North America 2013 Mazak VCC 5X 20K 5-Axis Vertical Mill
Results 1 to 2 of 2
Thread: 2013 Mazak VCC 5X 20K 5-Axis Vertical Mill
    Exclamation 2013 Mazak VCC 5X 20K 5-Axis Vertical Mill
    Mazatrol Matrix 2 CNC Control w/ 19'" Display
    Simultaneous/Contouring 5 Axis Cutting
    20,000 RPM High Precision Spindle
    Coolant through Spindle
    Multi-Directional Turn Table
    30 Tools High Speed ATC
    Thermal Compensation
    MPG Control
    High Speed Machining
    Dual USB Slot
    Spindle Chiller
    Spindle Orientation
    Helical Interpolation
    Rigid Tapping
    Absolute Incremental Programming
    Fast Rapid Traverse Rate
    Flood coolant with large separate coolant tank
    $47,500 - Machine is located in Magnolia, TX
    Attached Thumbnails Attached Thumbnails 2013 Mazak VCC 5X 20K 5-Axis Vertical Mill-mazak-vcc-5x-jpg   2013 Mazak VCC 5X 20K 5-Axis Vertical Mill-mazak-2-jpg   2013 Mazak VCC 5X 20K 5-Axis Vertical Mill-mazak-3-jpg   2013 Mazak VCC 5X 20K 5-Axis Vertical Mill-mazak-4-jpg
    2013 Mazak VCC 5X 20K 5-Axis Vertical Mill-mazak-5-jpg   2013 Mazak VCC 5X 20K 5-Axis Vertical Mill-mazak-6-jpg
    Default Re: 2013 Mazak VCC 5X 20K 5-Axis Vertical Mill
    Still available
