Gecko 6 Axis Motion Controller (The Most Advanced Controller Available)
Results 1 to 4 of 4
Thread: Gecko 6 Axis Motion Controller (The Most Advanced Controller Available)
    Nov 2012
    Default Gecko 6 Axis Motion Controller (The Most Advanced Controller Available)
    This controller has taken me almost a year to engineer. It features tool less manipulation form the drive mounts, to the power distribution blocks.
    It features Geckos G251x drivers. These are the same drivers used in the bullet proof G540.
    You can start with a single drive, and add up to 6 at end users requirement for demand. Want to use 2 drivers on 3 axis? This can do it? Do you require a two axis system till your ready to upgrade to 4? Once again I've got you covered. It supports both parallel format, and USB through the UC-100 at additional cost.
    This is the most advanced Gecko chassis available.
    Check out the link below for a complete video walkthrough of the design. If our looking for a controller that can grow with your business this is it.
    Gecko 6 Axis Chassis 3 G251X's 48V 12 5A 3 NEMA 23 300oz in 3 5A Motors | eBay
    Default Re: Gecko 6 Axis Motion Controller (The Most Advanced Controller Available)
    good
    Mar 2013
    Seems like a really well thought out system.
    Nov 2012
    Thank you both. I appreciate it
    The thought process was long, but well worth it. This system eliminates ever requiring another chassis which is the most difficult thing when trying to build a system for later expansion.
    Hi. Thanks for sharing this. I really like the concept of Gecko 6 Axis Motion Controller. We are also dealing with controllers and monitoring system which is used in industrial lubrication. You can visit us at
    https://www.eximlubrication.com/prod...ac-controller/
