Trumpf 2030 4kw fiber - cutting good for five minutes then can't cut through a sheet
Results 1 to 1 of 1
Thread: Trumpf 2030 4kw fiber - cutting good for five minutes then can't cut through a sheet
    Oct 2023
    Default Trumpf 2030 4kw fiber - cutting good for five minutes then can't cut through a sheet
    We recently purchased a used Trumpf 2030 4kw fiber from 2017. Only about 3000 hours on it.
    Cutting galvanized steel 8-14g. Just installed a new N2 generation system.
    It will cut good for about five minutes and then stop cutting through the sheet. We then let it sit and it cuts good again.
    What can we check?!?!?
    jjungels's Avatar
    Oct 2023
    Default Re: Trumpf 2030 4kw fiber - cutting good for five minutes then can't cut through a sh
    LaserJim,
    Some things I would look at for a start are
    -laser coolant levels
    -main laser filter
    -build up of material on the nozzle when its cutting
    -possibly your N2 generation unit is too small and cannot sustain the amount of cutting that you are doing
