Trying to machine Barrel Cam which has a simple profile wrapped around.
Using Featurecam, I created the curve using from both edges of the cam to be cut using the Create Curve from Surface Edges feature. When I select both edges it connects them and when machining this connected part is left out from the tool path. So there's a strip of metal left over that goes from top to bottom of the profile.
