Need Help! FC changing material
Results 1 to 5 of 5
Thread: FC changing material
    Dec 2009
    Default FC changing material
    Featurecam constantly changes the material from say Aluminum to "Aluminum from [filename]". This throws off the speeds and feeds, of course. I'm sure I'm missing something fundamental, but how can I keep FC from changing the material?
    Thanks.
    Member sabregr's Avatar
    Dec 2013
    Neapoli
    Default Re: FC changing material
    Go to Options -> File Options -> Existing files and set the Feed/Speed to Use the F/S tables from FeatureCAM's F/S Database
    Dec 2009
    Thanks for the reply. Before I do this, will this change the F/S I've already saved for ALUMINUM for each cutting tool?
    Dec 2013
    Neapoli
    No, I think this information is saved with the tool
    Dec 2009
    I'll try that, thanks.
