Joe, the gantry is 150 lbs. you should be able to push it with one hand in the center.
Just received my Saturn 2x4 and everything looks good, but wife says it has to stay on pallet til after Christmas. After reading all the posts, I wanted to check the machine before I unpacked it and my question is: Without the steppers attached, how much force should it take to move the gantry on the x and y axis? It seems to move without any binding, but I thought the linear motion bearing would make it move a lot easier. Am I getting some restriction or does it take a little force(guessing bout 5-10 lbs force) to move gantry?
Joe
- Log Carving with the Saturn 2
- New Saturn 2x4
- Saturn 4x2
- New Machine Build- Saturn 2 - 4x4
- New Machine Build- Saturn 4x4
Fine Line Automation
www.finelineautomation.com
Yes, I knew the gantry was pretty solid and I am able to push it with one hand, but it does take some force. I was just concerned that the steppers were not going to be able to handle it. I noticed the grease fittings; so do I need to lube the bearings now or are they done during assembly?
Joe
This is the official grease recommend by the mfg > https://www.ebay.com/itm/Gadus-S2-V1...72.m2749.l2649 some NLGI 2 greases are very tacky I found out. This is what I ordered and use.
If you loosen the gear drive on both side and drop to disengage the rack, keeping track of the measurement or counting the turns the gantry will very easily move with one hand.
1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
Thanks for the recommendation on the grease. I have not yet installed the gear drive.
I'm using Royal Purple NLGI #2 - works perfect for this application.
David
David
Romans 3:23
CurlyWoodShop - www.etsy.com/shop/CurlyWoodShop
David Falkner - www.youtube.com/user/difalkner
difalkner - www.instagram.com/difalkner
How's the machine going? Any pictures yet?
Got the the frame welded and the machine up on it with no problems. Attached the spindle yesterday and have been ordering parts to build the control box. I'm still a little worried about the gantry movement. I've read some of your earlier posts and saw where you had trouble with binding and replaced your gantry. Someone posted that they can push their gantry and it will continue to move. Mine only moves when being pushed even after being lubed. How can I tell if it needs to much force to move. The x axis moves with about the same amount of force.
Joe
I didn't know on my table until I had everything installed and started jogging the y axis but I immediately was concerned because I could feel it stick in certain places while moving it by hand. I actually notified Nate of the problem before I even took the router off the pallet. At that time no one had reported any issues so I just thought it was because the bearings needed to be greased.
Turns out it immediately started binding once I started jogging the axis and wasn't reliable until I loosened up all the gantry bolts and as soon as I tighten them back up it would bind up again and I had to keep them loose until I got my replacement beam. It's great now and I'm very happy with how it cuts so far.
Post some pictures of the table so I can see if yours is the same as mine. Also what did Nate have to say about it? Has he responded to you yet about your concerns?
Dan
Dan
It does not seem like it is sticking, but I expected the gantry to somewhat float on the bearings. I havent installed the gears yet because I am waiting on the motors I ordered from Nate. Nate responded to an earlier post about lubricating the bearings and to let him know if I still have issues. I'm not quite sure if I have an issue because I'm not sure how freely this heavy gantry should move. I have loosened the bolts but it did not make that much of a difference. My question is, how do I tell or is there a test to how freely the gantry should move on the Y-axis? Nate says I should be able to push it with one hand and I can, but I thought it should be a little easier. Maybe it is me not being familiar with cnc routers that is causing the issues.
I'll get a pic up tomorrow when my wifes car isn't in the way.
Joe
Remember that gantry is 150 lbs. It’s definitely not going to be as easy to move as just a plain carriage because of the weight. You shouldn’t feel like you have to shove it hard to move it.
If you are concerned, we would suggest loosening the bolts on the machine. See how it moves with the bolts loose, then tighten the bolts again and realign. If there is a noticeable difference, let us know and we’ll do additional troubleshooting.
Did a little of the bolt loosening today with just a very small improvement. Will try a more comprehensive realignment tomorrow and see if anything changes. Can you post a video showing the gantry movement without motor power?
Cool looking forward to seeing your table since I haven't seen a new 2x4 table yet. I'm curious to see if it's the same as mine.
Photo of completed stand. Does this movement appear to be like everyone elses?
It's been a while since I disengaged the stepper motors but yes, that's how ours moves. At least that's how I recall it moving.
David
David
Romans 3:23
