I lubed mine but I understand the new ones are bronze bushings. Not sure how handy you are but if you have a digital caliper you can measure your shaft size and the inside bore diameter of the gear to get the sizes. My local hardware store carries brass or bronze bushings. Hopefully it will not need reaming to size.
