Are you referring to the X axis stepper?
David
Hi Folks.
I am putting together my Saturn I 4x4 machine. It came to
me in December of 2016, but I was delayed in completing it due
to family commitments.
I could use your help on how to install the NEMA 34 motor on
the top of the black vertical sliding router holder. The one I have is identical to
this photo:
https://www.cnczone.com/forums/attac...2&d=1482378950
Issues:
- I hear the design was changed and I am guessing I need a spacer to lift the motor higher? Are these available from Fineline?
- The shaft of the NEMA 34 motor has key in it, but I see no corresponding slot on the coupler for it key into. Is this something I need to change as well?
- The plate at the top of the tower has four threaded small diameter holes for the machine bolts, but I don't have these bolts. Does anyone know the dimensions?
If anyone has photos or tips of this part of the install, I would be grateful to see them, as I am new at this. Thank you.
I realize this is an earlier model machine and I want to thank Nate for sending me the track spacers to upgrade the machine.
Nate if I need the spacer with longer bolts and the tiny bolts to attach the NEMA 34 motor to the mounting plate,
I would appreciate these being added to the additional new rack and pinion assembly I am going
to order from you when they are back in stock.
If the design has been altered so no spacer is needed and this can be retrofitted to a Saturn I
I would be interested in this option.
A big thank you to Nate and everyone for your help!
Redcedar in Canada
- New Machine Build- Saturn 4 X 4 with Nema 34 closed loop hybrids and ESS smooth stepper
- New Machine Build- Saturn 4x4 build with Nema 34 hybrid motors and ESS
- How to install Super PID with CNCRP nema 23 plug and play unit
- New Saturn 2 4 x 4 CNCRP Nema 34 build
- New Machine Build- Saturn 2 - 4x4
David
David
Romans 3:23
CurlyWoodShop - www.etsy.com/shop/CurlyWoodShop
David Falkner - www.youtube.com/user/difalkner
difalkner - www.instagram.com/difalkner
I think he's talking about the Z axis motor. Mine also had a key that had to be removed to fit into the coupler. I don't recall what the thread was for the mounting bolts.
Saturn 2 4848
CRP Plug & Play NEMA 34, 2.2kw Spindle, Mach3
Hi Guys.
Sorry, I was unclear on the terminology.
Yes, it is the Z-Axis motor that mounts at the top and powers the ball screw that lifts the spindle up and down from the work surface.
I think I need the spacer, otherwise the shaft of the motor will not go all the way down and the
motor base plate will not mount flush.
I seem to have read that Nate came up with a spacer for this. If anyone knows about this or
about the correct four small mounting bolts for the mounting the NEMA motor, I would appreciate hearing
from you.
Micknm, so you just remove the key and slide the shaft into the coupling and tighten it up?
The coupling on the z-axis shaft will hold tight enough to the NEMA motor shaft and not slip
I assume? The key in the motor shaft had me looking for a corresponding slot on the coupler, but
there isn't one.
Thank you all for your help. This is my first build--can you tell?
David
Yes, that's correct. None of the pulleys that we got were keyed. The Z axis coupler has not slipped. We did have repeated slippage on the Y slave pulley and had to reseat it several times, even though we used Locktite on it. We wound up changing the drives out to CNCRP drives and have had no problems.
Saturn 2 4848
OK, thank you for that information.
Did you need to put a spacer in to raise the height of the NEMA motor to connect properly to the Z-Axis coupler?
If so, did you get the spacer from Fineline or make it yourself?
I appreciate your information--it's very helpful.
David
Ours may be different but this is what it looks like, spacer included -
David
David
Romans 3:23
Ok, thank you, David.
Having the picture helps.
I bought some parts today and will fabricate a spacer.
I'll let you know how it goes.
All the best!
David
Fine Line Automation
www.finelineautomation.com
