SST Drag Knife - 3/8" shaft $80
Results 1 to 1 of 1
Thread: SST Drag Knife - 3/8" shaft $80
    Member Idbdan's Avatar
    May 2023
    Default SST Drag Knife - 3/8" shaft $80
    Cut 1 sheet of EVA Boat Carpet on a CNC with it. Worked very well. This puts the Donek knife and it's high price to shame. Much better design for blade adjustment.
    This is the 3/8" shaft model if you're checking retail prices.
    In box - like new. $80 + $8 ship (Paid $120 incl tax & ship) - Raleigh NC 27592 area
    2-15mm Adjustable Blade Height with Ability to Recall Position with Set Screw.
    3/8” Hardened Steel Shank & Compact Design Provide Compatibility with all Machines.
    Fits any Standard Utility Blade (Stanley HSS blade included).
    Dual Ball Bearing Shank Glides Smooth Without any Wobble.
    Cut Through Cardboard, Vinyl, Rubber, Plastic, Paper, Wood Veneer.
    CNC Machined from 6061 Aluminum and Backed by 5 Year SST Warranty
    Attached Thumbnails Attached Thumbnails SST Drag Knife - 3/8" shaft -ssi3-jpg   SST Drag Knife - 3/8" shaft -ssi-1-jpg
