Need Help! Part zero sensing marco
Results 1 to 4 of 4
Thread: Part zero sensing marco
    Registered tony978's Avatar
    Jun 2009
    Default Part zero sensing marco
    Does any one know if you can make a line of code to move an axis till line is tripped then set machine zero with a math fuction for probe cut ?
    Yes I know they have there automated part zero sensing but it will not let you set the direction of travel for each axis ! From what I have seen mach3 is better at this or more people have add there code !
    Thank you
    Sent from my GT-P5113 using Tapatalk
    Jun 2009
    problem solved !!! here is a sample for flashcut users and I add a comparison to mach 3 . I didn't add the messages to my code for if the line in is tripped already
    flashcut way to find inside center . if you use this code you need to set user variables .
    (find x center)
    g31 x2 I4 s1 E0 f5 (refer to user manual for info on g31 setup )
    g92x0.0
    g04 p1
    g31 x-2 I4 s1 E0 f5
    #x1 = #program.x
    #xc1 = #x1 / 2
    g04 p1
    g1 x#xc1 f5
    (find y center)
    g31 y2 I4 s1 E0 f5
    g92y0.0
    g04 p1
    g31 y-2 I4 s1 E0 f5
    #y1 = #program.x
    #yc1 = #y1 / 2
    g04 p1
    g1 y#yc1 f5
    _______________________________
    mach3 way Rem VBScript To center probe inside a pipe
    If GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty
    Code "(Probe plate is grounded, check connection and try again)"
    Else
    FeedCurrent = GetOemDRO(818) 'Get the current settings
    XCurrent = GetDro(0)
    YCurrent = GetDro(1)
    Code "G4 P1" 'Pause 1 second to give time to position probe plate
    Code "F4" 'slow feed rate to 4 ipm
    Rem Probe Left
    XNew = Xcurrent - 3 'probe 3 inches to left
    Code "G31 X" &XNew
    While IsMoving() 'wait for the move to finish
    Wend
    XPos1 = GetVar(2000) 'get the probe touch location
    Code "G0 X" &XCurrent 'rapid move back to start point
    Rem Probe Right
    XNew = XCurrent + 3 'probe 3 inches to right
    Code "G31 X" &XNew
    While IsMoving()
    Wend
    XPos2 = GetVar(2000)
    XCenter = (XPos1 + XPos2) / 2 'center is midway between XPos1 and XPos2
    Code "G0 X" &XCenter 'rapid move to the x center location
    While IsMoving ()
    Wend
    Call SetDro (0,0.000)
    Code "G4 P0.25"
    Rem Probe up
    YNew = YCurrent + 3
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    YPos1 = GetVar(2001)
    Code "G0 Y" &YCurrent
    Rem Probe down
    YNew = YCurrent - 3
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    YPos2 = GetVar(2001)
    YCenter = (YPos1 + YPos2) / 2
    Rem move To the center
    Code "G0 Y" &YCenter
    While IsMoving ()
    Wend
    Call SetDro (1,0.000)
    Code "G4 P0.25"
    Code "F" &FeedCurrent 'restore starting feed rate
    End If
    Member Fastest1's Avatar
    Nov 2009
    Default Re: Part zero sensing marco
    I know this is an old post but is I4 a reference to input 4? If so I assume I can change it to 7 if that is the pin I am using?
    Quote Originally Posted by tony978 View Post
    (find x center)
    g92x0.0
    g04 p1
    g31 x-2 I4 s1 E0 f5
    #x1 = #program.x
    #xc1 = #x1 / 2
    g04 p1
    g1 x#xc1 f5
    (find y center)
    g31 y2 I4 s1 E0 f5
    g92y0.0
    g04 p1
    g31 y-2 I4 s1 E0 f5
    #y1 = #program.x
    #yc1 = #y1 / 2
    g04 p1
    g1 y#yc1 f5
    Else
    Rem Probe Left
    Code "G31 X" &XNew
    Wend
    Rem Probe Right
    Code "G31 X" &XNew
    While IsMoving()
    Wend
    While IsMoving ()
    Wend
    Code "G4 P0.25"
    Rem Probe up
    YNew = YCurrent + 3
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    Rem Probe down
    YNew = YCurrent - 3
    Code "G31 Y" &YNew
    While IsMoving()
    Wend
    While IsMoving ()
    Wend
    Code "G4 P0.25"
    End If
    A lazy man does it twice.
    Jun 2009
    Quote Originally Posted by Fastest1 View Post
    Yes I4 is input 4 .
    Sent from my SAMSUNG-SM-G930A using Tapatalk
