- Cincinnati Cintimatic Vertical Bed Mill
Cincinnati CNC Vertical Mill. Retrofit from NC to CNC. 10 Hp 230V (1ph. Or 3ph.)6,000 rpm, grease bearing spindle. Air chuck with Cat 40 taper. Table 41”x25”, X-42”, Y-21”,Z-18”. Glentek Servos, Baldor Drive, Motor, Brake. Control Solutions Inc. Control systems. Flood coolant system with pump. ( internal sump in base is 25 gallon capacity) 20 cat 40 end mill holders included. I’ve had this mill for 15 years, never any problems, used for hobby. It’s hooked up and running if you need to test it. Thanks.
Cincinnati Cintimatic Vertical Mill Price
Newbie forgot to post a price and location. Sorry.
It’s $5,000 obo. Casper, Wyoming. Thanks
- You may not post replies
- You may not edit your posts
Forum Rules
