- Multicam MG103 with ATC - highly upgraded UCCNC retrofit
35,000 OBO
Not currently stored under power. Depending on interest I may get it set up and under power. Located in Provo, UT
6 x 12 ft cutting area
8 inches Z clearance
15 HP Colombo Spindle
Automatic 8 tool changer
Vacuum Table with 80hp vacuum pump
Water cooled Spindle
Wireless pendant controller
Runs on UCCNC with a highly customizable interface, possible to be programmed with a 4th lathe axis
Remote monitor/control capable
Head mounted webcam for remote monitoring
Control station runs on Ethernet and can be placed anywhere in the shop
PC brain optimized to handle simple to very large tool paths
Spindle head plate with extra space, ready to receive drill or plasma
Includes
3hp high capacity dust collector, 1 micron filter bags, and all necessary 8in piping
Lots of End Mills, including 1/8 in ball nose, 1/4 in flat/ball nose, 1/2 in flat/ball nose, 1 in ball nose, 2 in planer + others
10 Tool holders
26 Gallon ultra quiet air compressor
All other necessary tools inc lubrication
Powerful machine, can be run fast through MDF, plywood, hardwood, aluminum, plastic, brass + foam. Can also be run through steel but I never used that way. it was used primarily for highly detailed engraving.
I'm including 10 hours of remote consultation time for 6 months for help with setup or building custom macros/operations for your project. I'm also happy to do in person setup for time+travel.
Walkthrough video:
Re: Multicam MG103 with ATC - highly upgraded UCCNC retrofit
Price change 25,000, looking to move this pretty quick
- You may not post replies
- You may not edit your posts
Forum Rules
