Problem Motor Timing Pulleys - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 20 of 20
Thread: Motor Timing Pulleys
  1. #13
    Member Ntl's Avatar
    Aug 2018
    Default Re: Motor Timing Pulleys
    Quote Originally Posted by Joesmo View Post
    Still no response from FLA. Thanks for all the suggestions but I do not have milling equipment. The easiest and right way to do it, is to just have the parts replaced by FLA. I'm old school and believe you should fulfill a paid contract.
    Maybe get the price for them from cncrp and tell fineline that you need a refund for the the amount of the pulley's. See if they respond to that, I wonder also if the pulley's are custom made for them since I never called to see if they stock them. Either way you're 100% correct that you shouldn't have to deal with this. I still am amazed that fineline has lasted this long after my experience with the company.
    Dan
  2. #14
    Sep 2017
    $16.25 each from CNCRP for NEMA 34 pulleys. I agree, FLA should honor their commitments, but we decided to order the missing parts from CNCRP and Nate did come through with the refund. Not worth the frustration.
    Saturn 2 4848
    CRP Plug & Play NEMA 34, 2.2kw Spindle, Mach3
  3. #15
    Member Joesmo's Avatar
    Nov 2018
    I got a response from Nate couple of hrs ago but I'm not sure he understood what I needed. His response was that they do not have Nema 34 pulleys with 1/2" key slot. I had requested from him Nema 34 pulleys 1/2" diameter with 5mm key slots.
    I responded with a clarification but haven't heard back.
  4. #16
    Nov 2018
    Does everyones timing pulleys have key slots and set screws? I was looking at the ones form CNCRP and they only look like they have set screws. I would think that the key slots would be a must.
  5. #17
    Member Ntl's Avatar
    Aug 2018
    Mine have both the keyway and set screws. Like I said earlier they came in boxes with cncrp part numbers on them. I saw that as well that the pictures they have don't have the keyway. But their website doesn't look like they update it very often. You should just call or at least email cncrp they might be a special order part. I don't think that they were repackage and I still don't understand why fineline won't send you the correct ones since you paid for them. Worst case you can probably file the slots to open them up, or find a local machine shop and have them open up the keyways. That's what I was going to do if I didn't get the right ones. I'm not sure what would be cheaper, buying 3 pulleys or having the wrong ones machined.
  6. #18
    Sep 2017
    Ours are from CNCRP. They have both keyways and set screw.
    Saturn 2 4848
  7. #19
    Member Ntl's Avatar
    Aug 2018
    Quote Originally Posted by micknm View Post
    Just curious did you order them from cncrp or get them from Finline?
  8. #20
    Sep 2017
    Quote Originally Posted by Ntl View Post
    CNCRP
    Saturn 2 4848
