I sent you a PM with a URL, seems to be working. Not sure what the problem is.
If I try and send someone a PM containing a URL to an existing thread here (https://www.cnczone.com....) I get an error "Server Error 403 Forbidden You do not have permission to access this document" which isn't very helpful at describing the issue.
Other urls may also cause the error (linuxcnc etc). However https urls to google drive are accepted.
Jim Dawson
Sandy, Oregon, USA
It worked from my end. Is it possible you are not getting a good copy of the URL?
Jim Dawson
Sandy, Oregon, USA
Chrome Version 94.0.4606.61 (Official Build) (64-bit)
Windows 10 (x86_64)
hy try to begin your link with www, not https
OK, one possibility is that you need to add some text to the message, above the URL. I have found that just sending just the URL does not work. For whatever reason a message without some text will fail, like trying to send a picture or maybe a URL
Jim Dawson
Sandy, Oregon, USA
i've run into this off and on here. I always have text. I have to just strip out the link in the end.
In the test I sent to you, I didn't have text but trust me I see the same WITH text. Like several paragraphs worth.
If you're pinging someone to ask them an old thread it's quite annoying.
In that case, I really have no idea what the problem is.
Jim Dawson
Sandy, Oregon, USA
