Originally Posted by
DDgitfiddle
First off, I do not have the CNCRP controller, so I am not an expert on this. However, touch-off plates just work like simple switches, so it should work if you can get it connected. The CNCRP controller uses a standard M12 connector, but I don't know what gender or how many pins. By looking at the AUX port on the controller, you should be able to tell what style of connector you need. Looking at pictures online, it looks like you need a 4-pin male connector for the touch-off plate. You can buy the connectors at a number of places on the web, then just cut off the old connector and solder on the new one.
The next question is which of those two pins do you connect to. It doesn't matter which wire goes to which part of the touch-off plate, but there should only be two wires, not 4. If you look inside the controller, I imagine you will be able to figure out which of the pins is connected to the controller.
-Robert
