- Need Help!- Turn/mill rough machining
Good morning guys,
I've little issue with mill/turn machining
Attached the image of the screw that i want to machine with a mill/turn lathe
When i set the strategy the software allow only finish machining and the tool work so hard inside the main body of the screw
The simulation of the 4 axis machining is ok and the program generated is ok but featurecam want to do this machining in only one time
This part is made in plastic and for now i think is not a big problem but what i must do if the part will be steel/CRES?
To avoid this issue i'm designing more offset surface and made many program to avoid strees on tool
Thanks for help and sorry for my (google translator free) english
Inviato dal mio HMA-L29 utilizzando Tapatalk
- You may not post replies
- You may not edit your posts
Forum Rules
