sensing program zero - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
Thread: sensing program zero
  1. #21
    Member Fastest1's Avatar
    Nov 2009
    Default Re: sensing program zero
    Charlie, I hope you are still monitoring this ;-) Should I delete the second probe in my user variables? Or is there harm in having both listed but no values on the second one?
    I have copied and pasted all of the gcodes and macros I have seen here but nothing works as a center finder. I wonder if there are user variables that I am not filling in properly? In regards to the files for different probing routines, are these only kept as a gcode or is there a way to install them as routines or selections from the FC pages?
    Quote Originally Posted by charliex View Post
    add it like this
    A lazy man does it twice.
  2. #22
    Nov 2009
    Is this the center finding routine?
    If so when I run it, there is a dialog box at the end of the process that shows 2 different decimals.
    They appear to be the amounts of correction needed in the X and then Y axis to be at dead center.
    Can anyone verify this?
    Code:
    N100 GLOBAL REAL #XC #YC #ZC
    N102 GLOBAL REAL #PX #PY #PX1 #PY1 #PX2 #PY2 #CX #CY #RAD #STEP
    N103 GLOBAL REAL #DXDY
    N103 GLOBAL REAL #DXDY1
    N104 (Switch to imperial)
    N106 G20
    N108 (switch to the touch probe, set your tool as needed)
    N110 M06 T100
    N112 (Go to Program X0Y0)
    N114 G01Y0X0F5
    N116 G31 X-1 I7 S1 E0 F1
    N118 G01 X#Program.X/2 Y0 F5
    N122 (search Y axis to -1 at feed rate of 1 input line 7)
    N124 G31 Y-1 I7 S1 E0 F1
    N126 (First point is Program.X.Program.Y)
    N128 #PX = #Program.X
    N130 #PY = #Program.Y
    (N131 M00 #PX & " " & #PY
    N132 (Step back slightly to take probe off surface)
    N133 G01 X#Program.X/3 Y#Program.Y/2 F5
    N138 (search Y axis to 2 at feed rate of 1 input line 7)
    N140 G31 Y.5 I7 S1 E0 F1
    N142 (Second point is Program.X.Program.Y)
    N144 #PX1 = #Program.X
    N146 #PY1 = #Program.Y
    (N147 M00 #PX1 & " " & #PY1
    N149 G01 X#PX/3 Y#Program.Y/3 F5
    N154 (search X axis to 2 at feed rate of 1 input line 7)
    N156 G31 X2 I7 S1 E0 F1
    N158 (Third point is Program.X.Program.Y)
    N160 #PX2 = #Program.X
    N162 #PY2 = #Program.Y
    (N163 M00 #PX2 & " " & #PY2
    N164 (Go to Program X0Y0)
    N166 G01Y0X0F5
    IF [#PX1 - #PX] = 0 THEN
    #PX1  = #PX1 + 0.0001
    ENDIF
    IF [#PX2 - #PX1] = 0 THEN
    #PX2  = #PX2 + 0.0001
    ENDIF
    IF [#PY1 - #PY] = 0 THEN
    #PY1  = #PY1 + 0.0001
    ENDIF
    IF [#PY2 - #PY1] = 0 THEN
    #PY2  = #PY2 + 0.0001
    ENDIF
    #DXDY = [#PY1 - #PY] / [#PX1 - #PX]
    N174 #DXDY1=[[#PY2]-[#PY1]]/[[#PX2]-[#PX1]]
    (M00 #DXDY & " " & #DXDY1
    IF [#DXDY1 + #DXDY] = 0 THEN
    M00 "Either lines are on same coord or too small area"
    ENDIF
    N176 #CX=[[[#DXDY]*[#DXDY1]]*[[#PY]-[#PY2]]+[[#DXDY1]*[[#PX]+[#PX1]]]-[[#DXDY]*[[#PX1]+[#PX2]]]]/[[2.]*[[#DXDY1]-[#DXDY]]]
    N178 #CY=[[-1.]/[#DXDY]]*[[#CX]-[[#PX]+[#PX1]]/[2.]]+[[#PY]+[#PY1]]/[2.]
    (N180 #RAD=[SQRT[[[[#PX1]-[#CX]]*[[#PX1]-[#CX]]]+[[[#PY1]-[#CY]]*[[#PY1]-[#CY]]]]]*[2.]
    N182 M00 #CX & " " & " " & #CY & " " & #RAD
    N183 M00 #PX & " " & #PY & "; " & #PX1 & " " & #PY1 & "; " & #PX2 & " " & #PY2
    N184 M00
  3. #23
    Aug 2009
    yep its shows the difference
    you can store both variables at once, mine looks like this
  4. #24
    Nov 2009
    Thanks so much for the reply! In my case the Y seems to take a - number using the recommendation. I wonder if my Y is backwards?
  5. #25
    Aug 2009
    or mine is
  6. #26
    Nov 2009
    As long as the center is found. Thanks again.
  7. #27
    Aug 2009
    Quote Originally Posted by Fastest1 View Post
    yep no worries, i've been using this script for a while now.. . working on an upgrade to one my other flashcut add ons at the moment too. hopefully i get somewhere with it this weekend.not sure how many FC people there are out there
  8. #28
    Nov 2009
    I know nothing about making the scripts or even how to install them other than loading GCode.
    Mach was a little different and I could find screens and options, FC not so much ;-)
    I would enjoy your sharing the one you are working on.
    Also in the center finding one mentioned just above.
    Why doesnt the measured error automatically correct in the DRO’s (if accepted)?
    I just write them down or take a pic and enter the dimensions manually.
    Am I missing a technique?
    It seems I cant get any actions from the PC til I close that dialog box.
    Sent from my iPhone using Tapatalk Pro
