Avid/CNCRP PRO4824 with NEMA34 / 2.2 spindle / leg kit - Austin, TX
Results 1 to 3 of 3
Thread: Avid/CNCRP PRO4824 with NEMA34 / 2.2 spindle / leg kit - Austin, TX
    Apr 2009
    Default Avid/CNCRP PRO4824 with NEMA34 / 2.2 spindle / leg kit - Austin, TX
    This machine has been great but hasn't been used enough to justify the space and money that can be put to other projects. I am asking $8500 and not open to selling any parts separately. I am located in Austin, TX and am would prefer local pickup.
    1 x PRO4824 4' x 2' CNC Router Kit
    * Version: Nema 34 Compatible
    * Z*Axis Travel / Gantry Height: 8" / 8"
    1 x Leg Kit (PRO CNC)* Size: 4' x 2'
    1 x Plug and Play NEMA 34 CNC Control System
    * Cable configuration: (1) 12' and (3) 20' cables [recommended for 4'x'2' or 4'x4' machines
    * Additional Motor Drive: +1 [5th*Drive Upgrade]
    1 x Pepperl + Fuchs Proximity Sensor Kit
    * Sensor Configuration: Homing/Limit 6 Sensor Kit
    1 x Tramming GMT Spindle Mount
    1 x PC892 CNC Router Mount
    1 x 2.2 kW Plug and Play Spindle / VFD System
    1 x ER20 Collet Set 1/8", 1/4", 3/8" w/ (3) Balanced Nuts
    1 x Daedalus NL330 CNC Dust Shoe, 80mm, Red
    Attached Thumbnails Attached Thumbnails Avid/CNCRP PRO4824 with NEMA34 / 2.2 spindle / leg kit - Austin, TX-pxl_20220909_123550218-medium-jpg   Avid/CNCRP PRO4824 with NEMA34 / 2.2 spindle / leg kit - Austin, TX-pxl_20220909_123621057-medium-jpg   Avid/CNCRP PRO4824 with NEMA34 / 2.2 spindle / leg kit - Austin, TX-pxl_20220909_123737777-medium-jpg   Avid/CNCRP PRO4824 with NEMA34 / 2.2 spindle / leg kit - Austin, TX-pxl_20220909_123743338-medium-jpg
    Member Brads's Avatar
    Mar 2023
    Default Re: Avid/CNCRP PRO4824 with NEMA34 / 2.2 spindle / leg kit - Austin, TX
    Is this still available? How can I get in touch with you?
    Community Moderator RaderSidetrack's Avatar
    Apr 2018
    East Tennessee
    Quote Originally Posted by Brads View Post
    I recommend using the PM function to send a message to member elbarnso.
    Click his MemberID in post #1 and then choose "Private Message".
