Hi Guys.
I have a Saturn I 4x4 machine and am installing the black rack spacers
that Nate kindly sent me. Nate sent me 6 spacer bars and a bag of longer
machine screws to install them.
Do you install two spacer bars per side or four spacer bars per side to extend
the toothed rack outward?
The reason I ask is the fact that I have six spacers. If it is two per side then
I have two left over. If it is four per side, then I am two short.
To me, it seems I should have either 4 or 8 spacers not six. Can you clarify this, please?
Also when installing the spacers, they do not butt end-to-end but have a gap
of about two inches between them. I assume this is correct?
Thank you!
Redcedar
Fine Line Automation
www.finelineautomation.com
Thank you, Nate!
I appreciate the quick response and the clarification.
You are correct, I had forgotten about the rack on the X-Axis.
Now I can back to work on my machine! Thank you again.
All the best.
David
Not that you need this, David, but I did a video on installing the spacers -
David
David
Romans 3:23
CurlyWoodShop - www.etsy.com/shop/CurlyWoodShop
David Falkner - www.youtube.com/user/difalkner
difalkner - www.instagram.com/difalkner
