I have a Saturn 2 with nema 23 motors and am running Mach 3.
I am just setting up the machine and very new to CNC.
After I set soft limits in what I thought X and Y only, the Z axis is now moving at 50% at stated position. For instance the Z axis only moves 4" when Mach 3 reports it has moved 8".
I have not adjusted any motor tuning, or scaling.
I have attached a photo of the Z axis steps per unit in Mach 3. This is not changed from the XML file Nate sent me.
I emailed Mach 3 and they are suggesting I do an axis calibration. I am slow to believe it is out of calibration by 50%. It seems more likely a setting is wrong and is probably something very ignorant on my part. Any help you guys can offer would be great.
Thanks,
Lance
Yes that is correct, If he does a Search I have posted my setting for the NEMA 34 system I have.
1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
Thank you so much for your help!!
