- Used AC servo motor and driver
Activation process
Delta ECMA-C20604SS AC Servo Motor with ASD-B2-0421-B Servo Drive
Pulled from a trade show display that was dismantled. Was working when the display was put in storage
ECMA-C20604SS
400W AC Servo Motor with Brake
60mm Frame
14mm h6 Shaft Diameter
110 VAC
3000 r/min
1.27 Nm
0.4kW
ASD-B2-0421-B
220V single phase or 230V 3 phase
400W rated output power
Step/Dir or analog input
Position/Speed/Torque mode
$200 + shipping per axis
$700 for all 4
Located in Michigan
- You may not post replies
- You may not edit your posts
Forum Rules
