Thanks for the mention, Erik! Making videos is really a lot of fun so I'm glad you have gotten some good out of them. Some of the grease fittings are a bit tight to access but I've gotten good results by just holding the hose end tightly to the grease fitting. And I'm using Royal Purple #2 grease - seems to be working just fine.
Also, I have no complaints from the 2x4 frame I built for our machine. It gives a tiny bit in the Y direction with rapid moves and stops but I don't think that affects accuracy on the machine because the Saturn frame to spindle relationship doesn't change. I could add another couple of diagonal braces to lock it down tighter but that would limit my access to storing things under the CNC and I need all the space I can get in our small area.
Post some photos when you get time, even down on the pallet. We like pictures!
David
