of 7
Thread: Bumping thread on industryarena.com
    Member crazybrit's Avatar
    Apr 2011
    Default Bumping thread on industryarena.com
    If you bump an existing cnczone thread (add a reply) at http://industryarena.com the thread is moved to the top of the list of threads (as they are sorted by most recent reply) but if you then log into cnczone.com the change isn't shown at the top of the list of most recently modified threads for that subforum. If you manually open the thread you can see the change.
    I did this by error but it's not expected behavior.
    Apr 2011
    Default Re: Bumping thread on industryarena.com
    I also noticed that if you view an existing thread logged into industryarena.com any attachments that were originally added at cnczone.com are not visible.
    Administrator burs's Avatar
    Apr 2019
    Germany
    Thanks for reporting this.
    You´re right and we are aware that there are vulnerabilities in the synchronization between IA and the Zone. In the future, there should be only one forum anyway, so these problems will not appear then. This is being worked on right now. But still need to ask for a little patience.
    Member CitizenOfDreams's Avatar
    Nov 2012
    Quote Originally Posted by burs View Post
    Is there a way to add a "cnczone style" to the new forum? No offence, but the old forum's interface is better looking and more functional.
    cnczone
    industryarena
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    yes, the old look is indeed much better; i mean not only better, is close to profesional, while the new one is a recycled design, that really speask nothing
    i was thinkinh to add over the old one a new color theme, and some mouse over effects, transparancy, to enhance it
    i didn;t had time to code it, but .... maybe i should ? i mean like a sample ... kindly 1
    ps : hy citizen
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
    Apr 2019
    Germany
    The forum will get a new layout. the current IA forum will not be kept in this form either.
    But it is still a bit of work to integrate all content and functions of the Zone with the new forum.
  7. #7
    Apr 2011
    Quote Originally Posted by CitizenOfDreams View Post
    +1
