New Machine Build FineLine Saturn2 4' x 4' with ClearPath, UC300-ETH / UB1 - Page 12
Page 12 of 12 FirstFirst ... 29101112
Results 133 to 134 of 134
Thread: FineLine Saturn2 4' x 4' with ClearPath, UC300-ETH / UB1
  1. #133
    Sep 2005
    Default Re: FineLine Saturn2 4' x 4' with ClearPath, UC300-ETH / UB1
    Quote Originally Posted by rcmcdee View Post
    Thanks for this - It seems that I needed to enable edit mode for all parameters to expose what I needed. I will update when I get back to the shop next week.
    Robb
    Robb I will get mine, the default in the drive is 200 volts, my motor was 220 at 8 amps and that is where I set mine. David had posted his settings but he was using PWM and mine was 0-10 vdc some things changed. Mine is working fine. But its -8 F here and I will not be back in the shop until this afternoon. The Hitachi drive is different from the Chinese ones on what settings need to be changed, I only made a few.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router
  2. #134
    Jan 2005
    Robb
    That is correct when the default gets changed for Parameter setting, then this affects what parameters you can change
    Mactec54
