Here is an indepth article on the proper use of commercial grade epoxy to set machines on prepared concrete surfaces. They stress minimum thicknesses of epoxy even for that.
https://assets.master-builders-solut...y_Grouting.pdf
My research finds Gary is correct but only if the proper procedure is followed and the grouting is more like an epoxy bonding to both surfaces. This would make the bond between the gantry and bearing mount permanent. That is what makes it work. Otherwise I am sure it would crack.
Read more here> https://rlrowan.com/newsletters/pres...chinery-bases/
